POV-Ray : Newsgroups : povray.advanced-users : What is HDRI? Server Time
9 Feb 2026 16:36:24 EST (-0500)
  What is HDRI? (Message 1 to 10 of 33)
Subject: What is HDRI?
Date: 11 Jan 2003 12:19:33
Message: <3e205225$1@news.povray.org>
I've been away from playing with Pov-Ray for a few years, so I haven't heard
about this utility. Some of the pictures I've seen in p.b.i. are stunning --
they look like photographs. I'm certainly not looking for advice on how to
use it (I'm back up to the point where I can make a scene with spheres and
boxes without screwing up :-) ), just a sort of basic explanation of what it
is, and how it works. Thanks.
Mark
Subject: Re: What is HDRI?
Date: 11 Jan 2003 12:36:12
Message: <3e20560b@news.povray.org>
From what I know, it's an image which can have color channel values
greater than 1 (normal images can only have values between 0 and 1).
  That's it.
  The reason why that makes a big difference is another story, which I'm
not really qualified to explain, as I don't have any experience at all.
Date: 11 Jan 2003 15:59:46
Message: <cjameshuff-2AF9BB.15493311012003@netplex.aussie.org>
In article <3e205225$1@news.povray.org>,
Basically, to make a really realistic scene, it helps for your objects
to have realistic surroundings and lighting, especially for things like
reflections. You can construct this environment entirely in the
computer, having the computer actually simulate the entire scene, but
this takes memory, computation time, and is difficult or just time
consuming.
HDRI means High Dynamic Range Image. Usually, image color values are
percentages, you can have 0%, 100%, and steps in between. Of course, in
reality, there is no "100% brightness", it is just a compromise for what
our display devices can show. High dynamic range images store
intensities instead of percentages, and can store values brighter than
"white".
An HDRI image can be used to store lighting values for a scene, either
precomputed ahead of time or taken from a real-world sample. Since the
lighting values already exist, it doesn't take as long as having the
actual scenery there, it is easier to set up, and the lighting is more
realistic than a background from an ordinary image, with color values
clipped to a small range.
http://tag.povray.org/
Date: 11 Jan 2003 23:53:16
Message: <3e20f4bc$1@news.povray.org>
Very similar, in fact, to a convolution reverb, which samples the ambience
of a space and applies that to a sound recording, given the recording the
illusion of being in the space.
D.
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cja### [at] netplexaussieorg...
heard
stunning --
to
and
what it
> consuming.
> "white".
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 12 Jan 2003 13:19:31
Message: <3e21b1b3$1@news.povray.org>
Where does the scene come from? A scene you've already rendered? From
reading a few of the posts in p.b.i., it seemed like they were photographs.
Is that it?
Mark
Date: 12 Jan 2003 13:42:55
Message: <cjameshuff-D66628.13322612012003@netplex.aussie.org>
In article <3e21b1b3$1@news.povray.org>,
> Is that it?
"either precomputed ahead of time or taken from a real-world sample."
It doesn't really matter where it originally came from...could be
generated with a high-quality renderer, could be taken from a real-world
location. If the patch allows POV to output images in that format, you
could generate the images with POV. Then you would have to do the work
of setting up the scenery, but you would only have to do that and render
once, and could use the resulting HDRI map in several other scenes, or
to make a faster rendering animation. Most HDRI maps seem to be
real-world samples, probably because there isn't much rendering software
that can output to those images. I think Radiance can do it, or it might
just use its own RGBE format.
Date: 12 Jan 2003 21:40:39
Message: <3e222727$1@news.povray.org>
You can look for "probes" at various sites that have been mentioned
recently.
D.
"Mark Hanson" <mar### [at] attbicom> wrote in message
news:3e21b1b3$1@news.povray.org...
photographs.
> Is that it?
> Mark
Date: 14 Jan 2003 14:45:44
Message: <web.3e24683e552627465543301f0@news.povray.org>
What made HDRI make sense to me was the idea/fact that it was "invented" to
allow artificial 3D objects to be placed into a "real" scene.
Have you ever watched a program with CGI in an "real" scene where the CGI
just didn't look quite right, but you couldn't quite put your finger on why?
The likely cause was the improper lighting.  HDRI samples light differently
than, say, a single exposure on a digital camera.  From what I understand,
it does this by having multiple exposures of different lengths.  By doing
this, it can approximate the "real" intensity of the light.  By using this
light data, you can then place 3D objects into a "real" scene and have much
better lighting.
A good example is simply sunlight coming trough a window into a dark room.
On a normal photograph, the window may simply look "white".  However, having
a white piece of paper hanging on the wall does not begin to have the same
effect on lighting as sunlight coming through a window.  If you consider
all-white to be rgb<1,1,1>, then sunlight would be something like
rgb<1000,1000,1000>, but a normal digital photo can only show things in the
range rgb<0,0,0> to rgb<1,1,1>, so you'd lose all of that extra light.
I'm not sure if that made sense or not.  If you're like me, you'll be
driving down the road and suddenly go, "Hey, that makes sense now!"
Good Luck,
Slash
Date: 14 Jan 2003 15:24:26
Message: <3e2471fa$1@news.povray.org>
"Slashdolt" <nomail@nomail> wrote in message
news:web.3e24683e552627465543301f0@news.povray.org...
<snip>
Well, I'm getting there. HDRI is a way of approximating real-life situations
that Pov-Ray can't do, or can't do well -- I'm thinking events like depth of
focus, glare, sun flares.
Next: is HDRI a program in itself?
Mark
Date: 14 Jan 2003 15:50:05
Message: <web.3e247766552627465543301f0@news.povray.org>
Not quite.  It really has to do with one thing only, afaik.  Simply the
lighting.
By allowing some things to be brighter than simply "all-white" it allows you
to insert a 3D object into a "real life" photo, and have the same lighting
in the room as you did when the photo was taken.  To use my "sun coming
thru a window" analogy, your 3D object could actually be "lighted" from
where the sun hits on the far side of the room indirectly, and not just
from the actual light source.
I still don't feel I'm explaining this very well.  Maybe if I said something
like, "To some extent, it's like radiosity coming from a photograph rather
than from a light source bouncing off 3D objects in a completely rendered
scene."
Slash
