How would I go about finding a point on a ray the is equa-distant from to
other points?
Kevin
#macro _(r)#if(r<12)#local i=asc(substr("oqshil
acefg",r,1))-97;disc{<mod(i,7)-3,div(i,7)-1,6>,z,.4
pigment{rgb 10}}_(r+1)#end#end _(1)//KL
In article <3e18ef67@news.povray.org>, "Kevin Loney" <klo### [at] pt2m com>
> other points?
Your message is a little garbled. You want to find a point on a ray, the
point being equidistant to two other points? This is not always
possible, not without having the point shoot off to infinity.
The point will be in a plane perpendicular to a line between the two
known points and passing through the midpoint. You can easily calculate
this plane and find the intersection of the ray with it (with trace() or
by using the plane equation), but as I mentioned, with a line it can go
off to infinity, and with a ray there is sometimes no solution.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
Program ended abnormally on 1/5/03 9:50 PM, Due to a catastrophic Kevin
Loney error:
> other points?
If you have two points,
Pa = < Xa, Ya, Za >
Pb = < Xb, Yb, Zb >
then the point (M) that is in the middle will be:
M = < (Xa+Xb)/2, (Ya+Yb)/2, (Za+Zb)/2 >
Of course, in POV, you can simply use:
M = (Pa+Pb)/2
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* videotron.ca */}camera{orthographic location<6,1.25,-6>look_at a }
I'll post a diagram in p.b.i in a minute it should give you a better idea of
what I'm trying to find
Kevin
In article <cja### [at] netplex aussie org>,
#macro CompPoint(pA, pB, rayStart, rayDir)
// The midpoint and plane normal.
#local midPt = (pA + pB)/2;
#local Norm = vnormalize(pB - pA);
// Compensate for the plane not passing through the origin.
#local lRayStart = rayStart - midPt;
// Solve for intersection distance with line.
#local T = (vdot(Norm, lRayStart)/vdot(Norm, rayDir))
// If T is > 0, there is a ray intersection at rayStart + rayDir*T.
// Otherwise, no intersection. You'll need to fill in the blank.
Untested, I may have made an error, or trace() might be a better idea,
it would certainly be simpler.
Francois Labreque <fla### [at] videotron ca> wrote:
> M = (Pa+Pb)/2
Just for the sake of curiosity: This is also called average. :)
that solved my problem quite nicely
thank you
Kevin
>#end
I think this line;
- should have been:
#local lRayStart = midPt - rayStart;
And there should be no need to normalize
the normal vector.
Here's how I would have written that macro:
#macro CompPoint(pA, pB, pRayStart, vRayDir)
#local pMid = (pA + pB)/2;
#local vNorm = pB - pA;
#local T =
vdot(pMid - pRayStart, vNorm)/vdot(vRayDir, vNorm);
(pRayStart + T*vRayDir)
#end // CompPoint
And here's how I would test the ray:
#declare pHit = CompPoint(p0, p1, pRay, vRay);
#if (vdot(pHit - pRay, vRay) < 0)
#debug "There is no point on the ray that has"
#debug "equal distances to both points."
But I have not tested my code either,
so I too could be wrong.
Tor Olav
>> M = (Pa+Pb)/2
Warp, I'm a little curious too:
Can you explain how it makes sense to
calculate the average of two points ?
Tor Olav
What happened to the end ?
Tor Olav
