POV-Ray : Newsgroups : povray.advanced-users : The Harcore Povrayer Test Server Time
18 May 2026 02:33:44 EDT (-0400)
  The Harcore Povrayer Test (Message 68 to 77 of 77)
Subject: Re: Improved test
Date: 5 Feb 2002 07:37:45
Message: <3C5FD212.DB973BB7@namtar.qub.ac.uk>
Christopher James Huff wrote:
> It isn't hard, just a bunch of spheres and cylinders in a loop and some
> transformations. Basically, rotate for the twisting, translate out by
> the diameter of the ring, and rotate to the position on the ring.
> Christopher James Huff <chr### [at] maccom>
> POV-Ray TAG e-mail: chr### [at] tagpovrayorg
> TAG web site: http://tag.povray.org/
Oh, I thought maybe it was a general macro for DNA following a curve. I
was gonna use it in my IRTC entry, but I've changed my subject now, on
advice from my brother. Which reminds me; I have a lot of work to do!
(and less than a month to do it in!)
Thanks anyways!
signature{
Subject: Re: The Harcore Povrayer Test
Date: 5 Feb 2002 17:13:21
Message: <3C6058DB.943ECD14@spiritone.com>
Damn, I score between a 20 and a 25. Some questions I give myself half
points for.
Date: 6 Feb 2002 08:30:09
Message: <3c612fe1$1@news.povray.org>
3c5ec2d2$1@news.povray.org...
> ... couldn't you just replace 'em with "you are Gilles Tran" 10 times?
Well, I had to make up my own questions so that I could get at least few
points AND brag  like other people ;-)
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 13 Feb 2002 16:15:22
Message: <3c6ad76a@news.povray.org>
OK, so I admit I'm not anywhere near advanced status, but out of interest
why isn't "difference" a primitive CSG operation (simple answer please!!!)
Is there a Beginner/Intermediate Povrayer Test?
Reuben
doo### [at] breathemailnet
news:3c5977ae@news.povray.org...
>   Some years ago I made a "Hardcore Povrayer Test" just for fun. Here it
is
> again, with small updates.
>   For each statement which you feel is true in your case (be sincere),
take
> one point. The number of points you get is your score. The maximum number
> of points is 65.
>   (My personal score is "only" 37, so it *is* a tough test.)
> * You have participated in the IRTC and got to the top 20 best images.
> * You have won a price in the IRTC.
> * You have made bicubic patches by hand (and they worked as you expected).
> * You have made a pov-script that creates a smooth surface with bicubic
patches
>   using some algorithm.
> * You have made triangle meshes by hand.
> * You have made a pov-script which generates triangle meshes using some
>   algorithm.
> * You have used the quadric, cubic, quartic or poly primitives.
> * You have used poly objects bigger than 4th degree.
> * You have calculated the polynomial for that poly object by yourself
>   (instead of looking at the formula somwhere or just trying random
values).
> * You know the format of a PCM file.
> * You have made one by hand.
> * You have made a program which outputs a df3 file and used it in a scene.
> * You know what a df3 file is and what's its format.
> * You have made a patch for povray.
> * Your patch is included in MegaPov or at least it's popular.
> * Your patch was included in POV-Ray 3.5.
> * You have made a popular tool for povray.
> * You have used every object type, every camera type, every light source
>   type, every media type, etc. and know how to use them.
> * You could write a torus-shaped isosurface by memory, without needing
>   to look anywhere for the function.
> * Even if you don't remember the torus function, you could deduce it by
>   yourself, without looking it anywhere.
> * You know what is the "sturmian root solver" thing which is used with the
>   'sturm' keyword in some objects (ie. you know the algorithm it uses).
> * The intensity multiplier curves and light fading functions in the light
>   source section of the povray manual are very clear and you understand
>   them perfectly (and you might use them to choose your light source
>   types).
> * You understand how photon mapping works (at algorithm level).
> * You have found the 'average normal bug' by yourself in a povray version
>   previous than 3.1e.
> * You know exactly what was causing it.
> * You never include the povray include libraries (like colors.inc) because
>   they slow parsing, but always define your colors, textures, etc by
>   yourself.
> * You only use the png format when working with povray.
> * You always use it with alpha channel.
> * It's very easy to you to make slope maps and actually you often use
>   them to make your textures.
> * You know what the 'use_index' keyword is used for without looking at
>   the manual.
> * You understand the matrix transformation and you can write them by hand.
> * You know how to calculate the matrix from any number of consecutive
>   transformations (translate, scale, rotate).
> * For any given identifier name you can tell by heart if it's a reserved
>   keyword (ie. an illegal identifier name) or not (of course without
having
>   syntax highlighting to help you).
