POV-Ray : Newsgroups : povray.advanced-users : Random variation Server Time
18 May 2026 00:00:31 EDT (-0400)
  Random variation (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Random variation
Date: 26 Sep 2002 14:59:00
Message: <chrishuff-DAA116.14561326092002@netplex.aussie.org>
In article <3D93329F.A5E1E5C4@gmx.de>,
 Christoph Hormann <chr### [at] gmxde> wrote:
> Hmm, i'm not sure.  If it is possible that two consecutive occur in a
> sequence of random numbers what is the probability of this event?
Ideally, just as likely as any other single combination. That is, not
very likely with this large of a large set of possible combinations.
Say you have 2 (identical) dice. Is the 1:1 combination less likely than
the 1:4 combination?
> In fact i don't even know if mathematics deal with something like non
> integer random numbers.
It does, it doesn't matter if it is integer or not, as long as it is a
set of specific values. There is a finite number of values that can be
represented with a double precision variable, with a perfect random
number generator any one of those values would be equally likely,
whether or not it had just come up the previous time. Assuming the
values are evenly spaced, that is...I think. It depends on how you look
at it and what exactly you want, I guess.
Ok, IANAM (I Am Not A Mathematician), and have never taken a statistics
or set theory course, but:
Picking a random value from a finite set, each value has an equal chance
of coming up, even if it was the previous value.
A perfect random number generator would produce a flat distribution, any
range of resulting values would on average be hit the same number of
times as any other range of equal length. You will get the same number
of values in the range [0, 0.1] as in [0.5, 0.6] and [0.9, 1]. (on
average of course)
I do not think all possible values a double can hold in the [0, 1] range
are evenly distributed...it is probably close enough though. If the
distribution is off, say there are twice as many values in the lower
half of the range then in the upper half, a specific value in the lower
half will have to be less likely than a specific value in the upper half
if you want to keep a flat distribution. However, POV creates a
pseudo-random integer value and scales it down to the right range, so
they are evenly spaced as well as a double value can approximate and the
generator can generate.
BTW, the algorithm POV uses to compute the next random number is:
  next_rand[stream] = next_rand[stream] * 1812433253L + 12345L;
  return((DBL)(next_rand[stream] & 0xFFFFFFFFUL) / 0xFFFFFFFFUL);
The seed() function sets the initial value of next_rand and returns the
stream index.
http://tag.povray.org/
Date: 26 Sep 2002 15:30:22
Message: <3D93604D.4292E793@gmx.de>
All right, but mathematics don't care about double precision so since
there is an infinite number of real numbers between 0 and 1...
Date: 26 Sep 2002 15:32:23
Message: <3d9360c7$1@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
Really one die thrown twice might be a better example. Otherwise 4:1 would
be considered along with 1:4.
 -Shay
Date: 26 Sep 2002 15:43:49
Message: <3d936375$1@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote in message
news:3D93604D.4292E793@gmx.de...
Would this matter? The second hand of a clock points in an infinite number
of directions, but also moves in infinitely small increments, so at some
point each minute the second hand is pointing exactly at the center of the
12 on the clock. It spends as much time in this position as in every other
(infinite) position on the clock.
 -Shay
Date: 26 Sep 2002 15:55:39
Message: <3D93663B.471DD47E@gmx.de>
> Would this matter? [...]
Yes, this means the chance that two consecutive random numbers have
exactly the same value is infinitely small.
Date: 26 Sep 2002 16:01:09
Message: <3d936785$1@news.povray.org>
news:3D93663B.471DD47E@gmx.de...
...and equal to any other sequence. I think that we are all agreeing with
each other.
 -Shay
Date: 26 Sep 2002 16:05:04
Message: <3d93677c.99183057@news.povray.org>
On Thu, 26 Sep 2002 14:56:13 -0400, Christopher James Huff
Yes. Given that the two dice are identical you can't tell the
difference between 1:4 and 4:1, thus 4:1 is twice as likely to occur
as 1:1. If we change the premise so we only have one dice that we roll
twice 1:4 is as likely to occur as 1:1, now we've given value to the
order (1:4 <> 4:1). If you really want fun with permutations, try to
calculate the cumulative odds on a slot machine. I once attempted that
for a simulated slot machine I programmed, I ended up fiddling the
values until emparative testing showed the desired return rate (or
close enough) instead.
/Erkki
Date: 26 Sep 2002 16:11:48
Message: <chrishuff-FF433B.16091526092002@netplex.aussie.org>
In article <3D93604D.4292E793@gmx.de>,
What branch of mathematics are you thinking of? Computer science is
largely mathematics, and definitely does care. Finite binary
representations of numeric values may not matter in the abstract
concepts of mathematics, but those concepts do deal with the same
situations.
> so since there is an infinite number of real numbers between 0 and
> 1...
A specific value still has the same chance of coming up. It doesn't
matter if it has already come up the previous time, or the previous 10
times. Um...I really don't know how to express this, I haven't taken any
classes in it or done much research on my own. The probability seems to
be 0 but is obviously not 0, and I thought things like the term
"infinitesimal" weren't used any more. How about: as the size of the set
(n) increases towards infinity, the probability of a specific value
being picked (1/n) decreases towards 0, with all values having an equal
possibility of being picked.
Date: 26 Sep 2002 16:16:11
Message: <chrishuff-B5D58B.16133826092002@netplex.aussie.org>
In article <3d93677c.99183057@news.povray.org>,
Gah, alright, I misstated the problem. You know what I meant... ;-)
Date: 26 Sep 2002 17:09:04
Message: <3D937770.2863EBC7@gmx.de>
> largely mathematics, and definitely does care. [...]
I'm talking about those parts of mathematics that consider there are an
I'm not sure about the precise english terms, but math distinguishes
between natural numbers (integers: 1, 2, 3, ...), rational numbers
(numbers that can be represented as a fraction of two natual numbers) and
real numbers (rational numbers and all other numbers like sqrt(2), pi,
etc.).  The latter two categories are those where two consecutive random
numbers from a given range won't be identical (assuming there is a
mathematical definition of random numbers in that category, which i
doubt).
