POV-Ray : Newsgroups : povray.advanced-users : Polygon planarity tolerance Server Time
17 May 2026 19:54:00 EDT (-0400)
  Polygon planarity tolerance (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Polygon planarity tolerance
Date: 28 Dec 2002 18:20:35
Message: <3e0e31c3@news.povray.org>
Johannes Dahlstrom <sad### [at] tkukoulufi> wrote:
> Oh well, so I misinterpreted the drawings. Anyway, IMHO that particular
> kind of transformation does imply a perspective; it provides an important
> visual cue, as is seen in various illusions, such as here:
  I don't follow you. Which transformation are you talking about? Why
do you keep talking about perspective when there's no perspective involved
anywhere in the drawings?
  The problem is simple: Take a four-sided polygon which is not
rectangular (but eg. trapezoidal as in the illustration), apply
UV-coordinates to the vertices of this polygon so that they map a
rectangle on the texture, and feed this to the OpenGL API.
  What OpenGL does is to divide the polygon into two triangles. Then the
3D hardware draws these two triangles independently, causing the deformation
of the texture depicted in the illustration.
  There's no perspective anywhere. There are no transformations anywhere.
> And, although it is of course possible to map a texture like that, I'm not
> sure how common or useful it is.
  You seem to misunderstand the problem completely.
  Of course it's very common to build a surface using quadrilaterals
(ie. polygons of four sides). For example if you build a torus with
quadrilaterals, you'll get the depicted problem with the texturing
(at the top and bottom of the torus).
> Well, a triangle texture mapper without perspective correction interpolates
> linearly both in screen space and in texture space, and produces the
> artifact.
  What is "the artifact"?
  Yes, it produces *an* artifact, which is completely different from what
is depicted in my illustration.
  In fact, even if that polygon was _rectangular_ and drawn in perspective
and even if it was made _without_ perspective correction, there would be
no visible artifact due to the texture in question. There would be a visible
artifact if the texture had horizontal lines (in which case they would be
mapped at equal distances throughout the polygon instead of decreasing
distance due to perspective).
Date: 29 Dec 2002 07:56:25
Message: <3e0ef0f9@news.povray.org>
Warp wrote:
>   What in the image makes you (and 90% of other people as well) think
> that that image has something to do with perspective? I can't understand
> it.
I'am guilty, too.
>   There's no perspective nowhere in the drawings. It's purely 2D.
Now I get it!
Never thought of this problem before...
Sebastian H.
Date: 29 Dec 2002 11:54:07
Message: <3e0f28ae@news.povray.org>
Sorry, bad choice of word from my part, "mapping" would have been more
adequate. What I meant was that there are two ways to interpret your
drawing: Either
A) there is a tilted rectangular quad, or
B) there is a non-tilted trapezoidal quad.
It is simply impossible to know which is the correct way to interpret it
from the drawing only, without some depth information. The converging
lines, however, give a visual cue which would suggest the case A. Human
brains simply are wired that way, and this phenomenom is utilized in the
illusion I posted a link to in my previous message.
> deformation of the texture depicted in the illustration.
But my point was that it is impossible to see it from the drawing. I did
some experiments with OpenGL, and the results are here:
http://koti.mbnet.fi/~sharlin/with_pc.png
http://koti.mbnet.fi/~sharlin/without_pc.png
Without perspective correction (the second image) and without resorting to
the texts, can you tell case A from case B? I don't think so. The texture
mapper doesn't make a difference between them, because it isn't conserned
about depth information if it doesn't do perspective correction.
OK, I see that with such round shapes it can be a problem. My bad.
Erm, no. As you can see from the aforementioned images, without perspective
correction the two cases have the exactly same artifact, caused by exactly
same thing: linear interpolation in texture space. Perspective correction
does what it's meant to do: renders the perspective correctly. If it
wouldn't, most 3D games would look very very ugly.
Date: 29 Dec 2002 13:47:12
Message: <3e0f4330@news.povray.org>
> drawing: Either
  I see.
  Do you have any idea how that drawing should be done so that it doesn't
cause confusion?
  But the artifact which I'm talking about has nothing to do with perspective
correction, and using perspective correction does not affect the artifact
in question: It will still be there regardless of PC.
  There actually exists an algorithm to handle this problem, but I have never
heard that any 3D hardware supports this algorithm. The principle of the
algorithm is to perform a more complicated texture mapping.
Date: 29 Dec 2002 14:00:42
Message: <3E0F45E7.A08FB475@pacbell.net>
> > drawing: Either
>   I see.
> cause confusion?
I can think of at least three -
1. Title it as a trapezoid.
2. Make the top length a bit shorter.
3. Draw a thick lined rectangle around the illustration.
Ken Tyler
Date: 30 Dec 2002 05:45:02
Message: <3e1023ae$1@news.povray.org>
Shouldn't the distance between the coordinates of the texture be in
proportion to the coordinates in the polygon?
news:3e0f4330@news.povray.org...
> > drawing: Either
>   I see.
> cause confusion?
Date: 30 Dec 2002 08:04:42
Message: <3e104469@news.povray.org>
  Why should it?
Date: 30 Dec 2002 14:15:16
Message: <3e109b44$1@news.povray.org>
news:3e104469@news.povray.org...
>   Why should it?
Isn't the idea to just lay a bitmap across a face?
What you're asking OpenGL to do is reshape the bitmap, something I doubt it
was designed for.
Date: 30 Dec 2002 15:58:03
Message: <3e10b35a@news.povray.org>
> was designed for.
  Well, if you do it with a triangle, it works flawlessly. The texture
will be stretched correctly.
Date: 31 Dec 2002 20:01:45
Message: <3e123df8@news.povray.org>
> cause confusion?
You could put some evenly-spaced horizontal lines to the texture - they
would make a difference between the two cases: In the case B the mapping
wouldn't change their mutual distances, whereas in the case A it obviously
would (the lines "farther away" would be closer to each other).
