We have trace(), to find the intersection and the normal of any CSG-Object
with rays ...
Also we can compute the value of any 3D-Pattern at a given 3D-Point ...
What I'm missing, is the ability to compute the gradient of a 3D-Pattern at a
given point.
I know, this is not possible for avery pattern on every point ...
But (concerning Isosurfaces) it's done internally in POV...
I know, its done numerically, and depends on a given accuracy ...
I know, I can do this with a macro (is there one out there ?), taking 4
sample points(depending on accuracy)
around the point in question, and applying some maths to them, and one should
get a vector, showing the
gradient...
My question: Do you see any chance, that we can access the internal (faster)
gradient-function of POV
as it is probably the case for trace(), or at least a simple macro (doing
this in SDL-Space) that comes
with functions.inc in Pov3.5 ? ...
I know, it sounds like a feature-request, but there's probably such a macro
already out there, and
it wouldn't hurt, to put it into functions.inc, would it ?
[Talking about cardriving]
"People are opstacles?
Oh...I always treat them as bonus points..." [Ian Burgmyer in p.o-t]
// Jan Walzer <jan### [at] lzer net>
It is possible with type 1 displace warps in megapov, in Povray 3.5 you
can easily make a macro for that (or a function if you only want the
length of the gradient vector), but it would be slower of course, on the
other hand the displace warp code uses 7 evaluations and often 4 would
probably be sufficient.
Christoph Hormann <chr### [at] gmx de>
"Christoph Hormann" <chr### [at] gmx de> schrieb im Newsbeitrag
news:3C4AE575.6172DB98@gmx.de...
(faster)
I haven't read so much 'bout displace-warps, but I'd also like to stay
3.5-compatible.
But currently I've no idea, what I've to do with the 4 samples I took ...
Therefore my question, if there is one macro out there (somewhere), and if it
would be possible,
to include it into functions.inc for one of the following versions ...
I didn't post it to beta-test, becase it's a feature-request,
but probably some of the responsible persons are reading here, too ...
> would be possible,
For the length of the gradient try the following:
function {
sqrt(
(fn_test(x+DELTA, y, z) - fn_test(x, y, z))^2+
(fn_test(x, y+DELTA, z) - fn_test(x, y, z))^2+
(fn_test(x, y, z+DELTA) - fn_test(x, y, z))^2
)/DELTA
Note that Povray right now does not optimize the multiple 'fn_test(x, y,
z)' so there are in fact 6 function evaluations.
I will see what i can do concerning inclusion of such things into the
include files.
> with rays ...
> given point.
> gradient...
I agree very much with you Jan, it would be very nice
to have a built-in function that would return the
numerically calculated gradient vector for 3D functions
at any point in 3D-space.
If you look into my reply to Barron Gillon's
post to this group 24. Dec. 2001;
"isosurface surface normals",
you'll find such a macro: vGradient()
http://news.povray.org/povray.advanced-users/20922/138919/
news://news.povray.org/3C292BC5.5A6AB4A6%40hotmail.com
Example usage:
#declare WrinkleFn = function { pattern { wrinkles } }
#declare vWrinkleGradient =
vGradient(
function { WrinkleFn(x, y, z) },
<3, -2, 1>
If you have a closer look at this macro, you'll
probably notice its similarities to the three
functions DerxFn(), DeryFn() and DerzFn() in
my reply to your post 12. Nov. 2001:
"Help on isosurface - distances - other stuff..."
http://news.povray.org/povray.advanced-users/19992/130234
news://news.povray.org/3BF0541A.62BC8C1F%40hotmail.com
Tor Olav
