POV-Ray : Newsgroups : povray.advanced-users : Help needed! Forest memory problems Server Time
10 Jun 2026 00:45:41 EDT (-0400)
  Help needed! Forest memory problems (Message 21 to 30 of 31)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Help needed! Forest memory problems - I give up!
Date: 20 Dec 2002 06:39:16
Message: <3e030164$1@news.povray.org>
Hmm... my code doesn't quite look like that. I do this:
#declare Mesh = #include "mesh.inc"
#declare Forest =
    union {
        #local nTree = 0;
        #while (nTree < 8000)
            object { Mesh transform { ... } }
            #local nTree = nTree + 1;
The union couldn't cause problems could it?
BTW, the file definitely has only one mesh in.
Tek
http://www.evilsuperbrain.com
news:3E02E100.EC7FEB26@gmx.de...
> Tek wrote:
> > Yep, I tried that too. It took most of last evening to rewrite the
> > transformation code, but once I had it still had all the same problems
as
> > when it had been 1 mesh per leaf. My foliage include is just a 5 meg
mesh.
> If your code looks like:
> #declare Mesh= mesh { ... }
> object { Mesh ... }
> object { Mesh ... }
> this should work.
> If you have the mesh written to a file you should make sure it really
> contains a single mesh.
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
> Last updated 07 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 20 Dec 2002 06:44:45
Message: <3i060vchcpflhhhkq5vn7n55agm7fvgdsf@4ax.com>
On Fri, 20 Dec 2002 11:39:16 -0000, "Tek" <tek### [at] evilsuperbraincom> wrote:
just for sure, between 'mesh{' and '}' ?
ABX
Date: 20 Dec 2002 06:55:45
Message: <3e030541$1@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:3i060vchcpflhhhkq5vn7n55agm7fvgdsf@4ax.com...
The file is just:
mesh{
triangle{ ...}
triangle{ ...}
. //several thousand triangles
triangle{ ...}
triangle{ ...}
texture { txtLeaf }
BTW, for what it's worth I've come up with some good looking flat trees, so
I will be able to finish my image. But I still want to work out why the mesh
ones wouldn't work!
Thanks for helping with this, guys. Keep it coming :)
Tek
Date: 20 Dec 2002 07:42:04
Message: <3E03101C.C39DAD00@gmx.de>
> #declare Forest =
>     union {
>         #local nTree = 0;
>         #end
Well, if it does not work i would try dropping the union.  As i said the
code i suggested has proven to work in many cases.
Date: 20 Dec 2002 13:56:00
Message: <3e0367c0$1@news.povray.org>
> object { Mesh ... }
> object { Mesh ... }
> this should work.
Can one do
#declare Meshtrunk=mesh { ... }
#declare Meshleaf=mesh { ... }
object {Meshtrunk transform foobar1}
object {Meshtrunk transform foobar2}
object {Meshtrunk transform foobar3}
object {Meshleaf transform foobar1}
object {Meshleaf transform foobar2}
object {Meshleaf transform foobar3}
and get the benefit?
Date: 20 Dec 2002 14:59:46
Message: <3E0376B0.D806F52C@gmx.de>
"Greg M. Johnson" wrote:
> Can one do
Of course, and this makes a lot of sense if Meshleaf and Meshtrunk have
different textures because making them one mesh would require texturing
the individual triangles which would cost more memory.
Concerning render speed one large mesh of course renders faster than
several small ones.
Date: 20 Dec 2002 18:47:22
Message: <3e03ac0a@news.povray.org>
oops! Why isn't POV-Ray doing this yet? Or maybe it already does? Hmmm... I
think I'm a bit confused here  :-)
Date: 20 Dec 2002 22:14:31
Message: <3e03dc97$1@news.povray.org>
news:3e030164$1@news.povray.org...
> #declare Forest =
>     union {
>         #local nTree = 0;
>         #end
Is the problem in the way you're re-including the file each time.
**I** would do it this way:
Have a "mesh.inc" which does a
    #declare TREE= mesh{....}
Then in your main file at the beginning have a single
#include"mesh.inc"
then in your macro say object{TREE transform{...}}
I don't know of a design benefit for calling it the way you do....
Date: 20 Dec 2002 22:42:19
Message: <3e03e31b@news.povray.org>
Greg M. Johnson <gregj:-)56590@ao:-)l.com> wrote in message
news:3e03dc97$1@news.povray.org...
There's no design benefit, I was just working with the way that maketree was
originally written. It would be simple to change but I didn't think it would
make any difference.
I don't think there's any difference since I belive #include literally inserts
the contents of the given file at the point where it's invoked.
Tek
Date: 20 Dec 2002 23:36:44
Message: <chrishuff-BEB8B3.23310120122002@netplex.aussie.org>
In article <3e03dc97$1@news.povray.org>,
His code only includes the file once. Maybe you misunderstand the
#declare statement (it does not act like the C #define statement) or
meant something else...
http://tag.povray.org/