> * You could make any of the Chris Colefax's includes or macros by yourself
>   if you wanted.
> * You use frequency, phase, octaves, omega and lambda without problems
>   when creating your own textures.
> * You can tell what does each one of them do (without looking at the
>   documentation).
> * You understand the scattering function pictures in the media section of
>   the documentation.
> * You remember all the keywords that can be put in a global_settings block
and
>   you know what do they mean and how to use them.
> * Making good-looking radiosity images is not a problem to you.
> * You remember all the built-in float and vector identifiers.
> * You use all the vector and string functions without problem.
> * You know if some special feature is already implemented in the POV-Ray
3.5
>   standard include files (and thus you know you don't have to implement it
>   yourself).
> * Functions, macros, arrays, loops and file-IO directives are a piece of
cake.
> * You never get the "camera is inside non-hollow object" warning. If you
>   ever get it, it's absolutely intentional.
> * You have made a modeller for povray.
> * You often debug your povray code using the text message streams.
> * You can easily calculate the camera parameters when you want to put a
>   box right in front of the camera so that it completely and exactly fills
>   the viewing area.
> * You know which .c and .h files you must change to add a keyword to the
>   parser.
> * You can add a keyword and get it right the first time.
> * You know which .c file contains the functionality for each aspect of
>   the renderer.
> * You can find a bug in the renderer source code given just a description
>   of the symptoms and without using a debugger.
> * You know BOTH reasons why a mesh can't be used in CSG.
> * You know why refraction and media do work with meshes, even though CSG
>   doesn't.
> * You know that 'merge' doesn't have to be a primitive CSG operation
>   and can recite the equivalent sequence of intersections, unions, and
>   inverses.
> * You know that 'difference' isn't a primitive CSG operation and you
>   know how POV represents one internally.
> * You understand how 'bounded_by' _really_ works.
> * You know that a height_field has an inside and how it is defined.
> * You've written your own include file and distributed it on the net. It
has
>   got some popularity.
> * You understand all the options to 'media' without having to look in
>   the manual.
> * You know, without looking at the docs, how antialiasing methods 1 and 2
work
>   and what's their difference.
> * You have made yourself an obfuscated signature in POV-Ray SDL in 4 lines
>   or less, and you use it by default when posting to the POV-Ray news
server.
> * You didn't know the answer to one of the above questions so you tried
>   to find it in the manual.
>   to find it in the source code.
> * You didn't know that 'merge' wasn't a primitive but now that you do
>   you have worked it out for yourself.
> * You are a member of the POV-Team.
> #macro N(D)#if(D>99)cylinder{M()#local D=div(D,104);M().5,2pigment{rgb
M()}}
> N(D)#end#end#macro M()<mod(D,13)-6mod(div(D,13)8)-3,10>#end blob{
> N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}//  -
Warp -
Date: 13 Feb 2002 16:25:10
Message: <slrna6lmdo.rhv.ron.parker@fwi.com>
Because it can be rewritten in terms of more primitive operations.
difference {object{A} object{B}} is the same as
intersection{object{A} object{B inverse}}
In fact, that's how it's actually implemented inside POV.
To answer your next question, merge isn't primitive either.
merge {object{A} object{B}} is the same as
intersection{object{A inverse} object{B inverse} inverse}
but it's not actually implemented that way, for historical reasons (there's
nothing to be gained by rewriting it, so nobody ever did.)
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 13 Feb 2002 16:56:50
Message: <3c6ae122@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: Because it can be rewritten in terms of more primitive operations.
  Who says 'intersection' is more primitive than 'difference'?-)
Date: 13 Feb 2002 17:43:16
Message: <slrna6lr07.s7q.ron.parker@fwi.com>
Apparently, whoever wrote the code for difference. :)
merge {object{A inverse} object{B} inverse} works nicely too.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 14 Feb 2002 01:19:17
Message: <vOH88AA+T1a8Ewt6@econym.demon.co.uk>
Not only is there nothing to be gained by rewriting it, but it would end
up being much less efficient in most cases. The bounding box of a merge
using the current code tends to be a good fit, but the bounding box of
the inverse intersection inverse is usually infinite.
I claim that merge{object{A} object{B}} is more like being the same as
#declare U = union{object{A} object{B}}
   bounded_by{box{min_extent(U),max_extent(U)}}
Mike Williams
Gentleman of Leisure
Date: 6 Mar 2002 17:50:15
Message: <3c869d27$1@news.povray.org>
This sounds interesting - where is the test? (I can't see the original post
for this thread.)
/ Martin
Date: 6 Mar 2002 17:52:06
Message: <3c869d96@news.povray.org>
Oops, don't worry about that post - I found it...
/ Martin
