hi dear Povers!!
i want to make a slop function but always return zero. is it possible?
#declare ff = function { pigment {slope {<0,0,1> ,0,1} }}
ahmet oktar wrote:
> hi dear Povers!!
No, it is not, the slope pattern requires the normal vector from the
intersection test which is not available in fucnctions.
There is no method in Povray 3.5 to do this for arbitrary shapes but you
can use the object_slope pattern from megapov MCP that was made exactly
for this purpose:
http://www.tu-bs.de/~y0013390/povcyg/docu/docu_pattern01.html#OBJSLOPE
Last updated 20 Apr. 2002 _____./\/^>_*_<^\/\.______
thanks christoph! i can't understand why not for 3.5. it's important like
this features!
"Christoph Hormann" <chr### [at] gmx de> wrote in message
news:3CC2820F.C84D7164@gmx.de...
> ahmet oktar wrote:
> > hi dear Povers!!
> for this purpose:
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
If you have a slope function defined and you call it with some values,
what should the function return?
"Warp" <war### [at] tag povray org> wrote in message
news:3cc2ccd1@news.povray.org...
yes return a value but it's always constant. It not give slope values in
render time
