POV-Ray : Newsgroups : povray.advanced-users : Polygon planarity tolerance Server Time
17 May 2026 21:10:45 EDT (-0400)
  Polygon planarity tolerance (Message 21 to 22 of 22)
Subject: Re: Polygon planarity tolerance
Date: 31 Dec 2002 20:07:48
Message: <3e123f64@news.povray.org>
Johannes Dahlstrom <sad### [at] tkukoulufi> wrote:
> You could put some evenly-spaced horizontal lines to the texture - they
> would make a difference between the two cases: In the case B the mapping
> wouldn't change their mutual distances, whereas in the case A it obviously
> would (the lines "farther away" would be closer to each other).
  What are the cases A and B you are talking about?
Date: 31 Dec 2002 20:16:29
Message: <3e12416d@news.povray.org>
I was referring (a bit unclearly) to my previous message - case B is what
you want, ie. the trapezoidal, non-tilted quad, and case A is the one with
perspective.
