POV-Ray : Newsgroups : povray.advanced-users : Does PoV-Ray have a readable (by humans) info output? Server Time
19 Dec 2025 21:32:28 EST (-0500)
  Does PoV-Ray have a readable (by humans) info output? (Message 1 to 6 of 6)
Subject: Does PoV-Ray have a readable (by humans) info output?
Date: 9 Jan 2003 17:28:19
Message: <3e1df783@news.povray.org>
Will PoV-Ray output pixel information into a comma-delimited or similar
format? Is there a converter somewhere to change a PNG into a readable text
format?
I'm looking for rgb values of each pixel in an image, preferable at 16 bits.
 -Shay
Subject: Re: Does PoV-Ray have a readable (by humans) info output?
Date: 9 Jan 2003 17:43:18
Message: <3e1dfb06@news.povray.org>
> format?
  I think that the PPM format is ascii, IIRC.
Date: 9 Jan 2003 18:13:10
Message: <cjameshuff-5F1AC5.18032609012003@netplex.aussie.org>
In article <3e1df783@news.povray.org>, "Shay" <sah### [at] simcopartscom>
> format?
You seem to be a bit confused here..."16 bits" is meaningless for text
output. What you get is a string in decimal format, for 16 bits binary
data it would range from 0 to 65535, expressed as "0" and "65535".
Anyway, as someone else mentioned, the PPM format has an ASCII type. I
don't know if POV supports it, or if it supports that color resolution.
http://tag.povray.org/
Date: 9 Jan 2003 20:47:47
Message: <m2d6n5ixmk.fsf@localhost.localdomain>
"Shay" <sah### [at] simcopartscom> writes:
> format?
http://www.tuxedo.org/~esr/sng/
email  : art### [at] aaaapollolv
jabber : aro### [at] jabberorg
ICQ    : 158902222
Date: 10 Jan 2003 04:36:08
Message: <3E1E96A8.6B87FC31@frege.mathematik.uni-freiburg.de>
PPM comes in two variants: Originally it used to be just ascii,
so that pictures could be sent via email in the ancient days (or
something like that). Then people started to get annoyed by file
sizes of 12 bytes per pixel (for 8 bit depth) and the ,,packed''
variant was added. There only the header is pure ascii.
To my knowledge Povray outputs only packed ppm. So you would
have to convert that into unpacked.
If using Linux you should do
  man ppm
  man pnmtoplainpnm
  apropos ppm
  apropos pnm
for further information.
  Mark
Date: 10 Jan 2003 09:39:15
Message: <3e1edb13$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message
news:3e1df783@news.povray.org...
Thank you all for the replies. The PPM output from PoV-Ray is not the ASCII
type, but I *think* that I can convert it with this:
http://www.math.iastate.edu/burkardt/g_src/ppmb_2_ppma/ppmb_2_ppma.html
I'll have to explore that more later.
 -Shay
