POV-Ray : Newsgroups : povray.advanced-users : Fairy lights (PS. I'M BAAAACK!!!) Server Time
9 Jun 2026 22:47:19 EDT (-0400)
  Fairy lights (PS. I'M BAAAACK!!!) (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Fairy lights (PS. I'M BAAAACK!!!)
Date: 2 Jan 2003 19:45:04
Message: <N2k0CIAOzNF+Ewbn@econym.demon.co.uk>
Wasn't it Andrew Coppin who wrote:
>He folks.
>I'm baaaaaack!!!
>(Oh, what's that - no one noticed I was gone? *sigh* Oh well...)
>Anyway, I've been wondering about something... I love lights on Christmas
>trees. And my dad has more sets of lights than you can shake a VERY big
>stick at!! I've been thinking about trying to simulate some with POVRay, but
>I already know it's not going to be easy. The question is... Why do bright
>lights have an "aura" around them? I mean, you can see a fairy lights from
>quite a distance, considering how tiny they are. If I try and draw them with
>POVRay they'll be smaller than a single pixel... but in the real world they
>have a kind of "glare" around them which takes up more space and makes it
>easier to see them from a distance (when they're lit!) Is there some
>physical explaination for this?
I don't know about real-world physics, but the simple fix is to use the
MegaPOV "glow" feature.
Mike Williams
Gentleman of Leisure
Date: 2 Jan 2003 22:09:15
Message: <3e14fedb@news.povray.org>
but
with
they
Scattering media. Light leaving the bulb that's going not-quite-towards your
eye reflects off of air particles. You can try to simulate it with a *very*
low density scattering media (which is basically a simulation for air
particles, or maybe fog). Make sure you don't use scattering type 1; you'll
probably have the best results using type 5 and fiddling with the
eccentricity value. However, it's probably a lot easier to just use a little
emmitting media around the light to create the glow effect.
 - Slime
[ http://www.slimeland.com/ ]
Subject: Re: Fairy lights (thanks!)
Date: 3 Jan 2003 15:10:34
Message: <3e15ee3a@news.povray.org>
Thanks everybody. Was just wondering why this effect occurs. I've noticed
that when I blink the patterns of light scattering change, so I'm thinking
maybe it's the film of water on the surface of my eyes that does it...
Whatever it is, you're all quite right - either scattering media or (more
efficiently) emission will sort of simulate it.
While we're on the subject... Why DO cameras get lense flare? Just
curiose...
See ya's around ;-)
Andrew.
PS. My current WIP is a Single Image Picture Sterogram (SIPS). Don't know if
it'll be any good mind you...
Date: 3 Jan 2003 15:35:14
Message: <cjameshuff-894F5E.15311203012003@netplex.aussie.org>
In article <3e15ee3a@news.povray.org>,
Part of it is in the eye and on its surface. Part of it is atmospheric:
things look very different in rain or fog, and distance affects things
too.
> curiose...
A similar reason: the surfaces of the lenses reflect as well as refract.
Light from a very bright source can bounce through the lens system a
several times before hitting the film. That is why they sometimes form
lines of dots of changing size.
http://tag.povray.org/
Date: 3 Jan 2003 16:06:25
Message: <3e15fb51@news.povray.org>
Thanks for that!
Andrew.
Date: 3 Jan 2003 16:51:24
Message: <3e1605dc$1@news.povray.org>
"Andrew Coppin" <orp### [at] btinternetcom> wrote in message
news:3e14aaa2@news.povray.org...
with
they
Well, additionaly to all that has already been said, we benefit from a very
detailed simulation system oft named "reality" which is able to sample each
and every ray for every "pixel" on you retina. Hence, you see lights where
POV has a very great probabilty of seeing nothing because no ray hits the
light (not the light_source point, that is invisible - you can only see its
effects on its surronding, firstly the lamp itself (the glass, ...)).
Povingly,
Philippe
Date: 17 Jan 2003 15:51:20
Message: <12iwgqbbcv2k9$.1q6lsrlw5hqiu$.dlg@40tude.net>
On Thu, 2 Jan 2003 21:09:46 -0000, Andrew Coppin wrote:
> He folks.
> I'm baaaaaack!!!
> Or do I just need to clean my glasses???
> Thanks!
> Andrew.
I made my own lens flare include file. It points the camera at a mirror
with reflection 1 and a specular highlight is used to simulate these halos.
It works fairly well with point lights but it's a pain to use. The basic
idea is simple and you should be able to do it yourself.
Date: 20 Jan 2003 15:33:38
Message: <84317krcf13m$.1tb8uisv2qa23.dlg@40tude.net>
>> He folks.
>> I'm baaaaaack!!!
>> Thanks!
>> Andrew.
A very slight micro-normal on the mirror with really good antialiasing or
focal blur might work well with bright ambient objects or media as light
sources but beware of render times!
Date: 23 Feb 2003 12:05:05
Message: <web.3e58ff06404af8084b6c463e0@news.povray.org>
>>> Why do bright
Another part of the explanation is the eyelashes of the observer.  They
catch and redistribute small sources of light a lot more than you might
imagine.  I've seen literature on night-time driving simulators which have
explored these problems.
Date: 24 Feb 2003 16:26:51
Message: <3e5a8e1b@news.povray.org>
Hey... now that's something I hadn't thought of...
Thanks!
Andrew
