POV-Ray : Newsgroups : povray.advanced-users : Radiosity - sunlight through a window? Server Time
18 May 2026 00:01:59 EDT (-0400)
  Radiosity - sunlight through a window? (Message 11 to 20 of 20)
Subject: Re: Radiosity - sunlight through a window?
Date: 26 Jul 2002 16:45:37
Message: <3d41b4f1@news.povray.org>
"John Pallett" wrote:
> Hi guys -
> Some more notes -
> I was surrounding my entire scene with a gigantic white sphere, not creating
> a 'spherical sun'.  The problem, as it turns out, was that the light wasn't
> getting scattered around the room enough for it to properly simulate
> sunlight coming in a window (which scatters all over the room).  So the
> scene consisted of:
> - A huge white sphere, ambient 0.5
> - A parallel white light (sunlight) (parallel lighting for the sun is good
> enough for our purposes)
> - A room with a window, all materials set to (ambient 0, diffuse 0.9) so
> that they aren't emitting light into the scene
> - My camera inside the room
> Thanks to everyone for suggestions thus far.  The missing ingredient seems
> to have been media, which can be used to scatter light.  What I am doing now
> is using media inside my rooms to scatter the sunlight as it comes in the
> window and as it bounces around the room.  Very subtle scattering gives me
> great results.
> I'll post images to PBI once I get something put together that demonstrates
> the problem clearly.
> Can anyone suggest another way to solve the problem of having the light
> coming in the window scatter around the room appropriately?  Note that my
> camera points TOWARDS the window, so making the window's wall invisible is
> not an option.
Ah. Too bad. Then you have to:
1) Raise the count to appropriate value.
2) Raise the recursion limit to appropriate value (3).
3) Raise the brightness to appropriate value (2.5, 3 or even more)
4) Be very patient.
Otherwise you could put a huge area_light right where the window is. This, with just
a bit of tweaking, should give you very soft shadows which, together with just a bit
of radiosity, might look nice nonetheless. This can be very slow too.
Anyway ambient 0.5 is pretty low for a skysphere. Use a real sky_sphere with a
gradient from white (bright white: rgb 1.25) to sky blue.
Jonathan.
Date: 26 Jul 2002 18:34:37
Message: <3d41ce7d@news.povray.org>
So no value in using scattering media to help "scatter" the sunlight around
the room...?
JP
"JRG" <jrg### [at] hotmailcom> wrote in message
news:3d41b4f1@news.povray.org...
> > Hi guys -
> > Some more notes -
creating
wasn't
> > scene consisted of:
good
seems
now
the
me
> > great results.
demonstrates
my
is
> > not an option.
> 4) Be very patient.
with just
just a bit
with a
> Jonathan.
Date: 26 Jul 2002 18:48:43
Message: <3d41d1cb@news.povray.org>
I have (had?) a complete animation with this church scene. My bro almost
couldn't believe it was done using computer(s). Absolutely stunning.
Message: <3d41d1cb$1@news.povray.org>
> the room...?
Although "media on" in the radiosity block makes media affect radiosity, I doubt it
would be of any help here.
Jonathan.
Date: 26 Jul 2002 18:49:31
Message: <3d41d1fb$1@news.povray.org>
Not sure about that, remember the "god's fingers" situation when light
crawls through small openings in dusty/smoky areas?
Date: 26 Jul 2002 19:43:31
Message: <3d41dea3@news.povray.org>
Some good news actually regarding scattering media - I'm getting some good
results from this.
I tried adding a very simple scattering media to my room and it made a huge
difference - even without any emissive characteristics, the scattering
effect caused rays to bounce more or less as I'd expect sunlight to interact
with my room.  It's almost as if the 'scattering' of a single radiosity ray
simulates the effect of the sunlight bouncing around the room several times.
Unfortunately it's very tweaky - small changes in radiosity settings mean
you have to modify the media - but I'm still working on it.  The good news
is that using media, I can get good results in much less time than by
cranking up my radiosity settings.  I may not be able to get a reliable
framework out of it - but I will let you know if I do.
JP
news:3d41d1cb$1@news.povray.org...
around
> > the room...?
doubt it
> Jonathan.
Date: 26 Jul 2002 19:54:28
Message: <chrishuff-FEB388.18471426072002@netplex.aussie.org>
In article <3d41d1fb$1@news.povray.org>,
That is not due to beam divergence, it would happen with truely parallel
light. It is caused by perspective: the rays come through the clouds at
a distance and pass to each side. If the sun was close enough for
divergence to be visible, there probably wouldn't be clouds and you
wouldn't be there to see it.
Date: 27 Jul 2002 14:08:04
Message: <3D42E181.4030500@caltel.com>
What else can be used to simulate the adaption the eye makes in
low-light situations?
Christopher James Huff wrote:
> In article <3D4### [at] caltelcom>,
>  Samuel Benge <sbe### [at] caltelcom> wrote:
>>Try setting assumed_gamma to somthing very low, like 1 or 0.5. This will
>>brighten everything up, hopfully simulating the natural adjustment our
>>eyes make in low-light situations.
> Very low? 1 is the recommended value..."For new scenes, you should use
> an assumed gamma value of 1.0 as this models how light appears in the
> real world more realistically."
Samuel Benge
Date: 27 Jul 2002 22:47:03
Message: <chrishuff-011423.21394827072002@netplex.aussie.org>
You could use an external program to process the contrast of the image
(or do it in POV using functions, see the recent find_edges images for
an example), or you could use a patch that allows you to adjust the
dynamic range of the image. The raw_image and curves patches of MegaPOV
could be used for this.
Date: 29 Jul 2002 15:51:59
Message: <slrnakb771.dc5.ron.parker@fwi.com>
And in fact, on particularly good days you can see convergence on the
other side of the sky as well; APOD has had a few examples of this
phenomenon.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
