POV-Ray : Newsgroups : povray.advanced-users : Inverse Square Law Server Time
15 Jun 2026 07:04:20 EDT (-0400)
  Inverse Square Law (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Inverse Square Law
Date: 28 Sep 2002 18:31:36
Message: <3d962dc8$1@news.povray.org>
In article <3d95a3fe@news.povray.org>, orp### [at] btinternetcom says...
> But hang on... wouldn't that mean that the way the force drops off as we
> move away from Q is dependent on our units of measurement?
No.
> Suppose P is 1
> meter from Q. Then we have S / 1 * 1 = S.
When solving physical equations ALWAYS put in the units, instead of just
the numbers.
We now have S / (1m * 1m) = S*1 m^-2 = S*100cm-^2 etcpp.
If you want the force, you probably want it in Newton, that is
1N = 1kg*1m*1sek^-2.
If you use cemtimeters instead of meters when calculating the force your
result will be the same force, but it's unit won't be Newton. If you
convert it to Newton, it will be the same as if you put in meters in the
first place.
> By the way... is the force excerted by a *real* magnet dependent
> on the mass of the magnetic ball?
No, the force will be the same, but not the acceleration of the ball
(since a=F/m).
Lutz-Peter
Date: 28 Sep 2002 18:56:41
Message: <3d9633a9$1@news.povray.org>
In article <3d95c51c@news.povray.org>, jim### [at] blueyondercouk says...
> Also for the point charge thing there is a very simple equation (which
> totally escapes me at the mo) but I try a web search for "coulombs law"
F = -1/(4*Pi*Epsilon_0) * q*Q/r^2
q,Q are the charges of the balls
Epsilon_0 is a physical constant (8.854 * 10^-12 kg*m^3/(s^2*C^2))
r is the distance between the centers of the two balls.
Lutz-Peter
Date: 29 Sep 2002 06:34:01
Message: <3d96d719@news.povray.org>
Thankyou to all the people who replied ;-)
This is turning out to be *much* harder than I thought... Currently, the
ball approaches on of the magnets, accelerates to implausibly heigh speed,
and then ends up so far away from the magnets that is just demonstrates
Newton's 1st - it travels in a straight line forever. Bum!
Well anyway, at this point it was about 9pm, so I gave up and sulked off to
read a book instead. I haven't tried it again in light of the latest posts -
hopefully I might actually get somewhere! Well let folks know once I work
out exactly what's happening and can ask more *specific* questions.
Weary Andrew.
Date: 29 Sep 2002 06:38:53
Message: <3d96d83d@news.povray.org>
Isn't that the same as F = -r^2 / (4 * Pi * Epsilon_0 * q * Q)?
I'm with you. (I think...)
So... 8.854e-12 is the number... kg*m^3 is the unit... what's the s^2 * C^2
bit about?
Andrew.
Date: 29 Sep 2002 07:43:01
Message: <3d96e745$1@news.povray.org>
In article <3d96d83d@news.povray.org>, orp### [at] btinternetcom says...
Hu? No (beware: y/x*z = y*z/x and not =y/(x*z)).
> bit about?
s^2 * C^2 also belongs to the unit (s: seconds, C: Coloumb).
Lutz-Peter
Date: 29 Sep 2002 08:00:18
Message: <3d96eb52@news.povray.org>
"Lutz-Peter Hooge" <lpv### [at] gmxde> wrote in message
news:3d96e745$1@news.povray.org...
Are you beginning to see why my math doesn't work? <sob!>
C^2
> > bit about?
Right... So if I let q and Q be the charge of my ball and magnet (what's the
correct unit for charge?), and I measure r in meters, then F will come out
in Netwons? While we're on the subject, what would be a suitable range of
magnitude for q and Q? (The ball is 80g in mass.)
Thanks!
Andrew.
Date: 29 Sep 2002 10:40:16
Message: <3d9710d0@news.povray.org>
  The closer you get to a physically correct model, the more
real-life problems you will encounter.
  Orbits caused by gravitational or magnetic forces are very very
unstable. Even the slightest difference in a stable orbit can make it
unstable and the orbiting object will most probably be ejected away
(unless you have modelled object collision as well, and the orbiting object
happens to fall into the other object :) ).
  (So how come the planets and moons in our solar system are in so nice
stable orbits? Because from the millions and millions of objects very long
time ago floating around the forming Sun, these particular objects happened
to be, by chance, in the right places at the right times and survived. All
the other objects either collided with these or were ejected from the solar
system.)
Date: 29 Sep 2002 10:55:17
Message: <3d971455$1@news.povray.org>
In article <3d9710d0@news.povray.org>, war### [at] tagpovrayorg says...
> unstable.
This is only true for systems with three or more bodies.
A system of two bodies will always be stable I think (in real life, a
simulation of it may be unstable, especially if computed using the Euler
algorithm).
Lutz-Peter
Date: 29 Sep 2002 11:09:15
Message: <3d97179b@news.povray.org>
> algorithm).
  It may depend on how "stable" is defined.
  I think that an orbit is defined to be stable when the orbiting body
has a permanent and well-defined orbit around the other object
(that is, it will never collide with the other object nor it will be
ejected to infinity).
  In this sense it's perfectly possible to have an unstable orbit in
a two-body system (eg. simply by having them in collision course; it's
also possible that they will escape to infinity with respect to each other
if the minimum escaping speed is reached).
  Perhaps you confused this with the fact that a two-body
system can be modelled analytically while a three-(and higher) body
system cannot (but must be approximated numerically)?
Date: 29 Sep 2002 11:22:49
Message: <3d971ac9$1@news.povray.org>
In article <3d97179b@news.povray.org>, war### [at] tagpovrayorg says...
But then it is no orbit at all. Of course it can collide, or escape to
infty, but if it orbits at all, it will orbit forever (that is what I
mean with stable).
Lutz-Peter
