POV-Ray : Newsgroups : povray.advanced-users : Help needed! Forest memory problems Server Time
17 May 2026 21:32:09 EDT (-0400)
  Help needed! Forest memory problems (Message 12 to 21 of 31)
Subject: Re: Help needed! Forest memory problems - I give up!
Date: 19 Dec 2002 17:39:33
Message: <3e024aa5$1@news.povray.org>
In article <3e024622@news.povray.org> , "Tek" <tek### [at] evilsuperbraincom>
wrote:
> If anyone can show me some source that duplicates a complicated mesh (5MB .inc
> file)
Simple: Declare it once, then (re)use it via the "object" statement.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 19 Dec 2002 18:15:47
Message: <3e025323@news.povray.org>
Nope, did that. It substantially reduced the memory, but it still couldn't
handle 8000.
Tek
http://www.evilsuperbrain.com
Thorsten Froehlich <tho### [at] trfde> wrote in message
news:3e024aa5$1@news.povray.org...
.inc
> > file)
>     Thorsten
> Thorsten Froehlich
Date: 19 Dec 2002 18:56:19
Message: <3e025ca3$1@news.povray.org>
In article <3e025323@news.povray.org> , "Tek" <tek### [at] evilsuperbraincom>
> handle 8000.
Hmm, would you be willing to make the scene available somewhere?
    Thorsten
e-mail: tho### [at] trfde
Date: 19 Dec 2002 20:08:52
Message: <3e026da4@news.povray.org>
Well I no longer have the code that didn't work, plus I'm not sure how Gilles
would feel about me distributing my modified version of his code. But you might
want to try this:
If you have maketree you can probably recreate my problem using the second
example tree (extree2.pov), provided you don't use the branches ('cause they're
not meshes).
Set it to output files (dofile = true), then run it so it produces 3 files.
Create a new scene that declares an object as:
#declare tree = #include "gtfoliage2.inc"
And then try placing 8000 instances of that object in a loop. In theory you
should experience the same difficulties I do, though if not I'd be interested to
know because it would indicate some other problem in my scene.
Tek
news:3e025ca3$1@news.povray.org...
> > handle 8000.
>     Thorsten
Date: 20 Dec 2002 02:59:39
Message: <dbj50vgurcq3sniiuf7993lhikk33aesmf@4ax.com>
On Thu, 19 Dec 2002 23:15:11 -0000, "Tek" <tek### [at] evilsuperbraincom> wrote:
> handle 8000.
Are you sure you did not used this that way:
#macro MyMesh()
  #include "mesh_definition.inc"
object{ MyMesh() }
object{ MyMesh() transform{ Somehow } }
ABX
Date: 20 Dec 2002 03:30:56
Message: <3E02D541.9ED0828F@gmx.de>
> want to try this:
> not meshes).
If you do that with an unmodified maketree you get one mesh for every leaf
and 'tree' is a union of several thousand meshes.  Using that several
times will require at least the memory for the transformation matrices for
each mesh so you won't save much.  The trick is to put all leaves in *one*
mesh.  This involves some modification of the code, you have to transform
the vertices of the leaf instead of the leaf itself.
Last updated 07 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 20 Dec 2002 03:56:37
Message: <3e02db45@news.povray.org>
Yep, I tried that too. It took most of last evening to rewrite the
transformation code, but once I had it still had all the same problems as
when it had been 1 mesh per leaf. My foliage include is just a 5 meg mesh.
Though my rewrite of the branch code works fine, so if I want lots of bare
trees there's no problem. :(
Tek
news:3E02D541.9ED0828F@gmx.de...
Gilles
you might
> > want to try this:
second
they're
> > not meshes).
files.
you
interested to
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Date: 20 Dec 2002 03:57:59
Message: <3e02db97$1@news.povray.org>
No it's definitely:
#declare MyMesh = #include "mesh.inc"
object { MyMesh transform }
Tek
"ABX" <abx### [at] abxartpl> wrote in message
news:dbj50vgurcq3sniiuf7993lhikk33aesmf@4ax.com...
couldn't
> > handle 8000.
> #macro MyMesh()
> #end
> object{ MyMesh() }
> ABX
Date: 20 Dec 2002 04:21:07
Message: <3E02E100.EC7FEB26@gmx.de>
If your code looks like:
#declare Mesh= mesh { ... }
object { Mesh ... }
object { Mesh ... }
this should work.
If you have the mesh written to a file you should make sure it really
contains a single mesh.
Date: 20 Dec 2002 06:39:16
Message: <3e030164$1@news.povray.org>
Hmm... my code doesn't quite look like that. I do this:
#declare Mesh = #include "mesh.inc"
#declare Forest =
    union {
        #local nTree = 0;
        #while (nTree < 8000)
            object { Mesh transform { ... } }
            #local nTree = nTree + 1;
The union couldn't cause problems could it?
BTW, the file definitely has only one mesh in.
Tek
news:3E02E100.EC7FEB26@gmx.de...
as
mesh.
> object { Mesh ... }
> object { Mesh ... }
> this should work.
> Christoph
