POV-Ray : Newsgroups : povray.advanced-users : Unexpected behavior with modifying texture Server Time
10 Feb 2026 04:23:45 EST (-0500)
  Unexpected behavior with modifying texture (Message 1 to 5 of 5)
Subject: Unexpected behavior with modifying texture
Date: 1 Feb 2002 06:24:04
Message: <3c5a7ad4$1@news.povray.org>
I have a problem with modifying a layered texture. When changing the diffuse
of a layered texture, only one element of the texture is changed, but when
changing the reflection, the whole texture reflects.
Here's an example:
#include "stones.inc"
camera{location z*-2}
light_source{z*-2 rgb 1}
background{1}
plane{-z, 0
   texture{T_Stone25}
   finish{diffuse 2} //reflection
As you will see, the plane is not (as one might expect) bright, but only one
element of the texture. If you delete the finish line, you see the texture
as it is normally. But when you write "reflection" instead of "diffuse", the
white background is reflected by the whole texture!
Can anyone explain this behavior of POV-Ray?
Felix Wiemann
Subject: Re: Unexpected behavior with modifying texture
Date: 2 Feb 2002 07:06:38
Message: <3c5bd64e@news.povray.org>
May I ask:
Have I described the problem properly? Has anyone tested this? Perhaps I'll
post this into beta-test, but I must be sure that there are experienced
users who can't explain this.
Date: 2 Feb 2002 07:12:32
Message: <3c5bd7b0@news.povray.org>
Felix Wiemann wrote:
> May I ask:
> I'll post this into beta-test, but I must be sure that there are
> experienced users who can't explain this.
  This is nomal behavior: the top layer has clear parts which can show up
due to finish properties. Note these clear parts on povray textures still
have a finish: they aren't no-texture zones. You need another aproach to
this, as someone mentioned before: texture_maps!
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 3 Feb 2002 06:47:55
Message: <3c5d236b@news.povray.org>
Thank you! But how can I change the finish of the whole texture (in a
different way than inline or with #default)? Is there a possiblity at all?
Date: 3 Feb 2002 17:29:56
Message: <3c5db9e3@news.povray.org>
  You need to tweak individually each layer. I will start copying the code
from stones.inc and then changing each layer as desired.  Nothing better to
learn than muddling with the examples and standard includes... I never use
any other thing, except the manual when I do not understand the code I'm
looking to.
