POV-Ray : Newsgroups : povray.advanced-users : Something more theoretical.... Server Time
29 Sep 2024 20:18:31 EDT (-0400)
  Something more theoretical.... (Message 1 to 10 of 23)
Subject: Something more theoretical....
Date: 16 Apr 2002 13:26:03
Message: <3cbc5eab@news.povray.org>
OK ... I finished one of these 0PPS-pictures, and went on to my next POV-project ...
I'm working on something like the clutter-macro, we've already seen here ...
At least, I want to place a lot objects (currently spheres) in the scene (currently
on a surface, so its 2D) without intersection ...
currently I use the simple, dumb, standard algorithm, that checks for every new
sphere, if theres another one already placed, which would intersect. If so, then
I calculate another position, until I find a free place ...
The thing is, that this algorithm works in O(n^2) which means it can get quite slow
in POV-SDL (of course, not only SDL). Currently for an instance of n=10,000  I have
a parse-time of ~40mins, and I want to go even higher for n.
So I wonder, if there are other, more advanced algorithms out there, which are
faster ...
I thought about doing something like putting the spheres in boxes and only test
for the spheres, that are in the current and the adjacent boxes. This would save
the time to test EVERY other sphere, but would add some overhead for small number
of objects ...
So, has anyone done something like that already, or is there interest in such a
macro or at least testresults ?
If you are interested, I could do some tests when I have some time, but don't
count on this beeing soon ...
-- Jan
Subject: Re: Something more theoretical....
Date: 16 Apr 2002 16:49:16
Message: <3cbc8e4c@news.povray.org>
If the spheres are very tight to each other then jittering is the keyword: instead of
true pseudo-casual (forgive the oxymoron) positions you put your spheres through a
loop, then translate each position by a little random amount.
Otherwise dividing your Universe into boxes and checking the adjacent boxes only
should speed things of course. Try also this: if a position fail don't trash it but
try and translate that by a little amount (for example the diameter of the sphere) in
the four directions. You could use the number of spheres already in the box as
indicator of the probability (so the feasibility) of success of these translations.
Jonathan.
Home: http://digilander.iol.it/jrgpov
Date: 16 Apr 2002 16:59:38
Message: <3cbc90ba$1@news.povray.org>
But also small translation (or jittering) of the sphere would involve
a complete check of all other spheres if I don't do anything else...
Maybe I could (after I detected some collisions) save the nearest ones
and only check these ones ...
But I found a problem in my other approach. Does POV-Ray support some-
thing like chained-lists efficiently ? I don't know, how to find out,
if I have a given box, which of my thousands spheres are in that very
one box.
Date: 16 Apr 2002 17:20:38
Message: <3cbc95a6@news.povray.org>
Usually jittering is done in such way to make it impossible to have intersections.
That would make it a O(0)... ;-)
If R is the radius of the sphere you're placing and 1/L^2 is the density you want to
get (x_step=L, z_step=L) then you can translate your sphere by L/2-R maximum in any
direction. That should prevent any intersection, and yet make it possible to have
spheres touching each other.
Of course L>=2*max(Ri)i=1,2,...n.
> one box.
I did it once. IIRC it was a real puzzle, I began to meet arrays in my not so quiet
dreams... :-|
Jonathan.
Date: 16 Apr 2002 17:35:10
Message: <3cbc990e@news.povray.org>
"JRG" <jrg### [at] hotmailcom> schrieb im Newsbeitrag news:3cbc95a6@news.povray.org...
lets see, if I understood this correct ...
You say, that I should first place all the spheres in a grid, and then jitter this
to make a random distribution ? ... sounds interesting ...
My current approach is, that I select a random point in the area, and compute
the size of the sphere (currently the size of the sphere depends from a function, so
I have a bit control about the size)...
Then I look through an array of the already positioned spheres and if there's
another sphere intersecting, then I look for another place ...
> > one box.
