POV-Ray : Newsgroups : povray.advanced-users : Making Repeatable Textures Server Time
29 Sep 2024 18:15:26 EDT (-0400)
  Making Repeatable Textures (Message 1 to 9 of 9)
Subject: Making Repeatable Textures
Date: 14 Jun 2002 01:11:31
Message: <3d097b03@news.povray.org>
I'm currently making a 3D engine and I want to use some of the features of
POV-Ray to make textures. I already have some great results by using NKFlare
for sparkles and such. However, I want to make repeatable textures for the
walls and ground.
How can this be done in POV-Ray?
Now, I know I can setup two mirror planes that cross and then we have a
repeatable textures that looks like it was made with mirrors. But there are
textures that look like dirt but are repeatable and the lines inbetween are
not visible.
Can this be done in POV-Ray? I imagine so but I need a nudge in the right
direction.
Thanks in advance!
Subject: Re: Making Repeatable Textures
Date: 14 Jun 2002 01:51:15
Message: <3d098453$1@news.povray.org>
You could render to an image &
then make tilable using the GIMP or maybe photoshop &
then use the image as an imagemap.
Other than that you would have to rely on the texture gurus around here.
Date: 14 Jun 2002 05:47:54
Message: <3d09bbca$1@news.povray.org>
This should do what you want:
http://www.geocities.com/ccolefax/tilegen.html
All the best,
Andy Cocker
"Chris Becker" <top### [at] cshritedu> wrote in message
news:3d097b03@news.povray.org...
NKFlare
> walls and ground.
are
are
> not visible.
> direction.
> Thanks in advance!
Date: 14 Jun 2002 06:20:39
Message: <3d09c377@news.povray.org>
If you want to repeat textures along one direction only, it's very easy.
Just apply the texture to a hollow cylinder and place a 360 degree
cylindrical camera inside the cylinder. (The axis of the cylinder and
the axis of the cylindrical camera should be the same of course.)
If you need to repeat the texture both horizontally and vertically at
the same time, you need to use other tricks such as Chris Colefax's
utility as mentioned elsewhere in this thread. However, tiling textures
with the technique that Chris' utility uses can lead to blending, which
dependent on your texture may look very good or not very good.
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated May 20)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Date: 14 Jun 2002 10:12:54
Message: <3d09f9e6@news.povray.org>
It's easier to do with pov3.5 than the answers already given may make you
think:
// Create a pattern function which is tileable inside <0,0,0>-<1,1,0>
#macro MakeXYTileablePatternFunc(PatternFunc)
  function
  { (PatternFunc(x,y,z)*(1-x)+PatternFunc(x-1,y,z)*x)*(1-y) +
    (PatternFunc(x,y-1,z)*(1-x)+PatternFunc(x-1,y-1,z)*x)*y
// Example:
#declare GranitePattern = function { pattern { granite noise_generator 1 } }
#declare TileableGranite = MakeXYTileablePatternFunc(GranitePattern)
#declare Tile =
  box
  { 0,<1,1,.1>
    pigment
    { function { TileableGranite(x,y,z) }
      color_map { [0 rgb z][1 rgb 1] }
// Create 4x4 boxes:
#declare IndY = -2;
#while(IndY < 2)
  #declare IndX = -2;
  #while(IndX < 2)
    object { Tile translate <IndX, IndY, 0> }
    #declare IndX = IndX+1;
  #declare IndY = IndY+1;
camera { location -z*9 look_at 0 angle 35 }
light_source { -z*100, 1 }
Date: 14 Jun 2002 11:09:16
Message: <3d0a071c@news.povray.org>
> direction.
Image maps are already repeated in the x-y plane, so there's nothing special
to do there.
Procedural textures can be repeated using the "repeat" warp.
    wood
    warp { repeat 2*x }
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 14 Jun 2002 13:32:31
Message: <3d0a28af@news.povray.org>
>  pigment {
>     wood
>     warp { repeat 2*x }
  I think he meant that there shouldn't be visible lines.
Date: 17 Jun 2002 04:17:33
Message: <3d0d9b1d@news.povray.org>
3d0a28af@news.povray.org...
> >  pigment {
> >     wood
> >     warp { repeat 2*x }
OK, OK, so it's
pigment{
    bozo
    warp{repeat 2*x flip x}
    warp{repeat 2*z flip z} // depending on the tiling direction
G.
- Posters
Date: 18 Jun 2002 01:55:53
Message: <3d0ecb69@news.povray.org>
Excellent. Thanks a bunch!
"Andrew Cocker" <mai### [at] mariner9net> wrote in message
news:3d09bbca$1@news.povray.org...
> All the best,
> Andy Cocker
of
> NKFlare
the
> > walls and ground.
> are
> are
> > not visible.
right
> > direction.
> > Thanks in advance!
