POV-Ray : Newsgroups : povray.advanced-users : [EMERGENCY] - Help with geometry... Server Time
25 Nov 2026 15:11:13 EST (-0500)
  [EMERGENCY] - Help with geometry... (Message 1 to 7 of 7)
Subject: [EMERGENCY] - Help with geometry...
Date: 2 Dec 2001 23:41:04
Message: <3c0b0260@news.povray.org>
I need this for tomorrow, for a speech on computers. I want to have a model
of a mouse for illustrative purposes. I've made a CSG of what it looks like
from above and from the side, and intersected those to form the basic shape.
I want to round the edges of the top part. I've got a while-loop that almost
does it, but for some reason, things don't quite line up. Please help me.
Thanks in advance!
//a computer mouse
//anthony bennett
//december 2, 2001
#default {pigment {rgb 1} finish {ambient 0 diffuse 1}}
#macro SIGN(NUM)
 #if (NUM>=0) 1 #else -1 #end
global_settings {ambient_light 0 assumed_gamma 1}
camera {location <1,1,-1>*5 look_at 0}
light_source {<-1,2,-1>*15 1}
sky_sphere {pigment {rgb z}}
#declare X_View =
difference
 cylinder {-x*2,x*2,2}
 plane {y,0.5}
 plane {-z,0 translate z*1.0}
 plane {z,0 translate -z*1.5}
 translate <0,-0.5,0.25>
 scale <1.25,1,1/1.25*2.8>
#declare Y_View =
union
 difference
  cylinder {-y,y*2,1 scale <1.25,1,2.55>}
  plane {z,0}
  translate  z*0.25
 box {<-1.25,-1,-0.25>,<1.25,2,0.25>}
 difference
  plane {-z,0}
  translate -z*0.25
#declare Rounding = 0.1;
#declare Small_Y_View =
union
 difference
  cylinder {-y*2,y*3,1 scale <1.25-Rounding,1,2.55-Rounding>}
  plane {z,0}
  translate  z*0.25
 box {<-1.25+Rounding,-2,-0.25>,<1.25-Rounding,3,0.25>}
 difference
  plane {-z,0}
  translate -z*0.25
difference
 intersection
  object {X_View}
  object {Small_Y_View}
 object {X_View translate -y*Rounding}
#declare Y_R = 2;
#declare Y_Start_Z = 1;
#declare Y_End_Z = -1.5;
#declare Start_Y = sqrt(Y_R^2-Y_Start_Z^2);
#declare End_Y = sqrt(Y_R^2-Y_End_Z^2);
#declare Start_A = -degrees(asin(Start_Y/Y_R));
#declare End_A = degrees(asin(End_Y/Y_R));
union
 #declare B = Start_A;
 #while (B<=End_A)
  #declare PosY = (vrotate(y*2,x*B)+<0,-0.5,0.25>)*<1.25,1,1/1.25*2.8>;
   #switch(PosY.z)
   #range(-2.8,-0.25)
    #declare Pos1X = sqrt(1-(PosY.z/2.8)^2)*(1.25-Rounding);
    #declare Pos1 = < Pos1X,PosY.y-Rounding,PosY.z-Rounding*SIGN(PosY.z)>;
    #declare Pos2 = <-Pos1X,PosY.y-Rounding,PosY.z-Rounding*SIGN(PosY.z)>;
    sphere {Pos1,Rounding}
    sphere {Pos2,Rounding}
   #break
   #range(-0.25,0.25)
    #declare Pos1 = <
1.25-Rounding,PosY.y-Rounding,PosY.z-Rounding*SIGN(PosY.z)>;
    #declare Pos2 =
<-1.25+Rounding,PosY.y-Rounding,PosY.z-Rounding*SIGN(PosY.z)>;
   #break
   #range(0.25,2.8)
   #break
  #declare B = B + 0.01;
Date: 3 Dec 2001 16:00:50
Message: <jFAPOBACf+C8EwcF@econym.demon.co.uk>
>Thanks in advance!
I couldn't manage it using POV-Ray 3.1, but I've managed it using the
beta version of POV-Ray 3.5 and using MegaPOV.
I couldn't work out for myself where the little spheres should go, so I
used the new trace() facility to work out where the edges of the mouse
were located. I first sweep round the XZ plane looking for points where
it intersects the Small_Y_View. For each point I find I then trace
downwards from a point a long way vertically above it, to give me a
point on the top edge of the mouse. We know that the mouse is "Rounding"
thick, so the small sphere should be placed -y*0.5*Rounding down from
this top edge.
