POV-Ray : Newsgroups : povray.advanced-users : Odd antialiasing behaviour Server Time
18 May 2026 01:16:20 EDT (-0400)
  Odd antialiasing behaviour (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Odd antialiasing behaviour
Date: 2 Apr 2002 14:55:34
Message: <3caa0cb6@news.povray.org>
"_Light_Beam_" <fac### [at] aolcom> wrote:
> So ! what is, for most power-user, the best antialiasing setting for the
                         ^^^^^^^^^^--considering this...
> final render ? I'm still searching for a good method to render the final
> image of most of my scenes... (good antialiasing without blur...?!)
.. you can use: +A0.0 +AM2 +J0.78 +R9 ....
Date: 2 Apr 2002 15:02:05
Message: <3caa0e3d@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote:
>   The one I used in the second image.
>   The bad thing about it is that it's slow.
you used +AM2 +R9 ? ... wow ...
Date: 2 Apr 2002 15:33:27
Message: <3caa1597@news.povray.org>
  Eh? No. I used +r4.
Date: 2 Apr 2002 15:34:25
Message: <3caa15d1@news.povray.org>
  And wait a year for the image to finish?
  I think +r4 should be enough.
Date: 2 Apr 2002 15:49:57
Message: <3caa1974@news.povray.org>
This causes about 262'000 samples to be taken for each pixel...
objects.povworld.org - The POV-Ray Objects Collection
book.povworld.org    - The POV-Ray Book Project
Date: 2 Apr 2002 17:20:47
Message: <3CAA2EC1.9F89C104@luxlab.com>
> final render ?
I like this:
Render at 300% resolution +am1 +a0.1 +r5 +j20
and bicubic resample to final size.
Warp's test scene rendered 3.5 times faster + 5 seconds
in spent Photoshop. http://luxlab.com/tmp/aa_3x.jpg
_____________
Kari Kivisalo
Date: 2 Apr 2002 17:24:12
Message: <3caa2f8b@news.povray.org>
Kari Kivisalo wrote:
>> final render ?
> I like this:
Can you try this scene?:
camera{
location<0,0,-20>
look_at 0
angle 40
sphere{0,5
pigment{
gradient y
pigment_map{
[0 rgb 0.5]
[0.5 rgb .5]
[0.5 rgb 1]
[1 rgb 1]
scale .05
translate -10}
rotate z*-33
finish{ambient 1 diffuse 0}
Date: 3 Apr 2002 05:16:21
Message: <3caad675@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag news:3caa15d1@news.povray.org...
probably not enough, if dealing with 16Bit/Chan images ...
... but: Yes, R9 is probably overkill ...
Date: 3 Apr 2002 06:59:45
Message: <3caaeeb0@news.povray.org>
  I don't understand how the color depth would have any influence in the
need to shoot more rays.
Date: 3 Apr 2002 08:47:12
Message: <3cab07e0@news.povray.org>
really ?
If you use +r4 there will be shoot 256 (+AM2) samples per pixel (at max) ...
... this will mean, that this very pixel has a granted accuracy of 1/256 (in
the worst case) ...
... probably enough for a 8Bit/Channel image, as you can't store any more ...
however, in a 16Bit/Channel image, you may want to have the accuracy of at
least 16Bit...
.. this means, however, that you'll need (for the worst case), to shoot 65535
Samples per pixel...
... and this means, you'll need +R8 ...
