POV-Ray : Newsgroups : povray.advanced-users : Prism refracting a true rainbow ? Server Time
29 Sep 2024 16:12:33 EDT (-0400)
  Prism refracting a true rainbow ? (Message 1 to 6 of 6)
Subject: Prism refracting a true rainbow ?
Date: 11 Aug 2002 11:15:58
Message: <3d567fae$1@news.povray.org>
If I take a light and a glas-prism, I get a true rainbow.
Has anyone done something like that before ?
Can you sent me the scene file ?
Theo Gottwald
http://www.it-berater.org/smpov.htm
Subject: Re: Prism refracting a true rainbow ?
Date: 11 Aug 2002 11:21:34
Message: <3D568171.4DC80935@pacbell.net>
It has been done using photons + dispersion.
I don't have a working example handy but if you research those
features it shouldn't be too difficult for you to figure out.
Ken Tyler
Date: 11 Aug 2002 11:33:07
Message: <3d5683b3$1@news.povray.org>
Yes, I've already tried a bit and mixed a red, green and blue spot light
which gives also a lot of colours.
The diffract-examples partially render to some "unnatural rainbows"
as the colours do not flow in each other but are separated like with a line.
Especially new_diffract.pov. I am not yet shure what I need to change that.
However I thought I ask if someone has something like that already.
thanks
--Theo
"Ken" <tyl### [at] pacbellnet> schrieb im Newsbeitrag
news:3D568171.4DC80935@pacbell.net...
> Ken Tyler
Date: 11 Aug 2002 11:50:51
Message: <chrishuff-B339F2.10390311082002@netplex.aussie.org>
In article <3d5683b3$1@news.povray.org>,
That is not necessary, more work, and is much less accurate.
newdiffract.pov is not at all realistic, it uses a dispersion value far
outside the usual range for a special effect. Usual values are much
closer to 1, look at consts.inc for some values.
If you want smoother color blends, increase dispersion_samples. This
will slow things down though...it is a tradeoff of speed or quality.
http://tag.povray.org/
Date: 12 Aug 2002 00:40:05
Message: <web.3d5739daafdcd0e888d4e3910@news.povray.org>
Is there an option to specify a light source as a beam trace (opposed to a
ray trace)?  The differance in that a ray is a line which doesn't have any
area (in in't cross section).  A beam represents the summing of a bunch of
rays that pass closely to the point of interest (location, eye).  The
closer the ray passes the more it is weighted (gaussian) contribution.  The
beam would smooth the rays.  However at least 8 extra  rays around the
center ray would have to be traced to represent a beam, so this could be
costly.
>thanks
>news:3D568171.4DC80935[at]pacbell.net...
>> Ken Tyler
ton### [at] xenomechanicscom
Date: 12 Aug 2002 13:15:30
Message: <chrishuff-77ED79.12034512082002@netplex.aussie.org>
In article <web.3d5739daafdcd0e888d4e3910@news.povray.org>,
> costly.
The dispersion feature comes as close as is possible in POV by tracing
multiple rays to sample the "beam". There is no single "point of
interest" to compare each ray against because the entire scene can
matter, it might be an arbitrary set of solid shapes or a pattern of
color in a texture, or even volumetric media.
The solution is just to increase the dispersion samples until the
splitting is not noticeable.
