For an animation I'm making I need a special lens-like shape that have
certain properties. It should be kind of like a flattened sphere, or
actually more like a union between a torus and a cylinder (because it should
have a flat area), but without abrupt changes in curvature.
See the image in povray.binaries.images.
I don't think any CSG will do the trick, but maybe someone can come up with
an isosurface function that'll work? Or something different.
Thanks in advance!
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Feb 16)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
I found a function myself that works. I use this function in an isosurface
which I scale by <1,1,0.2>. However, is it possible to make it faster?
(sqrt(max(0,sqrt(x^2+y^2)*2-1)^4+z^2)-1)
Rune
I don't see why the union of a cylinder and a torus doesn't meet your
requirements. If I'm not mistaken, the derivatives of the surfaces of the
cylinder and the torus (if done correctly) should be equal at the
intersection, so there shouldn't be any abrupt changes in the smoothness of
both surfaces.
Or perhaps I'm misunderstanding your wishes...
Fernando.
"Rune" <run### [at] mobilixnet dk> wrote in message
news:3c824c95@news.povray.org...
> Rune
> 3D images and anims, include files, tutorials and more:
In article <3c82f3e2@news.povray.org>,
> both surfaces.
But the derivative of the derivative is discontinuous there...the rate
of change in curvature changes abruptly. It transitions from an almost
constantly curving surface to a completely flat surface. This change is
easy to see in the shading.
Christopher James Huff <chr### [at] mac com>
POV-Ray TAG e-mail: chr### [at] tag povray org
OK, now I understand that you're speaking about curvature and not
smoothness!
I didn't know that a change in curvature, in smooth surfaces, could be
easily detected in shading.
Pity I couldn't help...
Fernando.
"Christopher James Huff" <chr### [at] mac com> wrote in message
news:chr### [at] netplex aussie org...
the
of
> > both surfaces.
I've never seen a proof of this, but I'm 99% sure that it is physically
impossible to have a function with both infinitely continuous derivatives
*and* a perfectly flat spot, unless the entire function itself is flat.
If you only need the first and second derivatives to be continuous, and you
don't care about the third derivative, that can be done...
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
