POV-Ray : Newsgroups : povray.advanced-users : IsoCSG rounded shape macros Server Time
13 Oct 2025 16:19:19 EDT (-0400)
  IsoCSG rounded shape macros (Message 1 to 5 of 5)
Subject: IsoCSG rounded shape macros
Date: 19 Apr 2002 05:55:11
Message: <3cbfe97f@news.povray.org>
Hi all
I am tying to create some shapes in POVRay 3.5 (beta.RC1) using Christoph
Hormann's IsoCSG Library (version 0.4) and
I have a couple of questions:
1. I want to create a rounded cylinder using the IC_Cylinder shape macro in
the iso_rcsg.inc (Rounded Shapes).
However the cylinder I get just looks like a normal cylinder created using
POV primitive. Below is the code I am using:
#version 3.5;
global_settings {
  assumed_gamma 1.0
background { color <0.750,0.500,0.300> }
  location    <-10, 25, 10>*1.5
  direction   y
  sky         z
  up          z
  right       1.33333*x
  look_at     <0, 0, 1.7>
  angle       15
light_source {
  <-1000, 2500, 5000>
  color rgb 1.2
#include "iso_rcsg.inc"
#declare fn_1 = IC_Cylinder (-x, x, 0.8)
#declare fn_XX= function { fn_1(x, y, z) }
isosurface {
  function { fn_XX(x, y, z) }
  max_gradient 1.6
  contained_by { box { -8+z*5, 8+2*z } }
  pigment { rgb <0, 0.2, 1.1> }
  finish { specular 0.3 }
  scale 1.2
How do I create a smooth rounded cone using this macro?
What are general principles I need to use to get round edges on a object
created with IsoCSG?
2. How do you use the macros in the IsoCSG to do the equivalent of the blob
threshold as detailed in the POV help section 3.6.3.5
Thanks in advance
Reuben
doo### [at] breathemailnet
Subject: Re: IsoCSG rounded shape macros
Date: 19 Apr 2002 06:44:29
Message: <3CBFF50C.E043FCB7@gmx.de>
Reuben Pearse wrote:
> Hi all
Calling the functions 'rounded' is a bit misleading, i will add a better
explanation in the next version.  The shape itself is not different from
normal iso_csg functions.
But you can use the rounding properties of the functions by changing the
threshold value, for example:
#declare fn_1 = IC_Threshold( IC_Cylinder (-x, x, 0.8), 0.2)
Note that the resulting shape no more has the measures given to the
cylinder macro.
You can use the methods mentioned above or implement the CSG constructions
from the Round_Cone() macro in 'shapes.inc'.
The same applies for all other shapes of course.  For a rounded box you
can also use the f_rounded_box() function from functions.inc.
You can use the iso_csg functions like any other functions so you can also
use them in blob constructions (instead of fn_A()/fn_B() in the cited
example)
Future versions of iso_csg will probably also implement blob functions.
Last updated 16 Apr. 2002 _____./\/^>_*_<^\/\.______
Date: 19 Apr 2002 06:46:40
Message: <ftsvbu0n40gismmvt6u7ifuqpk9kkmemet@4ax.com>
On Fri, 19 Apr 2002 10:59:05 +0100, "Reuben Pearse"
> POV primitive.
Becouse it is rounded when you move surface outside. If you use only cylinder
in your isosurface then just use threshold keyword of isosurface to make
surface. If you want cylinder as part of bigger iso_csg then use IC_Threshold
macro as described in documentation.
The same way. Use threshold.
The same way. Just use result of macros in IsoCSG as blob component.
Sorry, have no time to make examples at this moment. Tell me if it is
necessary.
ABX
Date: 22 Apr 2002 07:35:12
Message: <3cc3f570$1@news.povray.org>
Thanks for your help.
I have started experimenting with IC_Theshold function. This works with the
rounded cylinder.
However when I tried to use the rounded cone function I got an error. The
details are below:
//Rounded cone function declaration
#declare fn_1 = IC_Threshold( IC_Cone (-x, 0.2, x, 0.8), 0.2)
I get this error in the Reorient_Trans macro in transforms.inc
#error "error in Reorient_Trans macro: Axis1 may not be exact opposite of
Axis2"
Any ideas?
Reuben Pearse
news:3CBFF50C.E043FCB7@gmx.de...
> > Hi all
in
using
> cylinder macro.
blob
> example)
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
Date: 22 Apr 2002 07:51:06
Message: <dqt7cu4mss3h0jlm3lffj7f2b7nt0kb573@4ax.com>
On Mon, 22 Apr 2002 12:39:11 +0100, "Reuben Pearse"
> Axis2"
> Any ideas?
Reorient_Trans is a macro from transforms.inc in standard distribution.
As simple workaroud try to make your cone along y axis and rotate it around z
to place along x. Something like:
IC_Threshold( IC_Rotate( IC_Cone (-y, 0.2, y, 0.8) , z*90 ), 0.2)
Unfortunatelly additional rotation can a little slow down evaluation.
ABX
