POV-Ray : Newsgroups : povray.advanced-users : Strange bug in heightfield Server Time
12 Jan 2025 18:51:39 EST (-0500)
  Strange bug in heightfield (Message 1 to 10 of 14)
Subject: Strange bug in heightfield
Date: 21 Jan 2002 09:26:35
Message: <3c4c251a@news.povray.org>
I have noticed that heightfields sometimes present strange bugs which I can't
explain.
  These bugs usually show up as small black areas in certain parts of the
heightfield. These areas are not shadows (no_shadow as no effect on them)
and they depend on the location of the camera (when the the heightfield is
looked from a bit different location, the size of these black areas change or
they disappear).
  Here is an example. Although you can see the bug and the effect of moving
the camera by rendering individual frames with different values of the clock
(between 0 and 1), it's best viewed as an animation (some of the black areas
slowly diminish in size and disappear). Also from the animation it's clearly
seen that they are not shadows.
----------8<----------8<----------8<----------8<----------8<----------
camera
{ location y*.03*clock
  look_at z*1
light_source { <90,90,0>, 1 }
height_field
{ function 900,900 { pattern { granite } }
  smooth
  scale <10,1.5,10>
  pigment { rgb 1 }
  translate -<5,.3,0>
  no_shadow
  Any idea what causes these bugs?
  (I can create a DivX animation if necessary.)
Subject: Re: Strange bug in heightfield
Date: 21 Jan 2002 11:07:44
Message: <3c4c3ccf@news.povray.org>
> or they disappear).
  Hmmm... seems like "missing triangles" to me, they are very coincident
with triangles when you trace it big enough. Also, it seems it is something
to do with smooth, because I can't reproduce it without that keyword.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 21 Jan 2002 13:11:11
Message: <3c4c59bf$1@news.povray.org>
I've not rendered yet, but if it really behaves the way, you describe,
then you can probably trace it down to some accuracy issue ...
[Talking about cardriving]
"People are opstacles?
Oh...I always treat them as bonus points..." [Ian Burgmyer in p.o-t]
// Jan Walzer <jan### [at] lzernet>
Date: 21 Jan 2002 14:31:55
Message: <3c4c6cab$1@news.povray.org>
Warp <war### [at] tagpovrayorg> schrieb in im Newsbeitrag:
3c4c251a@news.povray.org...
can't
> explain.
or
> they disappear).
moving
clock
areas
clearly
I think that the normals are switched because it goes away if you add
double_illuminate.
#local T=text{ttf"timrom.ttf""Simon Adameit".01,0}#local Y=1;#while(Y>-1)
#local X=0;#while(X<7)#local O=trace(T<X,Y><X,Y>+z);cylinder{<X-3,Y,5>*.01
<X-3,Y,5>*.01+5e-3,5e-5pigment{rgb 25*O}}#debug chr(83-(O.x=0)*51)#local
X=X+.05;#end#debug"\n"#local Y=Y-.05;#end
Date: 21 Jan 2002 16:09:13
Message: <3c4c8379@news.povray.org>
:   Hmmm... seems like "missing triangles" to me
  Nope. If you render the animation (eg. 30 frames or more), you clearly see
that it's not a missing triangle which suddenly appears. The black spot
diminishes smoothly until it disappears.
Date: 21 Jan 2002 16:10:22
Message: <3c4c83bd@news.povray.org>
Jan Walzer <jan### [at] lzernet> wrote:
: I've not rendered yet, but if it really behaves the way, you describe,
: then you can probably trace it down to some accuracy issue ...
  It's just that I can't figure out any reason why it happens.
  If the spots were equal independently of camera location it would be
simpler.
Date: 21 Jan 2002 16:11:04
Message: <3c4c83e7@news.povray.org>
Simon Adameit <gom### [at] gmxde> wrote:
: I think that the normals are switched because it goes away if you add
: double_illuminate.
  That sounds like it would look the same independently of the camera location,
but it doesn't...
Date: 21 Jan 2002 16:27:47
Message: <3c4c87d3@news.povray.org>
location,
> but it doesn't...
Then why does it disappear if you add double_illuminate ?
Date: 21 Jan 2002 17:49:09
Message: <3c4c9ae5@news.povray.org>
Try this and you will see that the normals indeed seem to be switched.
camera
{ location #if(0) <0,-0.3,0> #else 0 #end
  look_at z*1
height_field
{ function 200,200 { pattern { granite } }
  smooth
  scale <10,1.5,10>
  pigment {slope y}
  finish{ambient 1}
  translate -<5,.3,0>
Date: 21 Jan 2002 18:34:26
Message: <3c4ca582@news.povray.org>
: Then why does it disappear if you add double_illuminate ?
  'double_illuminate' "fixing" it is a clear symptom that it has something
to do with normals, but what confuses me is that the normals should not
depend on camera location. If the object stays static and the light source
stays static and there's no phong/specular finish, the lighting should remain
the same regardless of the point of view.
