POV-Ray : Newsgroups : povray.advanced-users : Odd antialiasing behaviour Server Time
29 Sep 2024 20:19:27 EDT (-0400)
  Odd antialiasing behaviour (Message 1 to 10 of 16)
Subject: Odd antialiasing behaviour
Date: 2 Apr 2002 11:27:42
Message: <3ca9dbfe@news.povray.org>
I don't understand the huge difference between using +a0.0 and any value
above 0.0.
  Consider this simple scene:
camera { location -z*10 look_at 0 angle 35 }
light_source { <1000,2000,0>, 1 }
plane
{ y,-1 pigment { checker rgb <1,1,.5>, rgb <.8,.4,.2> }
  rotate <-10,30,-30>
  When I rendered it with +a0.01 +am2 +r4, the resulting image is the
following:
http://www.cs.tut.fi/~warp/aa1.jpg
  There are big visible artifacts.
  However, when I rendered it with +a0.0 +am2 +r4, the result is almost
perfect:
http://www.cs.tut.fi/~warp/aa2.jpg
  It doesn't seem to matter how small the threshold value is. If it's larger
than 0, it will cause the artifacts.
  I don't understand why.
Subject: Re: Odd antialiasing behaviour
Date: 2 Apr 2002 12:12:57
Message: <itoc8a.e72.ln@linux.local>
>   value
> above 0.0.
The huge difference is: With +a0.0 every pixel is sampled, with any
value above only pixels which differ to their neighbours are sampled.
> plane
>   rotate <-10,30,-30>
> following:
>   almost
> perfect:
>   larger
These artifacts appear because it's coincidence (in that image area)
which color any pixel has and if two pixels differ or not.
If they differ, samples are taken and it looks as it should look. But
if they don't differ not the mixed color is used for the pixel but one
of the unmixed colors. So it's coincidence which color any pixel has in
the final image.
To avoid this problem it's neccesary to take more than one sample per
pixel to decide if the pixel must be sampled. So the only workaround
with the current AA methods is to sample every pixel with +a0.0.
Sorry, I don't speak English very well, so please tell me if it was not
understandable.
Felix Wiemann
Date: 2 Apr 2002 12:18:01
Message: <3ca9e7c9@news.povray.org>
  Yes, but if the previous pixel was antialiased, its color will differ
from the next pixel no matter where does the ray hit the plane in this
next pixel. The color of the previous pixel is a mix between the light and
dark colors of the plane, and thus is very different from either.
  This would mean that if the pixel at the left of each row is antialiased,
all the pixels in that row should be antialiased as well (because each time
a pixel is antialiased its color will differ radically from the next pixel
regardless of where does the ray hit).
  This is what I don't understand.
Date: 2 Apr 2002 14:03:04
Message: <3caa0067@news.povray.org>
>   antialiased,
> time a pixel is antialiased its color will differ radically from the next
> pixel regardless of where does the ray hit).
That's how method 1 works. Method 2 does not care about if the previous
pixel were supersampled or not, instead it just looks at the 4 corners. My
method 4/5 does as it also looks at the samples previously taken on the
pixels borders.
- Micha
objects.povworld.org - The POV-Ray Objects Collection
book.povworld.org    - The POV-Ray Book Project
Date: 2 Apr 2002 14:26:42
Message: <3caa05f2@news.povray.org>
So ! what is, for most power-user, the best antialiasing setting for the
final render ? I'm still searching for a good method to render the final
image of most of my scenes... (good antialiasing without blur...?!)
3caa0067@news.povray.org...
and
> >   antialiased,
next
> pixels borders.
> - Micha
Date: 2 Apr 2002 14:49:32
Message: <3caa0b4c@news.povray.org>
  The one I used in the second image.
  The bad thing about it is that it's slow.
Date: 2 Apr 2002 14:55:34
Message: <3caa0cb6@news.povray.org>
                         ^^^^^^^^^^--considering this...
.. you can use: +A0.0 +AM2 +J0.78 +R9 ....
Date: 2 Apr 2002 15:02:05
Message: <3caa0e3d@news.povray.org>
you used +AM2 +R9 ? ... wow ...
Date: 2 Apr 2002 15:33:27
Message: <3caa1597@news.povray.org>
  Eh? No. I used +r4.
Date: 2 Apr 2002 15:34:25
Message: <3caa15d1@news.povray.org>
  And wait a year for the image to finish?
  I think +r4 should be enough.
