POV-Ray : Newsgroups : povray.advanced-users : Waterdrops on Glass... How? Server Time
9 Jun 2026 21:19:42 EDT (-0400)
  Waterdrops on Glass... How? (Message 11 to 20 of 34)
Subject: Re: Waterdrops on Glass... How?
Date: 14 Jan 2003 16:21:55
Message: <3e247f73$1@news.povray.org>
3e240121$1@news.povray.org...
> I've uploaded a zoomed-version on the window,
> http://www.digitaltwilight.de/no_lights/rain_1.jpg
Looks like a good start. Perhaps the droplets should be more homogeneous in
shape, though it depends on whether it's still raining or not. Here are some
reference images if you haven't got them.
http://www.danheller.com/images/Italy/Tuscany/rain-window-big.jpg
http://www.pacamera.com/memberGalleries/ammac/rainWindow.jpg
http://www.sengers.ch/special/tropfen.jpg
> How did you place those droplets of yours? Using trace?
> Though some look like the gravitational-pull is actually
> affecting the droplet. How'd you do that?
The trouble is that the code isn't commented...
From what I understand of it, it first creates a grid of droplets in a u,v
plane, because I had observed that in real life dew droplets are somehow
organised and not 100% random (it's different from the rain-beated window
then). The macro is given attractor points that draw droplets to them
(droplets far from the attractor are smaller), with some gentle
function-based displacement. This allows "lines" of droplets of decreasing
size to be created (it's more visible here
http://www.oyonale.com/ldc/images/abeilles.jpg). It's far from perfect but
100% random positionning was really unrealistic.
The u,v positions and sizes of the droplets are stored in arrays and are
then wrapped around the object (a simple cylinder in this case) as a single
blob.
About the gravitational pull, I remember doing it but I can't find it in the
code so perhaps it's just luck...
G.
- Graphic experiments
- Posters
Date: 14 Jan 2003 16:27:38
Message: <3e2480ca$1@news.povray.org>
hey guys
> http://www.cs.unc.edu/~lin/COMP259/LEC/29b.ppt
can you tell me which app i have to use to view that file? powerpoint fails
(normaly uses .ppt, didn't think it would fit either), but google, wotsit ?
co just give powerpoint as target application...
thanks:florian
Date: 14 Jan 2003 16:29:19
Message: <3e24812f@news.povray.org>
3e24041e@news.povray.org...
> Its pretty interesting and perhaps, when I get the time to
> understand it, I'll implement it. Could be useful, at least
> for meshes (and windows can easily be done with
> meshes).
Thanks ! It looks very interesting indeed. I'll have a look at it too, but I
haven't done this kind of math since 1986... It seems feasible in POV-Ray
SDL and could give very nice results.
G.
- Posters
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
> Email: Tim### [at] gmxde
Date: 14 Jan 2003 16:32:10
Message: <3e2481da$1@news.povray.org>
It worked fine with Powerpoint for me. Perhaps you've
got the wrong Version?
Here's something that looks much better, and covers the same
topic (I guess its actually the same, though the PPT was the
presentation part...)
http://www.eml.hiroshima-u.ac.jp/member/staff/kin/publications/CA93/wdroplet
.pdf
Tim Nikias
Date: 14 Jan 2003 16:34:46
Message: <3e248276@news.povray.org>
As mentioned to Florian Brucker, here's a link to a better
and more handsome PDF-Version:
.pdf
If you actually do it, remember to comment it the SDL heavily,
so that others might learn from it. I know, you're french, and would
probably comment in french, but I'm german and still try to stick to
english when naming parameters and such, so that most Users might
learn something and understand it very easily...
And from your posts it doesn't look like you're not skilled enough for
english commentary! :-)
Tim
Tim Nikias
Date: 14 Jan 2003 16:55:58
Message: <3e24876e$1@news.povray.org>
3e248276@news.povray.org...
Oh well, some people here are so good at maths that they could probably
implement this in a evening or so [hint, hint ;-)] ...
