Has anyone ever seen that funky transparent plastic that turns rainbow
colours when you try to bend it?
1) does anyone know how this stuff works?
2) can it be simulated with POV-Ray?
Andrew.
In article <3dbbc275@news.povray.org>,
I don't know what you are talking about. Does it look like it gets many
tiny cracks in it? Or does it just get an iridescent oil-film look?
One possibility is microscopic cracks that form a diffraction grating,
like a CD. You might be able to simulate it with a normal of some kind
and dispersion.
Another possibility is a more complex effect having to do with
polarization...put cellophane or some other plastic between two
polarizing filters for an example. I've seen this effect on things like
CD jewel cases as well. You might want to look at the "irid" iridescence
feature, it is a fast way to simulate the "oil film" or "mother of
pearl" look.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
Right, well, I suppose I was a bit vague...
I visited the London Science Museum one time... They had this plastic stuff.
Apparently they make scale models of bridges and stuff out of it to analyse
stress. Coz, the thing is, when you view it through this clear plastic sheet
(which probably polarises or something), and when you bend it, the most
stressed parts show up rainbow colours. (The lightsource might be "special"
too - it was in a dark room.)
Andrew.
In article <3dbc5044@news.povray.org>,
There was probably a polarizing filter over the light source. POV can't
simulate this effect, but the irid feature might come close to looking
the same.
The effect is called photoelesticity, whereby the optical axis of a
material changes depending on the mechanical stress applied to it.
It's as if each part of the material is a piece of polaroid, but its
axis of polarization changes according to how much that part is under
stress.
You get the coloured effect when you put the material between crossed
polarizers. Look, for example, at:
http://technology.open.ac.uk/materials/mem/mem-photo.html
I guess it's the same kind of problem as in the polarization thread. A
lot of work!
Kaveh
Yep, this indeed appears to be the effect I saw. But of course, POV-Ray
doesn't do polarisation. (I can imagine why!) Oh well, never mind...
Andrew.
I am not an expert in povray, but you know, it shouldn't be difficult to
add in polarization. Not compared to the amazing things it does already!
I would love to see it some time.
Kaveh
In article <1fkqkvf.knzuo218fc70cN%kaveh@delete_this.focalimage.com>,
It would be very difficult and complex. It would basically require
changing the entire way colors are handled, storing information on the
amount of light of each color at each polarization angle, to do it well
would probably require using frequency distributions to describe light
color...building a raytracer from scratch with these features would be
far easier than adding it to POV.
Funny that you should mention this now.
I posted such an image a few days ago to
a photo forum here in Norway.
Here's that image:
http://foto.no/cgi-bin/bildekritikk/vis_bilde.cgi?id=49527
I shot the image here in my living room
about a year ago (IIRC) with a macro lens,
a halogen reading lamp and two polarizing
camera filters (one in front of the lamp
and one on the lens.)
Tor Olav
Well, I said I wasn't an expert. A little knowledge is a dangerous
thing. ;-)
Kaveh
