Hash: SHA1
I don't particularly like the background patterns supplied with
POV-Ray. (Well, the bw marble one is quite nice.) So I decided to
make my own, using... well... POV-Ray! The trick is, how do you get
the pattern to loop? The best I can come up with is something like...
camera
spherical
angle 360, 360
location <0, 0, 0>
direction z
up y
right x
object
sphere {<0, 0, 0>, 200}
hollow
texture
pigment {...}
finish {ambient 1 diffuse 0}
If you render that as a square image (e.g., 100x100 pixels) it loops
quite nicely... The image is a bit distorted though. The other
possibility is to use
camera
ultra_wide_angle
angle 360
location <0, 0, 0>
direction z
up y
right x
But that has other distortions too. (I like the first one better!)
Can anyone think of more creating ways of going about this? Perhaps
something weird could be done using function pigments and an
orthographic camera?
Thanks.
Andrew.
-----BEGIN PGP SIGNATURE-----
Version: PGPfreeware 7.0.3 for non-commercial use <http://www.pgp.com>
iQA/AwUBPZHZ07EpzUF0Y1JeEQIqpACgtYFVgyfK0W44Ss/1NSPDL8IR7yAAoLo5
Ub6GQgo43JMd+SqTse5bn+k6
=QZeB
-----END PGP SIGNATURE-----
Adapted from my repeating HF generator from:
(http://news.povray.org/povray.binaries.scene-files/26011/)
This uses a function pigment, there is a bit of distortion, but depending on
the pattern, it is nowhere near as noticeable as the spherical camera type,
and it is repeating in both the x and y directions rather than giving the
'banding' that the spherical camera tends to give.
-tgq
//start scene
camera{
orthographic
up y*image_height
right x*image_width
location -z
look_at 0
#macro RepeatPattern(Ptrn)//macro to make repeating texture
#macro CMap(C) color_map{[0 rgbt C*<3,3,3,0>+<0,0,0,1>][1 rgbt
C*<3,3,3,0>+<0,0,0,0>]}#end
#local Pat=function{pigment{Ptrn}}
#local FR=function{Pat(cos(x),sin(y),(sin(x)+cos(y))/2).red}
#local FG=function{Pat(cos(x),sin(y),(sin(x)+cos(y))/2).green}
#local FB=function{Pat(cos(x),sin(y),(sin(x)+cos(y))/2).blue}
average
texture_map {
[pigment{function{FR(x,y,z)} CMap(<1,0,0>)}finish{ambient 1}]
[pigment{function{FG(x,y,z)} CMap(<0,1,0>)}finish{ambient 1}]
[pigment{function{FB(x,y,z)} CMap(<0,0,1>)}finish{ambient 1}]
scale <image_width,image_height,1>/radians(360)
#declare Ptrn=//use whatever pattern you want here as a pigment
pigment{
bozo turbulence 0.72
color_map{
[0 rgb <1,0,0>]
[1 rgb <0,1,0>]
scale 1/2
plane{z 0 texture{RepeatPattern(Ptrn)}}
//end scene
