POV-Ray : Newsgroups : povray.advanced-users : Simulating calcite(Calcium carbonate), typical birefringent crystal Server Time
17 May 2026 18:45:43 EDT (-0400)
  Simulating calcite(Calcium carbonate), typical birefringent crystal (Message 1 to 10 of 10)
Subject: Simulating calcite(Calcium carbonate), typical birefringent crystal
Date: 25 Oct 2002 02:41:45
Message: <3db8e7a9@news.povray.org>
I might not have posted on a proper group. If I should have chosen the
povray.newusers, please don't hesitate to tell me as such.
Well, since I am still not very much acquainted with the POV-ray yet, I am
not sure whether this topic is rather absurd or not.
When a calcite crystal is laid on a page of newspaper, the characters would
form double images. The refractive indices of the clacite crystal are 1.6584
and 1.4864(n0 and ne, respectively)["Optics",p.337, Hecht]
Would it be possible with some effort to simulate this phenomena for
birefringent materials in the POV-ray 3.5?
Are there any such programs to support this function other than POV?
Thank you for your interest in this regard,
Jong
Subject: Re: Simulating calcite(Calcium carbonate), typical birefringent crystal
Date: 25 Oct 2002 04:13:40
Message: <3DB8FD33.E1289495@gmx.de>
That depends on the level of realism you want.  Birefringence is an effect
related to the polarization of light and a complete support for all
important effects related to polarization would require quite elementary
changes to POV-Ray.
If you however only want the optical effect of birefringent materials on
unpolarized light you could probably achieve this by a not that
complicated modification of the refraction code.  You would however
somehow have to define the orientation of the crystal, probably as a new
interior property.
Not that i know of.
Date: 25 Oct 2002 04:37:10
Message: <3db902b6@news.povray.org>
Dear Christoph,
 I really appreciate your support.  I am relieved to know that it might be
possible when using non-polarized light source.
What I would like to do is that the raytracing( if possible photon-mapping
included) of some (several to 20) cylindrical almost-transparent objects
parallel each other, or perpendicular, on a some simple plane like a
blackboard with the non-polarized light source.
My question then is this(level of difficulty):
Do I have to write a macro or function in this case(I might have to learn
quite a lot, a month or two, though)?
 Or do I have to 'code' some source of the POV(well, I don't think I have
the ability to do so).
Thank you again,
Jong
news:3DB8FD33.E1289495@gmx.de...
would
1.6584
> changes to POV-Ray.
> interior property.
> Not that i know of.
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
Date: 25 Oct 2002 11:04:00
Message: <3DB95D60.527123F6@gmx.de>
You will have to, there is no way achieving this from POV-Ray scripts.
Date: 25 Oct 2002 11:20:46
Message: <3DB96172.8040607@irrwerk.de>
Maybe there's a simple workaround. If you calculate two images.
One with ior 1.6584 of the interior of the crystal and another
with the other ior of 1.4864. And than combine this images in photoshop
or similar programs.
It's not fully simulation, but...
SciBorg
Date: 25 Oct 2002 19:23:09
Message: <chrishuff-069DBA.19162925102002@netplex.aussie.org>
In article <3DB95D60.527123F6@gmx.de>,
You could get something almost like it, with an average texture with two
slightly different gradient normals. True simulation requires modifying
the source code, though.
http://tag.povray.org/
Date: 27 Oct 2002 05:10:38
Message: <3dbbbb9e$1@news.povray.org>
Once again, cheers to POV-Ray TAG and supporting members.
  I myself was not able to figure how much effort should be needed to
implement the Double Refraction or birefringent material simulation.
Now, it seems to me that the simulation may well require team effort or some
sort of 2003(or 2004?) Siggraph presentation type effort.
I really appreciate your interest and suggestions.
Jong
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 27 Oct 2002 10:20:08
Message: <chrishuff-71386C.10124027102002@netplex.aussie.org>
In article <3dbbbb9e$1@news.povray.org>, "Jong" <jjk### [at] mmewhaackr>
Just to do double refraction wouldn't require much effort at all. (the
dispersion feature already does a kind of multiple refraction, for
example)
Making it direction dependant would be harder, but not too bad.
Simulating the other polarization effects would be quite difficult. The
thing is, it is just very special-case...you aren't going to find many
people interested in it.
Date: 29 Oct 2002 07:57:00
Message: <3dbe859c@news.povray.org>
That's right. That would be needed by some limited number of users. I guess
very small number of users in the gem-related field or ...
Thank you so much for the valuable insights and tips.
Jong
some
> example)
Date: 7 Nov 2002 02:00:16
Message: <web.3dca0c0e70cabf85b2769afa0@news.povray.org>
>example)
Hmmm... Polarized light might be an idea for a feature to add. I've seen
some interesting effects as a result of using polarized light; things like
sticky tape can look really beautiful when viewed using polarized light.
Maybe it could be added to POV, but as you just said, it would be too
difficult to bother with.
Rohan _e_ii
