POV-Ray : Newsgroups : povray.advanced-users : RC5 and SSE2 Server Time
16 Mar 2026 00:34:40 EDT (-0400)
  RC5 and SSE2 (Message 1 to 4 of 4)
Subject: RC5 and SSE2
Date: 19 May 2002 23:49:43
Message: <3ce87257$1@news.povray.org>
Has any P4 owner noticed speedups with POVRay 3.5 RC5 ? I noticed in the
changes log that they started to add optimizations, but it doesnt say much
else. I can't test this on my Athlon TBird :)
George Pantazopoulos
Subject: Re: RC5 and SSE2
Date: 20 May 2002 11:00:09
Message: <3ce90f78@news.povray.org>
  It is quite common that code that has been optimized for P4 also runs
faster in an Athlon than the unoptimized code, so some improvement should
probably be seen.
Date: 21 May 2002 03:47:30
Message: <KfnpPGvd4oUpnzF6gIpfPaCyOZVg@4ax.com>
>probably be seen.
I know that it's not totally fair to compare RC4 with the new RC5,
with respect to the new optimizations, but on an AthlonXP 1600+
system, I have a scene file that renders one second slower with the
new compile.
RC4 = 56 seconds
RC5 = 57 seconds
This is only a single file, selected at random, and far from a
scientific evaluation. However, I mention it to point out that the
potential gains from the new optimizations don't always happen for all
scene files, at least not on an AthlonXP system. I'm not alarmed by
this, especially since the new performance gains were only reported to
be moderate anyway, even when running under an Intel processor, as
targeted by these optimizations.
I'll run a few more comparisons, and if I find anything remarkable
happening, I'll be sure to post something about it.
I wonder which group that should be posted in, when and if I feel the
need to do so?
Later,
Glen
7no### [at] ezwvcom     (Remove the numeral "7")
Date: 22 May 2002 03:48:56
Message: <3ceb4d68@news.povray.org>
In article <KfnpPGvd4oUpnzF6gIpfPaCyOZVg@4ax.com> , Glen Berry
> new compile.
> RC4 = 56 seconds
> RC5 = 57 seconds
You know, on a multitasking system one second is like nothing.  A measuring
error, not more.
To trace the effect of the speedup you need a scene which uses a lot of noise,
that is for the most part certain textures.  To try benchmark.pov for example
(with a small resolution) will show some differences.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
