POV-Ray : Newsgroups : povray.advanced-users : "Sandy" texture to scattering media Server Time
16 Mar 2026 04:01:32 EDT (-0400)
  "Sandy" texture to scattering media (Message 1 to 7 of 7)
Subject: "Sandy" texture to scattering media
Date: 7 Mar 2002 10:52:42
Message: <3c878cca$1@news.povray.org>
I'm trying to use scattering media inside a translucent sphere in order to
see various points of light inside the sphere as glowing orbs. (In case
you're wondering, I'm trying to model the "Christmas light" effect of the
bussard collector domes in the original starship Enterprise.)
Although this works, I'm having a problem with the scattering media looking
very grainy or sandy. Can someone please post a quick pointer on how to
adjust the apparent density of the media? I've tried to understand the
obtuse documentation on this subject and I'm pulling out what little is left
of my hair. ;)
Thanks!
Scott Gammans
Subject: Re: "Sandy" texture to scattering media
Date: 7 Mar 2002 11:29:12
Message: <3C879572.D3E84AF2@gmx.de>
If you're using Povray Beta, you could try
and add method 3 intervals 1 to the
media description. This turns the adaptive
sampling method on.
If you want some more control,
use method 2 with at least 20 intervals. If
its not detailed enough, use more intervals.
Method 1 (the POV-Ray 3.1 media-type)
is almost always grainy, so you'd have to go
for some dozens of intervals (60? 70? 200?)
Tim Nikias
Date: 7 Mar 2002 11:37:11
Message: <3c879737$1@news.povray.org>
Hmm.. already tried increasing the intervals *and* method 1... all it seemed
to do was slow down the rendering time even further.
I am indeed using POV-Ray 3.5 beta 12. I guess I should post a code example
to show what I'm doing right now...
#declare Bussard_Collector_Dome_Interior = interior {
     ior 1
     fade_distance 1
     fade_power 1001
     fade_color rgb <0.9,0.9,0.9>
     media {
          intervals 10
          samples 3,10
          confidence 0.99
          variance 0.1/128
          ratio 1
          scattering {2,   rgb<0.45,0.3,0.25>}
          method 2
          jitter 0
          density {spherical  scale 7.5}    // radius of dome is 7.5
thanks...
Scott Gammans
"Tim Nikias" <tim### [at] gmxde> wrote in message
news:3C879572.D3E84AF2@gmx.de...
> sampling method on.
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
Date: 7 Mar 2002 11:49:22
Message: <chrishuff-32A48F.11493207032002@netplex.aussie.org>
In article <3c878cca$1@news.povray.org>,
> of my hair. ;)
For such a simple effect, you don't really need scattering media, you
should do fine with emitting media and a spherical density, which will
be faster. The grainy look is caused by the sampling method, you can
reduce it by using more samples, or use method 2 or 3 in MegaPOV or
POV-Ray 3.5.
Date: 7 Mar 2002 11:53:42
Message: <3c879b15@news.povray.org>
> sampling method on.
  But method 3 is the default in POV-Ray 3.5. You don't need to explicitly
add it.
Date: 7 Mar 2002 11:54:17
Message: <chrishuff-C88730.11542707032002@netplex.aussie.org>
In article <3c879737$1@news.povray.org>,
You only need 1 or 2 intervals, POV will make more as needed. Instead,
increase the number of samples taken per interval, try "intervals 1
samples 15" with "method 3".
Date: 7 Mar 2002 15:35:00
Message: <3c87cef4$1@news.povray.org>
D'oh! I didn't realize that you could have multiple media statements inside
an interior declaration. Your technique works so much better... and renders
orders of magnitude faster.
http://www.scottgammans.com/cgi_enterprise/scattering_media.jpg
http://www.scottgammans.com/cgi_enterprise/emitting_media.jpg
That first render using scattering media took nearly two hours to complete,
didn't look right, and didn't use anti-aliasing. The second render using
emitting media took less than 2 minutes to complete, looks SO much closer to
what I am trying to achieve, and even threw in AA 0.3 for good measure.
Those damn Bussard collector domes have been giving me fits... your advice
was right on target. Thanks Christopher!! :)
--Scott Gammans
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> POV-Ray 3.5.
