POV-Ray : Newsgroups : povray.advanced-users : request for special lens-like shape Server Time
29 Sep 2024 20:16:05 EDT (-0400)
  request for special lens-like shape (Message 1 to 6 of 6)
Subject: request for special lens-like shape
Date: 3 Mar 2002 07:26:27
Message: <3c821673@news.povray.org>
For an animation I'm making I need a special lens-like shape that have
certain properties. It should be kind of like a flattened sphere, or
actually more like a union between a torus and a cylinder (because it should
have a flat area), but without abrupt changes in curvature.
See the image in povray.binaries.images.
I don't think any CSG will do the trick, but maybe someone can come up with
an isosurface function that'll work? Or something different.
Thanks in advance!
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Feb 16)
Subject: Re: request for special lens-like shape
Date: 3 Mar 2002 11:17:25
Message: <3c824c95@news.povray.org>
I found a function myself that works. I use this function in an isosurface
which I scale by <1,1,0.2>. However, is it possible to make it faster?
(sqrt(max(0,sqrt(x^2+y^2)*2-1)^4+z^2)-1)
Rune
Date: 3 Mar 2002 23:11:14
Message: <3c82f3e2@news.povray.org>
I don't see why the union of a cylinder and a torus doesn't meet your
requirements. If I'm not mistaken, the derivatives of the surfaces of the
cylinder and the torus (if done correctly) should be equal at the
intersection, so there shouldn't be any abrupt changes in the smoothness of
both surfaces.
Or perhaps I'm misunderstanding your wishes...
Fernando.
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3c824c95@news.povray.org...
> Rune
> 3D images and anims, include files, tutorials and more:
Date: 4 Mar 2002 00:29:55
Message: <chrishuff-5890D0.00295904032002@netplex.aussie.org>
In article <3c82f3e2@news.povray.org>,
> both surfaces.
But the derivative of the derivative is discontinuous there...the rate
of change in curvature changes abruptly. It transitions from an almost
constantly curving surface to a completely flat surface. This change is
easy to see in the shading.
Date: 4 Mar 2002 01:50:10
Message: <3c831922@news.povray.org>
OK, now I understand that you're speaking about curvature and not
smoothness!
I didn't know that a change in curvature, in smooth surfaces, could be
easily detected in shading.
Pity I couldn't help...
Fernando.
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
the
of
> > both surfaces.
Date: 5 Mar 2002 18:46:23
Message: <3c8558cf$1@news.povray.org>
I've never seen a proof of this, but I'm 99% sure that it is physically
impossible to have a function with both infinitely continuous derivatives
*and* a perfectly flat spot, unless the entire function itself is flat.
If you only need the first and second derivatives to be continuous, and you
don't care about the third derivative, that can be done...
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
