Subject: Does PoV-Ray have a readable (by humans) info output?
Date: 9 Jan 2003 17:28:19
Message: <3e1df783@news.povray.org>
Will PoV-Ray output pixel information into a comma-delimited or similar
format? Is there a converter somewhere to change a PNG into a readable text
format?
I'm looking for rgb values of each pixel in an image, preferable at 16 bits.
-Shay
Subject: Re: Does PoV-Ray have a readable (by humans) info output?
Date: 9 Jan 2003 17:43:18
Message: <3e1dfb06@news.povray.org>
> format?
I think that the PPM format is ascii, IIRC.
In article <3e1df783@news.povray.org>, "Shay" <sah### [at] simcoparts com>
> format?
You seem to be a bit confused here..."16 bits" is meaningless for text
output. What you get is a string in decimal format, for 16 bits binary
data it would range from 0 to 65535, expressed as "0" and "65535".
Anyway, as someone else mentioned, the PPM format has an ASCII type. I
don't know if POV supports it, or if it supports that color resolution.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
"Shay" <sah### [at] simcoparts com> writes:
> format?
http://www.tuxedo.org/~esr/sng/
email : art### [at] aaa apollo lv
jabber : aro### [at] jabber org
ICQ : 158902222
PPM comes in two variants: Originally it used to be just ascii,
so that pictures could be sent via email in the ancient days (or
something like that). Then people started to get annoyed by file
sizes of 12 bytes per pixel (for 8 bit depth) and the ,,packed''
variant was added. There only the header is pure ascii.
To my knowledge Povray outputs only packed ppm. So you would
have to convert that into unpacked.
If using Linux you should do
man ppm
man pnmtoplainpnm
apropos ppm
apropos pnm
for further information.
Mark
Date: 10 Jan 2003 09:39:15
Message: <3e1edb13$1@news.povray.org>
"Shay" <sah### [at] simcoparts com> wrote in message
news:3e1df783@news.povray.org...
Thank you all for the replies. The PPM output from PoV-Ray is not the ASCII
type, but I *think* that I can convert it with this:
http://www.math.iastate.edu/burkardt/g_src/ppmb_2_ppma/ppmb_2_ppma.html
I'll have to explore that more later.
-Shay
