POV-Ray : Newsgroups : povray.advanced-users : Constrained motion Server Time
17 May 2026 22:42:18 EDT (-0400)
  Constrained motion (Message 11 to 11 of 11)
Subject: Re: Constrained motion
Date: 4 Oct 2002 14:48:23
Message: <3d9de277@news.povray.org>
OK peeps, just trying to pull my thoughts together here... I'm going to sum
up which (I think!) has been said so far, as I understand it, so folks can
tell me if I've got it right!
Motion constrained to the X-Y plane:
  * Compute the resultant force acting on the particle as normal.
  * Set the Z-part to zero.
  * Compute motion as normal.
Motion constrained to a sphere:
  * Compute resultant force.
  * Constrain the force to a plane perpendicular to the string tethering the
particle.
  * Work out how far the particle has moved.
  * Rotate the particle from it's initial position so that it moves the same
amount.
About that last step... I know how to work out the distance the particle has
moved... How do I work out how far to rotate? Angle = distance / radius or
something?
Andrew.