(Using sphere sweeps would be nicer than individual spheres, but since
it's an emergency I've not spent any time trying to code that.)
One extra tweak is that I changed the Small_Y_View from a union into a
merge because trace() kept finding interior surfaces of the object.
(Though I suppose I could have traced from the outside looking in, which
should work just as well).
The following code works in POV-Ray 3.5 (beta) and MegaPOV, but not in
POV-Ray 3.1 because it uses the new trace() facility.
#macro SIGN(NUM)
camera {location <1,1,-1>*3 look_at 0}
#declare X_View =
difference
 plane {y,0.5}
#declare Y_View =
union
 difference
  plane {z,0}
  translate  z*0.25
 difference
  plane {-z,0}
  translate -z*0.25
merge // otherwise trace finds an internal face
 difference
  plane {z,0}
  translate  z*0.25
 difference
  plane {-z,0}
  translate -z*0.25
difference
 intersection
  object {X_View}
#declare A = 0;
#while (A < 2*pi)
  // use trace to find the rim of the Y view
  #declare XZpos=trace(Small_Y_View, 0, <sin(A),0,cos(A)>);
  // trace from miles above downwards to find top edge
  #declare TopXYZ=trace(X_View, XZpos+y*5, -y);
  // sphere half "Rounding" down from there
  sphere {TopXYZ-y*Rounding*0.5 ,Rounding*0.5}
  #declare A=A+0.01;
Subject: Re: [EMERGENCY] - Help with geometry...
Date: 3 Dec 2001 16:39:09
Message: <3c0bf0fd@news.povray.org>
> I want to have a model of a mouse for illustrative purposes.
I have three things to say:
1) I hope you get this in time.
2) I hope it is a *really* important emergency.
3) I hope nobody beat me to it.
...because it took me quite a while to do this!
> I've got a while-loop that almost does it, but for some
Couldn't understand it. Made my own version. Here you go:
// a computer mouse
// anthony bennett
// december 2, 2001
#macro SIGN(NUM)
#declare X_View =
difference
 plane {y,0.5}
#declare Y_View =
union
 difference
  plane {z,0}
  translate  z*0.25
 difference
  plane {-z,0}
  translate -z*0.25
union
 difference
  plane {z,0}
  translate  z*0.25
 difference
  plane {-z,0}
  translate -z*0.25
difference
 intersection
  object {X_View}
  object {Small_Y_View scale <1,1,1.01>}
#declare Obj1 = Small_Y_View
#declare Obj2 = X_View
#include "math.inc"
union {
   #declare C = 0;
   #declare Samples = 1000;
   #while (C<Samples)
      #declare Norm = <0,0,0>;
      #declare Direction = vrotate(x,360*y*(C/Samples));
      #declare PosXZ = trace(Obj1, 100*Direction, -Direction, Norm)*<1,0,1>;
      #if (vlength(Norm)>0)
         #declare PosY = trace(Obj2, 10*y+PosXZ, -y, Norm)*y;
            #declare Ang = VAngle(y,Norm);
            #declare Pos = (
               +PosXZ+PosY
               -Rounding*y
               -y*(cos(Ang)+(sin(Ang)*vlength(Norm*<1,0,1>))-1)*Rounding
            sphere {Pos, Rounding}
      #declare C = C+1;
Date: 3 Dec 2001 16:50:03
Message: <3c0bf38b@news.povray.org>
> should go, so I used the new trace() facility to work out
> where the edges of the mouse were located.
Hmm, seems like we came up with the exact same method.
But you forgot to take into account the fact that the spheres stick up
slightly of the surface on all non-horizontal surfaces, i.e. everywhere.
Thus the edge is not 100% smooth in your version...
Sorry, I had to point that out... :)
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Date: 3 Dec 2001 20:54:24
Message: <3c0c2cd0@news.povray.org>
Nope. Didn't.
Not really. I managed to get by without the mouse being rounded.
Sorry. And thanks!
Date: 3 Dec 2001 20:54:49
Message: <3c0c2ce9@news.povray.org>
Thanks. I was really hoping for a method that didn't use trace(). Oh, well.
Date: 4 Dec 2001 16:12:41
Message: <3c0d3c49@news.povray.org>
> Nope. Didn't.
Oh well... Time spend with POV-Ray is never completely wasted...
Rune
