Is there any way I can use an array in a heightfield directly. I have
been modifying the array, saving it as a text file, converting it to a
TGA using ASC2TGA then using the heightfield normally. After that
repeating the steps.
Thanks in advance.
On Fri, 22 Nov 2002 14:27:54 GMT, mca### [at] aol com com (Stephen McAvoy) wrote:
I'm sure you can start loop along array and create (optionally smooth) mesh.
ABX
Subject: Re: Heightfield and arrays question.
Date: 22 Nov 2002 11:02:07
Message: <3DDE54FF.EE084F94@gmx.de>
You can create a mesh like ABX suggested or write an ascii pgm file using
the POV-Ray file writing routines, this would avoid the need to start a
separate program.
Last updated 15 Nov. 2002 _____./\/^>_*_<^\/\.______
On Fri, 22 Nov 2002 17:02:07 +0100, Christoph Hormann
>separate program.
>Christoph
Thanks Christoph, this looks like the easiest way for me to go. Your
site is interesting maybe too interesting, if I want to get anything
of my own done.
