POV-Ray : Newsgroups : povray.advanced-users : Re: mesh compressor settings for batch Server Time
13 Oct 2025 09:14:39 EDT (-0400)
  Re: mesh compressor settings for batch (Message 1 to 2 of 2)
Subject: Re: mesh compressor settings for batch
Date: 7 Nov 2002 10:48:37
Message: <3dca8b55@news.povray.org>
S <sha### [at] nocannedhamactivech> wrote:
> what would the command line string for Warp's mesh compressor to handle a
> bunch of inc files?
> "C:\meshcomp *.inc *.pcm"         would be the direction of what I need.
> Compress a directory full of mesh include files.
  The program supports converting just one file at a time. If you want
to automatize converting several files, you'll have to resort to any tools
your OS offers you.
  In a Unix shell it would be a command like this:
for F in *.inc; do meshcomp $F $F.pcm; done
(of if you don't like the files named in the form 'file.inc.pcm' but would
like them to be named like 'file.pcm', you'll have to use a bit more
complicated command, like:
for F in *.inc; do meshcomp $F `basename $F .inc`.pcm; done
  However, from your question I deduce that you are using Windows. If you
have the command-line version of the program, you can do something like this
in the DOS-prompt:
for %%F in (*.inc) do meshcomp %%F %%F.pcm
(It will create files with the form 'file.inc.pcm', and I don't know if
it can be made to create them otherwise.)
Date: 8 Nov 2002 00:22:09
Message: <3dcb4a01@news.povray.org>
Warp,
Thanks, have forgotten about good DOS tricks.  Appreciate it.
Shaw
