POV-Ray : Newsgroups : povray.advanced-users : Bug with defined() ? Server Time
17 May 2026 21:12:37 EDT (-0400)
  Bug with defined() ? (Message 1 to 4 of 4)
Subject: Bug with defined() ?
Date: 4 Aug 2002 11:44:42
Message: <3d4d4bea$1@news.povray.org>
When attempting to read an empty file (the file is
there, but containing not a single character)
like this:
#read (File, _PreviouslyUndeclared)
I'd expect defined(_PreviouslyUndeclared) to return
false.
It doesn't.
If I check the file before any reading with defined(File),
I get a true, after attempt to read, I get false, but
not only when the file is empty, but also when reading
the last data.
E.g.: A file filled with 3 vectors. If I check defined(File)
before and after reading, I get 3 true for the check before,
but only two true for the check after reading.
Checking if (_PreviouslyUndeclared) is defined results in
true all the time.
So. Is this really what I should expect?
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Bug with defined() ?
Date: 4 Aug 2002 12:53:17
Message: <3d4d5bfd@news.povray.org>
> like this:
> false.
> It doesn't.
_PrevioslyUndeclared is defined but it is not initialised (Did I use the
right words?)
> the last data.
This does only happen when you dont have a comma behind the last data item.
Date: 4 Aug 2002 13:59:41
Message: <3d4d6b8d@news.povray.org>
Thanks for both answers, I'll check what you mentioned
and reply sometime later again...
Tim
Tim Nikias
"Simon Adameit" <gom### [at] gmxde> schrieb im Newsbeitrag
news:3d4d5bfd@news.povray.org...
> > like this:
> > false.
> > It doesn't.
> right words?)
> > the last data.
item.
Date: 5 Aug 2002 12:35:18
Message: <3d4ea946@news.povray.org>
Its finally working!
I never thought that the files would need that extra
comma to work. IMHO its may be easier for
a starter (simply append to file with Data+",") but
I think it would make more sense if defined(File)
would return false if no data follows, not if no
data follows after a comma.
Ah well. It was probably thought of some long time
ago, and I don't want to start a debate about such
small things.
But some note in the docs would perhaps be of some
help? Ingo?
Tim
Tim Nikias
"Tim Nikias" <tim### [at] gmxde> schrieb im Newsbeitrag
news:3d4d6b8d@news.povray.org...
> Regards,
> Tim
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
> > > like this:
> > > false.
> > > It doesn't.
> > right words?)
> > > the last data.
> item.
