POV-Ray : Newsgroups : povray.advanced-users : Transparent plane with non-transparent shadows? Server Time
20 Dec 2025 08:10:59 EST (-0500)
  Transparent plane with non-transparent shadows? (Message 1 to 10 of 15)
Subject: Transparent plane with non-transparent shadows?
Date: 6 Dec 2001 21:12:34
Message: <3c102592@news.povray.org>
Is it possible to create a plane that is transparent in the light but
becomes slightly non-transparent in shadow? I know this isn't physically
accurate, but I'm basically trying to create a transparent image that casts
a shadow on its background. I'm using version 3.5 beta.
Anders
Subject: Re: Transparent plane with non-transparent shadows?
Date: 7 Dec 2001 01:24:35
Message: <3c1060a3@news.povray.org>
Maybe  no_image  is all you need to put in the plane.  I did that for a
drop-shadow of my desktop icons and used the result for wallpaper.  I think
I did anyhow, either that or it was light_group
"Anders K." <and### [at] f2scom> wrote in message
news:3c102592@news.povray.org...
casts
Date: 7 Dec 2001 07:24:55
Message: <3c10b516@news.povray.org>
bob h <omn### [at] charternet> wrote:
: Maybe  no_image  is all you need to put in the plane.
  If you don't see the plane, you don't see the shadow cast onto it either...
Date: 7 Dec 2001 09:02:42
Message: <3c10cc02@news.povray.org>
No_image on the plane didn't work. I think what you're thinking of is making
the *object* have no_image so all you can see is its shadow. I'm looking for
something slightly different; I want both the object and the shadow to show
up, but the rest of the plane to be transparent.
Any other ideas, anyone?
Anders
Date: 7 Dec 2001 11:02:29
Message: <3c10e814@news.povray.org>
Anders K. <and### [at] f2scom> wrote:
: Any other ideas, anyone?
  Thinking about how the raytracing/lighting algorithms used in povray work,
I have the feeling that it's not possible.
  A shadow is just a non-lit part of the pigment of a surface. This means that
the light source does not contribute to lightening up that part of the surface
pigment. That is, the pigment just gets darker.
  If there's no pigment to show, there can't be a darkening of this pigment
either.
  It might be possible using other methods than lighting calculations. It may
be possible to make a copy of the object and apply a proper semi-transparent
black pigment to it. Then this object is skewed and scaled properly so that
it looks like projected onto the plane. This way you would have an actual
object which looks like the shadow of the original object.
  I'm not sure yet of the exact transformations needed for this "shadow"
object.
Date: 7 Dec 2001 11:25:23
Message: <3c10ed73@news.povray.org>
Just an untried suggestion that will need some tweaking. Render the pic with
a white plane so the shadow is cast and use this as a material map,
pigment_pattern,  or image_pattern making the white part transparent and the
black whatever you want.
Mick
news:3c10e814@news.povray.org...
work,
that
surface
pigment
> either.
may
semi-transparent
that
> object.
Date: 7 Dec 2001 11:54:01
Message: <3c10f429@news.povray.org>
news:3c10b516@news.povray.org...
either...
You might have misunderstood the idea, or maybe I did.  If it's about using
a transparent object to cast a shadow onto a nontransparent object then the
following should do okay.
  location  -100*z
        orthographic
  look_at   0
box {
  -<image_width,image_height,0>/2,<image_width,image_height,50>/2
  pigment {rgb <0,1,0>}
  finish {ambient .25 diffuse .75}
#declare Icons=
box {
  -<image_width,image_height,0>/2,<image_width,image_height,0>/2
  pigment {image_map {"shadows" map_type 0 once transmit 24, 1}
        translate <-.5,-.5,0> scale <image_width,image_height,1>
  finish {ambient 1 diffuse 0}
  translate <0,0,-2>
//union {
light_source {
  0,
  1.5
  area_light <150,0,0>,<0,150,0>,4,4 jitter
  translate -1000*z
  rotate <45,45,0>
object {Icons no_image}
This is how I made the drop-shadow for my desktop icons which were imaged by
screen capture first then the solid background color made transparent.
I was also thinking this could be done with the "tiny scaled and near light"
trick to leave the actual object out of view.
The other way the concept could be interpreted is for the object where the
shadow falls across to be transparent yet still show that shadow on it.
Thinking maybe this is what got conveyed but having read the original
message again it sounds more like what I first thought.
text{ttf"arial","bob h",.1,0pigment{rgb 9}translate<-1,-.2,3>}
Date: 7 Dec 2001 12:03:30
Message: <3c10f662$1@news.povray.org>
"bob h" <omn### [at] charternet> wrote in message
news:3c10f429@news.povray.org...
> either...
using
the
No, I think he wants a plane (say in mid air) upon which shadows are cast
and are visible, but where there is no shdow, is completely transparent.
-tgq
Date: 7 Dec 2001 12:10:16
Message: <3c10f7f8@news.povray.org>
Ooops.  Yes, having now read the other message by Anders I see how he's
wanting it to be.  Sorry.
"Trevor Quayle" <Tin### [at] hotmailcom> wrote in message
news:3c10f662$1@news.povray.org...
Date: 7 Dec 2001 19:01:19
Message: <3c11584f$1@news.povray.org>
work,
Yeah, I was afraid that would be the case...
Although I realized it might be possible if transmit/filter could be
included in a light's color, not just rgb. Then you could "shine" the
transparency onto the plane. Of course, this makes no sense physically, but
it could still be useful.
may
semi-transparent
that
This is an interesting idea -- I'll try it. Do you think that by making
several semi-transparent copies scaled in the right way, you could simulate
an area light?
