POV-Ray : Newsgroups : povray.advanced-users : Change in Image_Map => function? Server Time
29 Sep 2024 16:10:31 EDT (-0400)
  Change in Image_Map => function? (Message 1 to 5 of 5)
Subject: Change in Image_Map => function?
Date: 10 Sep 2002 17:55:05
Message: <3d7e6a39@news.povray.org>
I could really use some help on this. Prior to the final release of 3.5, I
got a very different result from using an image map for a function in an
iso. In the old version (some 3.5 beta...), the image actually "formed" the
iso. Now it is simply mapped onto the surface. I am using the same image as
a pigment, but the sphere itself did not appear in the old image, as you can
see in p.b.i. I need to redo this scene using a new set of TGA files so I
would very much like some suggestions on how to recreate the old effect in
which the image in the image map itself generates or alters the form of the
iso.
Here's the code from the scenes is in pbi - it no longer creates the effect
I am after (nothing else has changed.)
#declare MAP = pigment {
 image_map {  tga concat("e:\\me\\me", str(clock*356,-3,0), .tga")
    map_type 1 interpolate 2 }}
#declare PF = function {pigment { MAP }}
#declare Sphere = function { pow(x,x)+pow(y,y)+pow(z,z) }
#declare test =
  isosurface {function {(1 - PF(x, y, z).grey) * 0.4 + Sphere(x, y, z)}
    max_gradient 80
    threshold 0.9
    contained_by { sphere { 0, 0.999 } }
    no_shadow
    pigment { MAP }
    finish { ambient 0.8 specular .2 diffuse 0.7 }
    rnd_rotate() }
thanks for any help.
Dennis
Subject: Re: Change in Image_Map => function?
Date: 10 Sep 2002 18:08:53
Message: <3d7e6d75@news.povray.org>
3d7e6a39@news.povray.org...
effect
Perhaps the code in the hfsphere.zip file in the page below could help.
http://www.oyonale.com/ressources/english/sources09.htm
G.
- Graphic experiments
- Posters
Date: 10 Sep 2002 18:33:15
Message: <3d7e732b$1@news.povray.org>
Thanks, but I still see a large portion of the sphere when I use my image
map in hfsphere.pov
Plus, I am trying to determine if there have been any changes to the final
3.5 that could account for the differences (did you have a chance to check
pbi?) In the old version, you cannot see the sphere at all, which is what I
am after.
Best,
D.
"Gilles Tran" <git### [at] wanadoofr> wrote in message
news:3d7e6d75@news.povray.org...
> effect
> G.
> - POV-Ray and Poser computer images
> - Posters
Date: 10 Sep 2002 20:52:54
Message: <3d7e93e6@news.povray.org>
"Dennis Miller" <dhm### [at] attbicom> wrote in message
news:3d7e6a39@news.povray.org...
This function should be
 #declare Sphere = function { pow(x,2)+pow(y,2)+pow(z,2) }
Or use f_sphere function.  It is much faster.
R. Suzuki
Date: 10 Sep 2002 21:06:00
Message: <3d7e96f8$1@news.povray.org>
Ah, yes, that was it. I forgot I had to change the old x^2.
Thanks so very much,
Dennis
"R. Suzuki" <r-s### [at] aistgojp> wrote in message
news:3d7e93e6@news.povray.org...
> R. Suzuki