My only advantage is that Nobel Prize Pierre-Gilles de Gennes (who is cited
a in the paper) works a couple of streets away so I could perhaps kidnap him
and ask for functional, working code...
I know, I know, even the scenes I don't plan to release are commented in
English now, just in case I have to cut and paste some code in these
groups... Not that I like it but it's better than renaming the variables at
the last minute.
G.
- Posters
Date: 14 Jan 2003 17:07:02
Message: <cjameshuff-CABB66.17064414012003@netplex.aussie.org>
In article <3e23a9eb@news.povray.org>, "KalleK" <kal### [at] gmxde> wrote:
> Maybe, you can tinker with clipped_by, to clip the surface of the drop which
> would contact the window. I don't know wether the ray remembers the ior of
> the object it currently is in or not. But if it's so, the ray would go from
> 1.33 straight into 1.45. which should be right...
Don't. This will not work properly: the ray will never leave the object
if it goes through an area that was clipped away, and won't enter the
object properly from the glass side. The correct solution is simpler,
just overlap the objects.
http://tag.povray.org/
Date: 14 Jan 2003 17:16:49
Message: <cjameshuff-95B46C.17162714012003@netplex.aussie.org>
In article <3e23f9ed$1@news.povray.org>,
 "Tim Nikias" <tim### [at] gmxde> wrote:
> It "does things"? What does it do? Just curious.
Take a ray entering a droplet for example: it hits the droplet surface
and gets refracted, and is now inside the droplet. The next surface it
hits is the glass, so it gets refracted as it should when going from
water to glass. It is now inside the glass and the droplet. When it hits
the other droplet surface, *no refraction is done*, but it leaves the
droplet. (I think it still computes the texture, I'm not sure it should
though.)
Now the ray has gone through the droplet, been refracted going from
air/water and water/glass, and is now in the glass, just as it should be.
> Though doing that with blobs is still kinda difficult...
No more so than for any other object. The difficulty is more determined
by the object you are placing the blobs on.
Date: 14 Jan 2003 19:56:42
Message: <3e24b1ca$1@news.povray.org>
Why don't you like it? I've heard several rumours about
french people and languages... They like to stick to theirs... ;-)
In some respect, germans are much the same. Some are
really against incorporating english words into the known german
vocabulary. And sometimes, things get messed up. For example,
cell-phones are called "Handy", but ask any american, they
wouldn't know what we're referring to, unless they're told.
About that math-stuff... I think, if I sit down, I could solve it,
though perhaps not strictly by the rules given in the paper. Especially
that modelling part about angles of the water-droplets and such would
be quite difficult, I think.
But right now, I'm not really in the mood to dig into that. There's a lot
of scientific papers floating on my harddrive, waiting to be implemented
in one way or the other... Next week perhaps... ;-)
No, seriously, I do like the idea of this, might be a very useful addition
to lots of realistic scenes. I've actually found some MPEG showing off
what the code is capable of:
http://www.eml.hiroshima-u.ac.jp/member/staff/kin/publications/JVCA
As I'm posting this, the page can't be accessed, don't know why. Perhaps
back online tomorrow.
We'll see who gets to implement this first. That wave-algorithm Rune
and then Christopher Hormann (if I'm not mistaken, was at least a
Christopher :-) implemented was something I wanted to do as well...
Tim Nikias
cited
him
at
> the last minute.
Date: 14 Jan 2003 20:01:20
Message: <3e24b2e0$1@news.povray.org>
I guess you meant "When it hits the other glass surface", cause it makes
no sense if it doesn't refract when exiting the water and entering air.
> though.)
I think it should compute the texture, since if an object is transparent and
has two sides, POV's rays will be affected by each surface. That's just
the way its implemented and IMHO how I would expect it to behave. If
we'd want 100% realism, we'd probably have to texture it completely
transparent, but add some interior color, like using fade_color and
fade_power or such.
You're right about that. It works pretty well for a window made of a single
box, but I'm always thinking "general", to keep things flexible.
Tim Nikias