> dreams... :-|
that doesn't sound nice ... you mean I should leave this to an external program ?
Date: 16 Apr 2002 18:02:30
Message: <3cbc9f76@news.povray.org>
Ideally. In fact you jitter the spheres as you place them. You should come up with
something like:
#declare N = 400;
#declare L = 0.3+1; //max_radius + epsilon
#declare RS = seed (123);
union {
#local i=0;
#while (i<sqrt(N))
#local j=0;
#while (j<sqrt(N))
#declare RADIUS = 0.1+0.2*rand(RS); // your function here
sphere {
0,RADIUS
translate <i*L -(L/2-RADIUS)+2*(L/2-RADIUS)*rand(RS), RADIUS, j*L -
(L/2-RADIUS)+2*(L/2-RADIUS)*rand(RS)>
pigment {rgb 1}
#local j=j+1;
#local i=i+1;
The pitfall of this approach is that not always it's that easy to get a reasonably
random look (you can try increasing the maximum translation amount till you can
observe clear intersections).
There's almost no parsing time...
quiet
> > dreams... :-|
You mean an external language (like C)? That would make it faster and simpler, but
you would lose flexibility.
Jonathan.
Date: 16 Apr 2002 18:06:13
Message: <3cbca055@news.povray.org>
"JRG" wrote:
> #declare N = 400;
Oops, as I said that should be:
#declare L = 2*max_radius+ delta;
No real harm done here. It's like:
#declare L = 2*0.3 + 0.7;// 2*max_radius + epsilon.
Jonathan.
Date: 17 Apr 2002 02:44:35
Message: <576qbu0hc4edbpghq6vodc2ncv2eequb77@4ax.com>
On Tue, 16 Apr 2002 19:26:01 +0200, "Jan Walzer" <jan### [at] lzernet>
>faster ...
Use an oct-tree like POV does for bounding slabs.
Peter Popov ICQ : 15002700
Date: 17 Apr 2002 02:56:28
Message: <3cbd1c9c$1@news.povray.org>
"Jan Walzer" <jan### [at] lzernet> schrieb im Newsbeitrag
news:3cbc990e@news.povray.org...
jitter this
And it works very well. Look in p.b.i for my test render of 50.000 spheres.
I made a array of 500x500 squares. In every square there can only be 1
sphere. After detecting a free square I translated the sphere randomly
within the square and marked the square as loaded. That's it. Here is some
code:
// Initialising the array
#declare gitter = array[501][501];
#declare array_help_x = 0;
#declare array_help_z = 0;
#while (array_help_x < 501)
        #while (array_help_z < 501)
                #declare gitter[array_help_x][array_help_z] = 0;
                #declare array_help_z = array_help_z + 1;
        #declare array_help_x = array_help_x + 1;
#declare i = 1;
#declare zufall = seed(123456);
#while (i < 50000)
        // Find a square to start
        #declare neu_x = floor(500*rand(zufall)+0.5);
        #declare neu_z = floor(500*rand(zufall)+0.5);
        // If the square is loaded, find another one
        #while (gitter[neu_x][neu_z] = 1)
        // Mark the square as loaded
        #declare gitter[neu_x][neu_z] = 1;
        // Random radius
        #declare neu_radius = 0.5*rand(zufall);
        // Creating the sphere
        sphere
                <neu_x+2*(0.5-neu_radius)*rand(zufall)-(0.5-neu_radius),
neu_radius, neu_z+2*(0.5-neu_radius)*rand(zufall)-(0.5-neu_radius)>,
neu_radius
                texture
                        pigment
                                color rgb <1, 1, 0>
        #declare i = i + 1;
Date: 17 Apr 2002 04:25:30
Message: <3cbd317a$1@news.povray.org>
yeah ... interesting technique ...
how well will this work with
different sized spheres ?
would this mean that I have to
mark some adjacent boxes as
loaded ?
