POV-Ray : Newsgroups : povray.advanced-users : Random rotation don't work ? Server Time
16 Jun 2026 09:02:26 EDT (-0400)
  Random rotation don't work ? (Message 1 to 10 of 18)
Subject: Random rotation don't work ?
Date: 6 Mar 2002 07:20:40
Message: <3c860998@news.povray.org>
I'm trying to make random rotation of random placed box.... the random
fonction works with" translate" but rotate doesn't seem to work... why ?
The code :
// Essai sur les macros...
#declare kub = box {<-0.1, -0.1, -0.1><0.1, 0.1, 0.1>
                 pigment {color rgb <0.5, 0.0, 0.5>}
                 finish {ambient 0.3
                         diffuse 0.5
                         reflection {0.0, 1 fresnel on}}
light_source {
             <10, 5, -10>
             color rgb 1
#declare R1 = seed(360);
// 1 unit random moving
#declare R3 = seed(1);
#declare i = 0;
 #while (i < 2001)
  object {kub translate <rand(R3), rand(R3), rand(R3)> rotate <rand(R1),
rand(R1), rand(R1)>}
 #declare i = i + 1;
       location <3, 0, 0>
       look_at <0, 0, 0>
Subject: Re: Random rotation don't work ?
Date: 6 Mar 2002 07:27:05
Message: <3C860B52.E444F09A@aicoss.de>
What exactly do you mean by "does not work"?
Remember, rotations always occur around <0,0,0>
Markus
Date: 6 Mar 2002 07:28:09
Message: <em2c8ucfg1rhah4g5be4ru0hnpp7ntuufk@4ax.com>
On Wed, 6 Mar 2002 13:21:41 +0100, "_Light_Beam_" <fac### [at] aolcom> wrote:
Parameter of seed has nothing to do with angle.
360 should be placed here:
> rotate <rand(R1),>rand(R1), rand(R1)>}
rotate 360*<rand(R1),rand(R1), rand(R1)>
ABX
disc{z,-z 5#macro O()asc(substr("-+((1*(,1,/.-,*/(,&.323/'1"e,1))*.1-4#declare
e=e-1;#end#local e=26;pigment{#local g=function(_){ceil(_)-_}function#local//X
k=function{pattern{object{sphere_sweep{linear_spline 13#while(e>0)<O(),O()//AB
>.01#end}}}}{k(g(atan2(x,y)),g(ln((y+x)^2+1e-5)),0)}}finish{ambient 1}}//POV35
Date: 6 Mar 2002 08:20:42
Message: <3c8617aa@news.povray.org>
seed is just an initialisation of the random-number-generator.
to create a random number use following structure:
#local R1 = seed(45345);
// the number has no further meaning. you may use anything
// note that different randoms generated from the same seed value, produce
synchronously the same numbers
#local random = rand(R1);
// this is the actual random number
// to rotate something you may use:
// rotate <rand(R1), rand(R1), rand(R1)>
regards
SY
Date: 6 Mar 2002 17:22:34
Message: <3c8696aa@news.povray.org>
rand produces numbers between 0 and 1 so you are basically rotating between
0 and 1 degree.
Try this:
rotate<rand(R1)*360, rand(R1)*360, rand(R1)*360>
"_Light_Beam_" <fac### [at] aolcom> wrote in message
news:3c860998@news.povray.org...
> The code :
>          texture {
>                  finish {ambient 0.3
>                          diffuse 0.5
> light_source {
>              <10, 5, -10>
>              color rgb 1
> #declare i = 0;
>  #while (i < 2001)
>  #declare i = i + 1;
> #end
> camera {
>        location <3, 0, 0>
>        look_at <0, 0, 0>
Date: 7 Mar 2002 01:49:58
Message: <3c870d96$1@news.povray.org>
Hi again,
Errr.. I forgot: rand returns a float in range of 0..1, so you should rather
use
> // rotate <360*rand(R1), 360*rand(R1), 360*rand(R1)>
Sorry.
regards
SY
Date: 7 Mar 2002 11:40:10
Message: <chrishuff-519ADF.11402007032002@netplex.aussie.org>
In article <3c870d96$1@news.povray.org>,
> use
Or even better:
rotate 360*< rand(R1), rand(R1), rand(R1)>
Date: 7 Mar 2002 11:52:08
Message: <3c879ab8@news.povray.org>
> Or even better:
  Note that this does not achieve *any* possible orientation the object can
have. For example, I think that it can never reach an orientation like
caused by
  rotate y*30 rotate x*30
  In order to really achieve almost any possible orientation, that random
rotation should be applied several times. Perhaps even a random number of
times. For example:
#declare RotTimes = 5+5*rand(R1); // from 5 to 10 times.
#declare Ind = 0;
#while(Ind < RotTimes)
  rotate 360*<rand(R1),rand(R1),rand(R1)>
  #declare Ind = Ind+1;
Date: 7 Mar 2002 11:58:50
Message: <chrishuff-109CA0.11590007032002@netplex.aussie.org>
In article <3c879ab8@news.povray.org>, Warp <war### [at] tagpovrayorg>
> times. For example:
I think a better way would just be to generate a random point on the
surface of a sphere (using VRandOnSphere()) and use the PointAtTrans()
macro. Probably should rotate by a random amount around the y axis first.
Date: 7 Mar 2002 12:25:12
Message: <3c87a278$1@news.povray.org>
can
> caused by
> times.
I believe all orientations are covered by just
rotate 360*<rand(R1),rand(R2),rand(R3)>
I'm pretty sure that takes care of all orientations. Whether or not they're
all equally likely is another question.
(Here's why I think that covers everything. Just the point <1,0,0> around
the y axis and then around the z axis randomly gives it the possibility of
pointing in any possible direction. If you're working with an object, and
you rotate it around the x axis, you sort of spin it in any possible
orientation. Then rotating it around the y and z axis like you did with the
point makes it point in a random direction.)
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
