POV-Ray : Newsgroups : povray.advanced-users : Random rotation don't work ? Server Time
18 May 2026 02:35:02 EDT (-0400)
  Random rotation don't work ? (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Random rotation don't work ?
Date: 7 Mar 2002 11:58:50
Message: <chrishuff-109CA0.11590007032002@netplex.aussie.org>
In article <3c879ab8@news.povray.org>, Warp <war### [at] tagpovrayorg>
wrote:
>   In order to really achieve almost any possible orientation, that random
> rotation should be applied several times. Perhaps even a random number of
> times. For example:
I think a better way would just be to generate a random point on the
surface of a sphere (using VRandOnSphere()) and use the PointAtTrans()
macro. Probably should rotate by a random amount around the y axis first.
Date: 7 Mar 2002 12:25:12
Message: <3c87a278$1@news.povray.org>
>   Note that this does not achieve *any* possible orientation the object
can
> have. For example, I think that it can never reach an orientation like
> caused by
>   rotate y*30 rotate x*30
> times.
I believe all orientations are covered by just
rotate 360*<rand(R1),rand(R2),rand(R3)>
I'm pretty sure that takes care of all orientations. Whether or not they're
all equally likely is another question.
(Here's why I think that covers everything. Just the point <1,0,0> around
the y axis and then around the z axis randomly gives it the possibility of
pointing in any possible direction. If you're working with an object, and
you rotate it around the x axis, you sort of spin it in any possible
orientation. Then rotating it around the y and z axis like you did with the
point makes it point in a random direction.)
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 7 Mar 2002 12:43:41
Message: <3c87a6cd@news.povray.org>
  So give me a "rotate <A,B,C>" command which, when replacing the two rotates
with it in the scene below, will give the exact same image:
camera { location <1,2,-3> look_at y*.5 angle 35 }
light_source { <100,250,-50>, 1 }
plane { y,0 pigment { checker rgb 1, rgb .5 } }
#declare Object =
  intersection
  { cone { 0,.5, y,.2 }
    box { <-.5,-.01,0><.5,1.01,.5> }
    pigment { rgb x+y }
object
{ Object
  rotate y*45 rotate x*45
Date: 7 Mar 2002 14:34:41
Message: <3C87C127.DA94FE0A@engineer.com>
I believe this is close enough. Don't have time to calculate
the exact transform.
rotate<53,30,35>
_____________
Kari Kivisalo
Date: 7 Mar 2002 15:02:16
Message: <3c87c747@news.povray.org>
Kari Kivisalo <ray### [at] engineercom> wrote:
> rotate<53,30,35>
  I didn't think of it that way.
  Is any combination of free rotates achievable with a rotate <A,B,C>?
Somehow it's very hard to grasp.
  Some kind of intuitive, graphical or mathematical proof could help.
Date: 7 Mar 2002 15:40:42
Message: <3C87D09D.C7CACAF6@engineer.com>
I think it was Euler who proved that any orientation in space could be
represented by a single rotation about an arbitrary axis, and that this
rotation is equivalent to three successive rotations about the x, y and
z axes.
_____________
Kari Kivisalo
Date: 7 Mar 2002 16:14:56
Message: <3c87d850@news.povray.org>
  That's even more radical!
  But thinking hard about it, it starts to be intuitive...
Date: 9 Mar 2002 18:25:16
Message: <3c8a99dc@news.povray.org>
let me summarize this please, to understand this  ...
We proved Warp, to be wrong ?
Date: 10 Mar 2002 06:01:19
Message: <3c8b3cfe@news.povray.org>
  So?
Date: 10 Mar 2002 09:14:05
Message: <3C8B6A85.EFDAA7E6@engineer.com>
But it was educational. It was the 1st time I tried in practice
an abstract piece of information learned long time ago. If Warp
hadn't asked the question I wouldn't have learned that arbitrary
orientation can be also defined as x y x rotation. When building
a robot this might be good to know :)
_____________
Kari Kivisalo
