POV-Ray : Newsgroups : povray.advanced-users : Palm trees from primatives Server Time
18 May 2026 02:33:28 EDT (-0400)
  Palm trees from primatives (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Palm trees from primatives
Date: 8 Feb 2002 22:08:43
Message: <3c6492bb@news.povray.org>
"Wanderer On The Road" <non### [at] fakeaddresscom> wrote in message
news:3c648bca@news.povray.org...
> Interesting. I've tried to do some stuff with #while and failed. Before
and
> I'm interestid in this spline() function in 3.5 I'm assuming that it's
> documented. Any good tutorials for that sort of thing? Oh and if it makes
> any difference this will be appear in a painting with in the scene.
You are going to model something that will be 2D?  Or were you going to use
a ready-made photo?  If the latter, image_map is all you'd need.
Yes, in the beta of 3.5 and MegaPOV, both have splines.  It isn't very
difficult to use at all.  Just a list of points (vectors) with a time value
attached to each, then when you run a variable through it via clock or loop
it increments according to that.  Interpolating a series of vectors called
by MySpline(Time) for example which in reality is <1,2,3> format as
recognized by the keyword you apply it with, i.e. translate MySpline(Move)
[those words being whatever you declare them to be, of course].  Move would
be the clock or loop variable.
See section 6.1.9 of the v3.5 docs.
I thought that was available online separately but I fail to find it now.
Check out the creators (I think he is anyway) tutorial on it:
http://pandora.inf.uni-jena.de/p/e/noo/povsp/use.html
bob h
Date: 11 Feb 2002 22:30:01
Message: <3c688c39@news.povray.org>
"bob h" <omn### [at] charternet> wrote in message
news:3c6492bb@news.povray.org...
> and
makes
use
Modeling something that will be 2D-ish. See my plan is to make a scene that
will then be image_mapped on to an object (in this case a painter's canvas).
value
loop
would
hrm.... Any good tutorials on how to use #while?
Thanks. I'll look into it.
Much thanks.
     Many religions are the story of man trying to reach out to God
     Christianity is the story of God trying to reach out to man.
Date: 12 Feb 2002 03:33:59
Message: <3c68d377$1@news.povray.org>
news:3c688c39@news.povray.org...
that
canvas).
http://www.students.tut.fi/~warp/povVFAQ/whileloops.html
That should do nicely if you can be a little technical about it, since Warp
can often be I know :-)
Yeah, the render within a render can be pretty neat, as many online
galleries can attest to.
bob h
Date: 12 Feb 2002 08:19:17
Message: <3C6916FA.B63993EF@pacbell.net>
There is a good basic introduction to loops at this site in the povabilities
section - http://www.spake.org/rtimes/
Ken Tyler
Date: 16 Feb 2002 00:39:48
Message: <3c6df0a4@news.povray.org>
news:3c68d377$1@news.povray.org...
> that
> canvas).
Warp
Well since I'm often accused (usualy correctly) of thinking too much I bet I
can figure it out ^_~
Yes, though is there anything I can do to the painting scene that will make
it look slightly unfinished with out resorting to post trace effects in like
the gimp?
Date: 16 Feb 2002 08:59:11
Message: <3c6e65af@news.povray.org>
news:3c6df0a4@news.povray.org...
make
like
> the gimp?
Any number of things are possible I suppose.  One thing that comes to mind
is material_map to take the rendered image and make incomplete parts to it,
hence unfinished.  Likewise by using a patterned layered texture with
image_map(s) as the main pigment.
Getting a oil painting look to it wouldn't be difficult, making different
brush stroke effects for each color region.  Kind of an in-POV Photoshop
filter effects just by applying various normals and finishes for those color
regions.
bob h
Take a look at this simplified form of that:
  location  -2*z
  look_at   0
light_source {
  0,1
  translate <-5, 5, -30>
// textures for material map
#declare T0=texture {pigment {rgb 0}}
#declare T1=texture {pigment {rgb <0,1,0>}
 normal {wrinkles 0.25 scale 0.025}
  finish {specular 0.4 roughness 0.01}}
#declare T2=texture {pigment {rgb <1,1,0>}
 normal {granite 0.125 scale 0.125}
  finish {specular 0.2 roughness 0.025}}
#declare T3=texture {pigment {rgb <1,1,1>}
 normal {bumps 0.1 scale 0.1}
  finish {specular 0.3 roughness 0.0125}}
#declare T4=texture {pigment {rgb <0,1,1>}
 normal {marble 0.1 scale 0.1 turbulence 1}
  finish {specular 0.5 roughness 0.005}}
#declare T5=texture {pigment {rgb 1}}
plane {
  z, 0
      material_map {
        png "materialmap.png" // 256 color bitmap (of your rendering)
        once
        interpolate 2
        texture {T0} // index 0
       #declare Index=1;
       #while (Index<25)
        texture {T1}
       #declare Index=Index+1;
       #while (Index<100)
        texture {T2}
       #while (Index<150)
        texture {T3}
       #while (Index<255)
        texture {T4}
        texture {T5} // index 255
      translate -0.5
      scale <4/3,1,1>*2
To get better resolution of colors and textures into your image you'll need
to increase the number of entries.
Date: 16 Feb 2002 17:02:44
Message: <3c6ed704@news.povray.org>
news:3c6e65af@news.povray.org...
> make
> like
> > the gimp?
it,
color
> regions.
Ok I'll look into that after I choose a palm leaf method. Did OE nuke the
thread or did the server? I can't seem to find the beginning few posts
anymore.
[snip]
[snip]
need
Is that's what is limiting the material map to 8bit color as opposed to 24
or 32 bit?
Date: 16 Feb 2002 18:42:21
Message: <3C6EEF11.C8ADAA78@pacbell.net>
> Did OE nuke the thread or did the server? I can't seem to find
> the beginning few posts anymore.
OE done it.
Ken Tyler
Date: 16 Feb 2002 22:12:09
Message: <3c6f1f89@news.povray.org>
news:3c6ed704@news.povray.org...
> or 32 bit?
Yep.  That's the downside to this, having to lower a 24 bit image to 8 bit
and thereby reducing the image quality.  You either get banded colors or
dithering.
I was going to use an example which would put the original image underneath
a clear material map so just the normals with specular highlights are
overlayed.  Could still be done that way too I guess, only need a second
object to place the image_map on.  Can't layer textures when material_map is
used, at least I don't think so.
About OE removing messages, check Tools menu, Options then Maintenance.  The
delete after so many days is what does it.
bob h
Date: 20 Feb 2002 21:37:08
Message: <3c745d54@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3C6EEF11.C8ADAA78@pacbell.net...
> OE done it.
Fun, it's still on the server I hope. So like I can nuke this news account
and recreate it and find it again?
