POV-Ray : Newsgroups : povray.advanced-users : Polygon planarity tolerance Server Time
21 Feb 2025 13:12:17 EST (-0500)
  Polygon planarity tolerance (Message 1 to 10 of 22)
Subject: Polygon planarity tolerance
Date: 22 Dec 2002 12:55:46
Message: <3e05fca2$1@news.povray.org>
POV-Ray requires points in a polygon to be within
ZERO_TOLERANCE of
planarity, otherwise they are not drawn:
file polygon.cpp:
#define ZERO_TOLERANCE 1.0e-10
function Compute_Polygon:
   if (fabs(d) > ZERO_TOLERANCE)
      Set_Flag(Polyg, DEGENERATE_FLAG);
     Warning(0, "Points in polygon are not co-planar.
Ignoring polygons.");
In practice, this usually means that polygons with more than
three
corners have to be defined in a principal plane (one
coordinate =
zero).  Since I use general polygons in my software
(www.shapesoftware.com), POV-Ray often fails to draw them.
Actually, it does not appear that this degree of precision
is
necessary.  I changed the tolerance value to 0.0002 in the
above
instance, and have had no problems - all the polygons draw
OK.
I suggest that either a) the tolerance (in this one place)
be changed
to a more reasonable value, like 0.0002, or b) the user have
the
option of overriding the value.
Eric Dowty
dow### [at] shapesoftwarecom
Subject: Re: Polygon planarity tolerance
Date: 22 Dec 2002 13:06:59
Message: <3e05ff43$1@news.povray.org>
If you know your polygons aren't quite flat can't you just draw them as several
triangles?
I suspect increasing tolerance is a bad idea cause you'll start getting
artefacts under some circumstances. i.e. it worked fine for your purposes but it
might cause problems elsewhere.
Besides, surely triangles render faster because pov has good mesh optimisations?
Tek
http://www.evilsuperbrain.com
Eric Dowty <dow### [at] shapesoftwarecom> wrote in message
news:3e05fca2$1@news.povray.org...
> ZERO_TOLERANCE of
> file polygon.cpp:
> three
> coordinate =
> is
> above
> OK.
> be changed
> the
> Eric Dowty
Date: 22 Dec 2002 13:50:58
Message: <chrishuff-28748E.13455922122002@netplex.aussie.org>
In article <3e05ff43$1@news.povray.org>, "Tek" <tek### [at] evilsuperbraincom>
> optimisations?
Being well-optimized does not mean faster than everything else. The mesh
optimizations are a huge benefit for large meshes, for very small ones
they are mainly overhead, a simple union of triangles can be faster
(though using "hierarchy off" could make the mesh faster again). For a
polygon, the polygon primitive is the best primitive.
If the problem is just that numeric errors cause the points to be
non-coplanar, it would probably be best to just project them to the
right plane in POV. If a non-planar polygon is desired, the polygon
object is just the wrong primitive.
http://tag.povray.org/
Date: 24 Dec 2002 09:55:33
Message: <3e087565@news.povray.org>
points to be
them to the
the polygon
> triangles?
I can get around this problem either by a) converting to
triangles or b) changing the tolerance in POV-Ray. So far, I
have not had any problem with either method.
Nevertheless, it is annoying to have to change methods and
write a new polygon-triangle conversion function, when this
appears to be unnecessary.  Again, I urge POV-Ray designers
to consider an optional variable tolerance, for the
following reasons.
There is no question that the currect tolerance is
unrealistically strict from a mathematical point of view,
when using 8-byte floating-point numbers.  Even if one
starts out with objects that are absolutely planar
(tolerance zero), one or two manipulations (rotation,
intersections, etc.) before input into POV-Ray can result in
violation of the planarity test.  At the least this
tolerance should be increased by a factor of 10.
"non-planar" and "polygons aren't quite flat" are dependent
on the tolerance.  I know that my polygons are planar within
tolerance about 1.0e-04 (my internal tolerance).  Tolerance
of 1.0e-10 is also excessive with respect to resolution of
current raster devices and the human eye.  Should the
tolerance be based on arbitrary machine precision, or
real-world factors?  Other 3D packages such as OpenGL and
QuickDraw3D are able to draw polygons without requiring
planarity within e-10.
Eric Dowty
Date: 24 Dec 2002 18:16:38
Message: <3e08ead6$1@news.povray.org>
In article <3e087565@news.povray.org> , "Eric Dowty"
Since when is POV-Ray a scanline renderer?  As both APIs are implement such
that they turn the polygons into triangles for you they hardly suffer from
degenerate input data.  It is much different for ray-tracing and the
algorithm used to calculate the polygon intersection.  If your modification
works 99% of the time that does not mean it is a good idea, just a
workaround for the degenerate input data.  And fixing your data is really
easy!
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 27 Dec 2002 15:02:38
Message: <3e0cb1dd@news.povray.org>
> triangles?
  Tesselating a free polygon is a problem in itself. If his program does
not support that, and he has concave polygons, implementing a working
tesselation algorithm can be quite laborious.
Date: 27 Dec 2002 15:05:40
Message: <3e0cb294@news.povray.org>
  It's true that OpenGL tesselates to triangles any polygon given to it.
This avoids degeneration problems, but is actually a bad problem with
respect to texturing. I don't know if there's *any* way around this
problem in OpenGL or other (simple) scanline rendering methods.
  The problem is illustrated eg. here:
http://www.cs.tut.fi/~warp/images/uvproblem.gif
Date: 27 Dec 2002 16:29:24
Message: <3e0cc634@news.povray.org>
But isn't that a problem only if no perspective correction takes place?
Or did I interpret the image wrong?
Date: 27 Dec 2002 18:07:59
Message: <3e0cdd4f@news.povray.org>
  What in the image makes you (and 90% of other people as well) think
that that image has something to do with perspective? I can't understand
it.
  There's no perspective nowhere in the drawings. It's purely 2D.
  And even if there would be perspective there (which there isn't), why
would lack of perspective correction cause the artifact depicted there?
Date: 28 Dec 2002 16:40:40
Message: <3e0e1a57@news.povray.org>
> it.
Oh well, so I misinterpreted the drawings. Anyway, IMHO that particular
kind of transformation does imply a perspective; it provides an important
visual cue, as is seen in various illusions, such as here:
http://www.optillusions.com/dp/files/1-36.gif
And, although it is of course possible to map a texture like that, I'm not
sure how common or useful it is.
Well, a triangle texture mapper without perspective correction interpolates
linearly both in screen space and in texture space, and produces the
artifact. This obviously isn't how perspective works - to produce the
correct output, the mapper needs to interpolate inlinearly based on the
triangle vertices' z coordinates. The artifact can be clearly seen in some
old games such as Tomb Raider 2 or I-War, when run with software rendering.
