POV-Ray : Newsgroups : povray.advanced-users : Curve fitting a function with a cubic spline Server Time
18 May 2026 00:02:38 EDT (-0400)
  Curve fitting a function with a cubic spline (Message 1 to 5 of 5)
Subject: Curve fitting a function with a cubic spline
Date: 17 Jan 2002 01:28:02
Message: <3c466ef2$1@news.povray.org>
I've been searching around the web on this one and I'm stumped
Say I have a function that is continuous between two defined points.  Which
method should I use to pick control points to fit a cubic spline to the
function.  I've found information on the least squares method but I'm not
entirely sure how to proceed.  The function is two dimensional.  0 to 1 on
the x axis and 0 to 1 on the y.  The function plots are close to linear from
(0,0) to (1,1) with a small amount of drift that can't be ignored.  It's the
deviation from linear that I'm interested in so i can't just assume it's
linear.  It may be that I've just stared at the problem blindly for too long
but any help would be appreciated
thanks
Chris
Subject: Re: Curve fitting a function with a cubic spline
Date: 17 Jan 2002 18:59:58
Message: <3C476509.937360DC@hotmail.com>
Unfortunately I don't have to to investigate
this, but you can try this search:
http://www.google.com/search?hl=en&q=curve+fitting+3rd+degree+polynomial+%22cubic+spline%22
Btw.:
Are you thinking of using _one_ or _several_
cubic splines to interpolate the function ?
Tor Olav
Date: 17 Jan 2002 19:02:16
Message: <3C476596.1884D1F7@hotmail.com>
Or just this:
http://www.google.com/search?q=curve+fitting+3rd+degree+polynomial&hl=en
Tor Olav
Date: 17 Jan 2002 20:57:50
Message: <3c47811e@news.povray.org>
"Tor Olav Kristensen" <tor### [at] hotmailcom> wrote in message
news:3C476509.937360DC@hotmail.com...
cubic+spline%22
> Btw.:
> Tor Olav
I'm trying to get away with using a single spline.  The function curve
should be fairly simple under most if not all conditions.  My recent
attempts have been aimed at placing control points at the peaks, troughs,
and zero crossing points of the function.  It works to a degree but I need
to make the peak,trough,zero routines more accurate and rework how it
determines the first and last point in the spline.  Thanks for the link, I
managed to dig up some old SIGGRAPH papers on the subject today as well.
Chris
Date: 18 Jan 2002 14:34:49
Message: <3c4878d9@news.povray.org>
cubic+spline%22
> Btw.:
> Tor Olav
Ok, I've managed to write a macro to fit the a cubic spline (pov 3.5 b10) to
a function.  I assigned control points to the peaks, troughs, and zero
crossings of the function.  The only thing I still can't figure out is how
to find the endpoints.  For n points running from 0 to n, I've only managed
to get everything between 1 and n-1.  I tried the links that Tor Olav
suggested and even tried other sites on the subject but I'm still stumped.
Odds are the answer is staring me in the face but .....
I'm using the POV 3.5 cubic spline feature so I need to find the time value
and coords of the endpoints.
Thanks
Chris
