POV-Ray : Newsgroups : povray.advanced-users : Quiz Server Time
29 Sep 2024 18:15:26 EDT (-0400)
  Quiz (Message 1 to 10 of 10)
Subject: Quiz
Date: 28 May 2002 12:16:38
Message: <3cf3ad66@news.povray.org>
For what O is
        object{O}
the same as
        object{object{O inverse} inverse}
- Micha
objects.povworld.org - The POV-Ray Objects Collection
book.povworld.org    - The POV-Ray Book Project
Subject: Re: Quiz
Date: 28 May 2002 13:15:06
Message: <3cf3bb1a@news.povray.org>
"Micha Riser" <mri### [at] gmxnet> wrote:
> For what O is
>         object{O}
> the same as
shouldn't this apply for all objects ?
Subject: Re: Quiz
Date: 28 May 2002 13:25:29
Message: <3cf3bd89@news.povray.org>
Micha Riser <mri### [at] gmxnet> wrote:
> For what O is
>         object{O}
> the same as
  Logically yes, but whether POV-Ray is able to optimize the inverses away
or not is a different question.
Subject: Re: Quiz
Date: 28 May 2002 16:52:44
Message: <3cf3ee1c@news.povray.org>
>> For what O is
>>         object{O}
>> the same as
Well, - as Warp wrote - logically yes, but it depends how POV handles it.
The answer is *not* "for all". Have another try :)
- Micha
Subject: Re: Quiz
Date: 28 May 2002 17:31:26
Message: <3cf3f72e@news.povray.org>
In article <3cf3bd89@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Well, "inverse" keyword sets the internal INVERTED_FLAG and just like all bit
flags it is promoted and then handled by the object intersection code itself.
Consequently an object is either inverted or it is nor.  Thus the inverse flag
is always "optimised" also the correct term would probably be "promoted".
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Subject: Solution
Date: 30 May 2002 11:17:59
Message: <3cf642a7@news.povray.org>
> bit flags it is promoted and then handled by the object intersection code
> itself.
> flag is always "optimised" also the correct term would probably be
> "promoted".
As I see this from the source code this is handled differently from object
to object. Most of them just set the INVERTED_FLAG but not all. It is not
possible to do this for CSG objects. Instead POV has to use De Morgans's
law. This means that all members of the CSG get inverted and the CSG type
is changed as follows:
 union -> intersection
 merge -> intersection
 intersection -> merge
This has the consequence that a double-inverted union results in a merge!
So for
 #declare O = union{
  sphere{<0,0,1>,2}
  sphere{<0,0,-1>,2}
  pigment{rgbf 0.9} finish{ambient 1}
 object{O}
and
is not the same as in the second version the internal walls are removed.
- Micha
Subject: Re: Solution
Date: 30 May 2002 13:41:24
Message: <3cf66444@news.povray.org>
In article <3cf642a7@news.povray.org> , Micha Riser <mri### [at] gmxnet>  wrote:
Well, that is intentional as you are essentially misusing the "union" object
as a merge object in the first place.  There is no correct inversion of a
union object that is not a merge so POV-Ray changes it for you automatically.
So inverting has a side effect in this case, yes (and maybe a warning might be
a good idea for this), but is changes nothing about the optimal handling of
"inverse", that is multiple-inversions will not add any otherhead, which is
the answer to the initial question you asked...
    Thorsten
Thorsten Froehlich
Date: 30 May 2002 13:56:23
Message: <3cf667c6@news.povray.org>
  If you think about it, that's exactly the correct behaviour.
  An inverted union is everything outside the union. Now the "outside"
is everything that was "inside" the union. "Outside" doesn't have any surfaces
in it, but it's just empty space. Inverting a union implicitly "removes" all
the inner surfaces (because they are not inner anymore).
  Now if you invert this object, you get an object which is everything that
was "outside" the object. That is, the original union with the inner surfaces
removed.
Date: 30 May 2002 16:42:03
Message: <3cf68e9b@news.povray.org>
Yep, that's exactly the point. I did not mean to claim that there is
anything wrong with POV-Ray. It is just something I came across while
implementing CSG for my own little ray-tracer.
> automatically. So inverting has a side effect in this case, yes (and maybe
> a warning might be a good idea for this), but is changes nothing about the
> optimal handling of "inverse", that is multiple-inversions will not add
> any otherhead, which is the answer to the initial question you asked...
That was Warp's question not mine. I just wanted to point out that
double-inversing does sometimes do something one would not expect at the
first moment.
- Micha
Date: 30 May 2002 16:44:51
Message: <3cf68f43@news.povray.org>
I never said there was anything wrong.
> surfaces in it, but it's just empty space. Inverting a union implicitly
> "removes" all the inner surfaces (because they are not inner anymore).
Hmm, I better like the idea that there is no correct inversion of unions.
- MIcha
