POV-Ray : Newsgroups : povray.advanced-users : Random variation Server Time
18 May 2026 00:01:52 EDT (-0400)
  Random variation (Message 21 to 25 of 25)
Subject: Re: Random variation
Date: 27 Sep 2002 09:53:57
Message: <chrishuff-AD0865.09511027092002@netplex.aussie.org>
In article <3d9434b1@news.povray.org>, Warp <war### [at] tagpovrayorg>
wrote:
>   Then it's a rather poor random number generator, I must say.
>   In a good random number generator, any combination of two numbers (including
> the same number twice) should be about equally probable.
>   Of course this is a very difficult issue.
I don't think this alone makes it so bad, its other characteristics seem
fair. Not great, but not horrible. It is an extremely simple algorithm,
I posted the code earlier in this thread.
If you want a really good generator, the Mersene Twister might be
suitable...I've heard good things about it, and wrote an implementation
of it that seems to work fine.
>   I wonder if an approach like the drand48() function would be better.
What approach would that be?
http://tag.povray.org/
Date: 27 Sep 2002 11:54:18
Message: <3d947f2a@news.povray.org>
  From the drand48 man page:
     Functions  drand48()  and  erand48()   return   non-negative
     double-precision floating-point values uniformly distributed
     over the interval [0.0, 1.0].
[snip]
     All the routines work by generating  a  sequence  of  48-bit
     integer  values,  Xi  , according to the linear congruential
     formula
           X n+1= (aX n+c)  mod m n>=0.
     The parameter m = 2**48; hence 48-bit integer arithmetic  is
     performed. Unless lcong48() has been invoked, the multiplier
     value a and the addend value c are given by
               a = 5DEECE66D16 = 2736731631558
               c = B16 = 138 .
     The value  returned  by  any  of  the  functions  drand48(),
     erand48(),  lrand48(), nrand48(), mrand48(), or jrand48() is
     computed by first generating  the  next  48-bit  Xi  in  the
     sequence.  Then the appropriate number of bits, according to
     the type of data item to be returned, are  copied  from  the
     high-order  (leftmost)  bits  of Xi and transformed into the
     returned value.
     The functions drand48(), lrand48(), and mrand48() store  the
     last  48-bit  Xi generated in an internal buffer. Xi must be
     initialized prior to being invoked.
[snip]
     The initializer function srand48() sets  the  high-order  32
     bits  of  Xi  to  the 32 bits contained in its argument. The
     low-order 16 bits of Xi  are  set  to  the  arbitrary  value
     330E16 .
Date: 27 Sep 2002 20:09:52
Message: <3D94F3B2.7070008@enter.net>
Christopher James Huff wrote:
 > represented with a double precision variable, with a perfect random
 > number generator any one of those values would be equally likely,
<g>
But then, for perfect random number generator, wouldn't we need to
plug a fresh cup of really hot tea into the USB port and use the
non-standard C function getbrownian() and somehow cast the
resulting vector as a double? Alas, I understand getbrownian()
isn't directly supported on all the platforms that POV-Ray is
compiled for, (or any of them, in fact) so this might somewhat
hurt portability.
</g>
@C[$F];
The Silver Tome ::  http://www.silvertome.com
"You may sing to my cat if you like..."
Date: 28 Sep 2002 04:07:48
Message: <dioapu0nrkkfjt1ga960j24i5aq9c2etik@4ax.com>
On Fri, 27 Sep 2002 20:11:30 -0400, Charles Fusner <cfu### [at] enternet>
The problem with this approach is that the second law of
thermodynamics will kick in, which means that in animations, later
frames will have lower dispersion in their random sequences. This will
also result in pretty interesting vertical gradient patterns in
radiosity pictures due to the random number generator cooling down
during the long render.
<follow-ups set>
Peter Popov ICQ : 15002700
Date: 28 Sep 2002 09:52:33
Message: <slrnapbd0v.18v.y7pt9001@safari.homelinux.net>
some time ago I played with PRNG's...
'worst-case' simulation or something.
25000 spheres were 'randomly' positioned.
'incr-seeds' means that for every sphere different initial seeds
were used (little bigger than for the previous sphere).
for every sphere position six (pseudo) random number generator
states (or seeds) were needed.
now, if spheres are not placed uniformly, it means that seed
values correlate with the output of the generator
(bad thing for a PRNG).
'one-seeding' means that for all of the 25000 sphere positions
only six seeds were used (and I mean six in TOTAL).
if spheres are not placed uniformly (in both -1 and -2 jpg),
it means that the PRNG plainly sucks.
I made patch for povray 3.5 which allows using GSL's RNG's
by defining env var POVRAY_USE_GSL and then wanted generator
in GSL_RNG_TYPE. if POVRAY_USE_GSL is not defined, SHA-512 is used.
of every PRNG in GSL v1.2, only mt19937 was 'okay' in my *humble*
opinion. YMMV.
(GSL+SHA-512 patch not available for public as for now)
scene file source
http://iki.fi/safari/prng/rnd_sphere2.pov
http://iki.fi/safari/prng/incr-seeds/rnd_sphere2-rand48-1.jpg
http://iki.fi/safari/prng/incr-seeds/rnd_sphere2-rand48-2.jpg
http://iki.fi/safari/prng/one-seeding/rnd_sphere2-rand48-1.jpg
http://iki.fi/safari/prng/one-seeding/rnd_sphere2-rand48-2.jpg
compare to a 'better' PRNG
http://iki.fi/safari/prng/incr-seeds/rnd_sphere2-sha-512-1.jpg
http://iki.fi/safari/prng/incr-seeds/rnd_sphere2-sha-512-2.jpg
http://iki.fi/safari/prng/one-seeding/rnd_sphere2-sha-512-1.jpg
http://iki.fi/safari/prng/one-seeding/rnd_sphere2-sha-512-2.jpg
and with povray 3.5's official PRNG
http://iki.fi/safari/prng/incr-seeds/rnd_sphere2-orig-1.jpg
http://iki.fi/safari/prng/incr-seeds/rnd_sphere2-orig-2.jpg
http://iki.fi/safari/prng/one-seeding/rnd_sphere2-orig-1.jpg
http://iki.fi/safari/prng/one-seeding/rnd_sphere2-orig-2.jpg
interesting, it's almost like rand48.
usually povray's PRNG is sufficient, but sometimes I get
artefacts in photon shooting (not evenly placed or something)...
and, of course, when using this kind of scene file :)
(yes, SHA1 would probably give same kind of results than SHA-512,
but that's another story)
Safari - y7p### [at] sneakemailcomgovinvalid
"Talk is cheap. Show me the code." - Linus Torvalds
