POV-Ray : Newsgroups : povray.advanced-users : The Harcore Povrayer Test Server Time
18 May 2026 02:33:43 EDT (-0400)
  The Harcore Povrayer Test (Message 11 to 20 of 77)
Subject: Re: The Harcore Povrayer Test
Date: 31 Jan 2002 14:55:54
Message: <Xns91A7D532EF6C9seed7@povray.org>
in news:3c5977ae@news.povray.org Warp wrote:
23,
...and they let me fool around with the docs....
Ingo
Date: 31 Jan 2002 14:57:25
Message: <3c59a1a4@news.povray.org>
Zeger Knaepen <zeg### [at] studentkuleuvenacbe> wrote:
: * You didn't know the answer to one of the above questions so you tried to find
: it in the manual.
: So you get a point for cheating?
  The meaning of that is that you didn't know the answer to some question
and thus you didn't take a point in that question, but it interested you
so much that you tried to find the answer.
Date: 31 Jan 2002 15:00:49
Message: <3c59a271@news.povray.org>
Warp wrote:
>   Some years ago I made a "Hardcore Povrayer Test" just for fun.
  Hmmm... only 21, and cheating a bit! Hardcore is not for me... I will
better keep listening groove.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 31 Jan 2002 15:10:01
Message: <3C59A485.39D4EB53@gmx.de>
Warp wrote:
>   Some years ago I made a "Hardcore Povrayer Test" just for fun. Here it is
> again, with small updates.
>   For each statement which you feel is true in your case (be sincere), take
> one point. The number of points you get is your score. The maximum number
> of points is 65.
>   (My personal score is "only" 37, so it *is* a tough test.)
30, but with some questions i had doubts about the answer (and then
answered 'no').
A lot of questions are not very good, i picked out a few of them:
> * You never include the povray include libraries (like colors.inc) because
>   they slow parsing, but always define your colors, textures, etc by
>   yourself.
This is total crap of course, esp. with Povray 3.5
> * You only use the png format when working with povray.
Why does this qualify for a hardcore Pover?
> * You have made a modeller for povray.
Can you define 'modeller' please?
> * You know BOTH reasons why a mesh can't be used in CSG.
What is the second one?
I also have some suggestions:
* You have written isosurface functions by hand with more than X
characters (for 'X' use a reasonable value, for example 2000)
* You know the parameters of every internal function of Povray 3.5
(functions.inc) without looking it up. (that's a really hard one, maybe
just knowing every function is enough...)
* Your longest render was more than X days (X=5, 10, 20 or more)
Date: 31 Jan 2002 15:12:39
Message: <3c59a537$1@news.povray.org>
25 ...
damn ...
maybe additional point for:
"you don't know .... but you know exactly where to find it in the docs ?"
#macro J(N A)#local a=mod(N 3);#local W=<int(mod(A,4)*2)int(-A/4)9>*2;#if
(!mod(a 2))sphere{W,2,2pigment{color rgb<a*5A/2W.x/A*5>}}#if(a<1)sphere{W
+<2,0>2 2pigment{color rgb<a*10A 10>}}#end#end#if(N>3)J(int(N/3)A+1)#end#
end blob{J(29229171 0)threshold 1translate<-6 3>}/******Jan Walzer******/
Date: 31 Jan 2002 15:22:26
Message: <slrna5j9s3.in.ron.parker@fwi.com>
Oh, sure, we tell you and then you tell someone else and pretty soon
everyone has an extra hardcore point.
It's because (at least in 3.1) All_Mesh_Intersections doesn't actually
return all of the intersections; it just returns the closest one.
I rendered the sample scenes on my old Amiga when I started using POV;
some of those took days to render.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 31 Jan 2002 16:06:19
Message: <3c59b1cb@news.povray.org>
In article <3C59A485.39D4EB53@gmx.de> , Christoph Hormann
Whatever size you pick up to the limit that functions allow, I have created
such a function ...  not that alternating sequences of x-x+y-y+z-z or similar
combinations make a lot of sense ;-)
    Thorsten
e-mail: tho### [at] trfde
Date: 31 Jan 2002 16:08:28
Message: <3C59B235.2B73FBC0@gmx.de>
I only know one reason: There is no 'inside' and 'outside' in a mesh.
This is perfectly sufficient.  The problem with this questions is that you
can answer it on different levels, the logical and the programming level,
of course in the latter you can easily find several reasons.
The idea for this question is that a hardcore Pover devotes more
computational power to render jobs, whether the scene is complicated or
not is not the question IMO.
Date: 31 Jan 2002 16:13:38
Message: <MPG.16c3cab4ad23cad9896be@news.povray.org>
In article <3c5977ae@news.povray.org>, war### [at] tagpovrayorg says...
I didn't pass one single question of the test, so I guess for me it is
0.
Who did worse??
Sander
Date: 31 Jan 2002 16:17:45
Message: <slrna5jd3p.js.ron.parker@fwi.com>
Nope, those two are the only ones I know.  The 'inside' vs. 'outside' thing
is basically programming, too, in the case of meshes where such is defined,
so I don't see the same dichotomy you do here.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
