POV-Ray : Newsgroups : povray.advanced-users : What is HDRI? Server Time
17 May 2026 21:32:41 EDT (-0400)
  What is HDRI? (Message 14 to 23 of 33)
Subject: Re: What is HDRI?
Date: 16 Jan 2003 10:58:21
Message: <cjameshuff-A31352.10574316012003@netplex.aussie.org>
In article <3e24a4da@news.povray.org>,
 "Mark Hanson" <mar### [at] attbicom> wrote:
> No, actually that about did it. I'm rendering a statue in a white room.
> There is one light source illuminating the side of the statue the camera is
> looking at, meaning the other side is dark. HDRI bounces the light off the
> white walls and illuminates (partially) the other side if the statue. Do I
> have it now? That's pretty cool.
No. Radiosity alone does that. HDRI just lets you encode the lighting
values in a high dynamic range image, so you don't have to calculate it
during rendering and can use real-world surroundings without having to
model them.
http://tag.povray.org/
Date: 16 Jan 2003 11:37:14
Message: <3e26dfba$1@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cja### [at] netplexaussieorg...
is
the
I
> model them.
Okay, I give up. :-) I don't know enough about higher-end rendering to
understand it. But I'll get there some day. Thanks to everyone.
Mark
Date: 3 Mar 2003 09:07:43
Message: <3e6361af@news.povray.org>
Do not give up!
HDRI is just the BITMAP, nothing more.
Its higher dynamics & lower bounds on intensity clamping give you
opportunity to use it as a source of data which is more real than
clamped & more discretized RGB map such PNG,BMP etc.
Its a BITMAP!   ... used in a very cheap way to light the scene or
place more dynamic reflections/refractions.... its a touch of reality in
the very clamped POVRAY world....
Date: 3 Mar 2003 09:13:57
Message: <sjo66v0co8k9mdl2n5qiqnk8dk6lspm00j@4ax.com>
On Mon, 3 Mar 2003 15:07:05 +0100, "T.J.Viking" <vik### [at] bp-domarpl> wrote:
would you like to make "clamped" word usage more clear here?
ABX
Date: 3 Mar 2003 09:47:27
Message: <3e636aff@news.povray.org>
clamping (in GFX world) - clipping some values in suitable range
.. in POVRAY clamping occurs in final RGB discretization process, but also is
present in radiosity code i many places - the author of implementation had some
intention to make POV radiosity more artistic one.. rather than real one....
Date: 3 Mar 2003 10:00:26
Message: <85r66vgt97vbv62ou75qoimr6qv89ju5oe@4ax.com>
On Mon, 3 Mar 2003 15:46:50 +0100, "T.J.Viking" <vik### [at] bp-domarpl> wrote:
Gooood. I was affraid that you meant "POV community" as "POV world" which could
change "clamped" sense a lot.
Have you done some "unclamping" for radiosity code ? Have you some results ? Any
patched version available ?
ABX
Date: 3 Mar 2003 12:08:21
Message: <3e638c05$1@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:85r66vgt97vbv62ou75qoimr6qv89ju5oe@4ax.com...
could
Now, *THATS* paranoid.... ;)
Date: 4 Mar 2003 03:39:02
Message: <3e646626$1@news.povray.org>
ehhhh :) no comment... :)
Nope.
I am writing my own GI renderer and studied radiosity/monte carlo/irradiance caching
over
years.... then tried to look how POV is doing that.
When I saw the GI code in POVRAY, I sat down and started to cry :)
Many bugs! Bugs meant by misunderstanding light theory and many nifty
"methods" of coping with "crossing 1's value".
I know the code is working, but is highly limited in some areas eg. light is not so
well
propagating in corridors, tunnels etc. due to many limits bound on GI values during
caching and mixing with diffuse coefficients - no matter how many GI bounces you
gave in rendering settings.
I think that it is the time to redesign radiosity code, there are so many new theories
and
algos now... somebody could boost POV in XXI century.
Date: 4 Mar 2003 04:26:59
Message: <3E647162.7C018C44@gmx.de>
theories and
Very funny.
Instead of making 'wise' comments just get the POV-Ray source from
http://www.povray.org/download/
and implement a better radiosity function.  If you are as competent in
that matter as you pretend to be this should not be a problem.  If not i
suggest you either stop your complaints or support your critiques with
some proof.  This of course would require actually using POV-Ray.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 4 Mar 2003 04:28:34
Message: <3e6471c2@news.povray.org>
"T.J.Viking" <vik### [at] bp-domarpl> wrote in message
news:3e646626$1@news.povray.org...
theories and
If you can provide a decent patch, I'm sure it will make it's way to megapov.
Once megapov gets enough features, it tends to become the standard
pov-executable for the majority of users.
