POV-Ray : Newsgroups : povray.advanced-users : accuracy ? Server Time
20 Dec 2025 08:10:55 EST (-0500)
  accuracy ? (Message 1 to 10 of 12)
Subject: accuracy ?
Date: 16 Nov 2001 13:19:21
Message: <3bf558a9$1@news.povray.org>
I'm trying, to play a bit with meshes ...
I build a sphere with a rekursive tesselation ...
so far a OK
Next step was to add some noise to the surface...
I decided to add the value of the bozo ...
but now, the triangles no longer fit together ...
Where did I mix up the wrong variables ?
Image is going to p.b.i.
file://---------------------------------------------------------
#declare Fn_p=function {
    pattern {
        bozo
        scale 0.1
#declare Fn=function {
    (Fn_p(x,y,z)-0.5)*0.05
#macro Recursion(p1,p2,p3,c,d)
    #local pp1=vnormalize(p1-c)+c+Fn(p1.x,p1.y,p1.z)*p1;
    #local pp2=vnormalize(p2-c)+c+Fn(p2.x,p2.y,p2.z)*p2;
    #local pp3=vnormalize(p3-c)+c+Fn(p3.x,p3.y,p3.z)*p2;
    #if (d>0)
        Recursion(pp1,(pp1+pp2)/2,(pp1+pp3)/2,c,d-1)
        Recursion((pp2+pp3)/2,(pp1+pp2)/2,pp2,c,d-1)
        Recursion((pp2+pp3)/2,pp3,(pp1+pp3)/2,c,d-1)
        Recursion((pp2+pp3)/2,(pp1+pp3)/2,(pp1+pp2)/2,c,d-1)
    #else
        triangle {pp1,pp2,pp3}
#macro RecurseObj(c,d)
    mesh
    Recursion (c+x,c+y,c-z,c,d)
    Recursion (c+x,c-y,c-z,c,d)
    Recursion (c-x,c+y,c-z,c,d)
    Recursion (c-x,c-y,c-z,c,d)
//    Recursion (c+x,c+y,c+z,c,d)
//    Recursion (c+x,c-y,c+z,c,d)
//    Recursion (c-x,c+y,c+z,c,d)
//    Recursion (c-x,c-y,c+z,c,d)
  location  <0.0, 0.5, -4.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
plane {
  y, -1
  pigment { color rgb <0.7,0.5,0.3> }
object {
    RecurseObj(0.1,6)   // recursiondepth ans Center of sphere...
    pigment {color rgbt <1,1,1,0.0>}
Jan Walzer <jan### [at] lzernet>
Subject: Re: accuracy ?
Date: 16 Nov 2001 15:24:30
Message: <3bf575fe@news.povray.org>
First of all I'd want to say  that I did not look to your macros (I'm sorry
but hand editing meshes is not my strong point). That said, I think that
this could be some floating point approximation problem. Maybe I'm
completely wrong (in that case forgive me, please) but I think that with a
mesh2 object you could avoid this problem (two coincident vertexes are not
reapeted, are they?).
Jonathan.
"Jan Walzer" <jan### [at] lzernet> ha scritto nel messaggio
news:3bf558a9$1@news.povray.org...
> so far a OK
>     pattern {
>         bozo
>         scale 0.1
>     #if (d>0)
>     #else
>     #end
> #end
>     mesh
> #end
> camera {
>   direction 1.5*z
> light_source {
> plane {
>   y, -1
> object {
Date: 16 Nov 2001 15:56:45
Message: <3bf57d8d$1@news.povray.org>
"JRG" <jrg### [at] hotmailcom> schrieb im Newsbeitrag
news:3bf575fe@news.povray.org...
so why did you repeat the whole thing then ?
correct in parts ...
You can in mesh2 use one vertex for multiple triangles ..
but AFAIK you can also to the same mess, and put every vertex multiple
times in the list ...
Also, I just tried this algorithm the first time, and it was easier to
create with a normal mesh...
Maybe I'll try to port it to mesh2, but this will be quite hard ...
on the other hand, it was possible, by only changing some steps in the logic
of the computation, to clear these holes, but the thing is, I don't know, why
they happend here ... I don't believe here in accuracy things ... that would
be
to simple...
Date: 17 Nov 2001 12:58:33
Message: <3BF6A53A.F86D0573@free.fr>
> so far a OK
Trying to provide some light...
you should experiment with
        0.2
And see the resulting image.
The problem does not come from the bozo,
nor from precision loss.
I Hope this could help.
Date: 19 Nov 2001 03:31:52
Message: <rqghvtg9eigbucr72homvnsi3pns0vcr3j@4ax.com>
> #declare Fn=function {0.2}
There were such sentence within this beta-test group:
"It make ***not*** sense to have a function with
_zero_ parameters and thus it is not allowed."
Such example shows it is sometimes useful.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 19 Nov 2001 04:05:26
Message: <3bf8cb56@news.povray.org>
: There were such sentence within this beta-test group:
: "It make ***not*** sense to have a function with
: _zero_ parameters and thus it is not allowed."
: Such example shows it is sometimes useful.
  What is the fundamental difference between this:
and this:
#declare Fn=0.2;
Date: 19 Nov 2001 04:09:16
Message: <quihvtci1otu08aapgmt3qj2kics0gknch@4ax.com>
> and this:
> #declare Fn=0.2;
is it rhetorical question ?
my answer is "refferencing way" ;-)
ABX
Date: 19 Nov 2001 04:39:32
Message: <3bf8d354@news.povray.org>
:>  What is the fundamental difference between this:
:> #declare Fn=function {0.2}
:> and this:
:> #declare Fn=0.2;
: is it rhetorical question ?
  Nope. What I tried to say was that the function declaration above is
more or less obsolete.
Date: 19 Nov 2001 04:51:29
Message: <3BF8D68C.A2D05CDA@atosorigin.com>
> :> and this:
> :> #declare Fn=0.2;
Maybe, but a function declaration without parameter implicitely got three
parameters (x,y,z). Now, nothing force you to use the parameters
for the computation of the function...
Invoking the function DOES request the parameters, and what was
previously said was that INVOKING a function without parameters was
a non-sense (to which I agree).
Rather than nitpicking about the function syntax, we should try to solve
the initial query.
Date: 19 Nov 2001 10:27:28
Message: <3bf924e0@news.povray.org>
> the initial query.
it  was a problem in the logic of thinking ...
What I changed was:
to the following:
    #local pp1=vnormalize(p1-c);
    #local pp2=vnormalize(p2-c);
    #local pp3=vnormalize(p3-c);
    #local pp1=pp1+Fn(pp1.x,pp1.y,pp1.z)*pp1+c;
    #local pp2=pp2+Fn(pp2.x,pp2.y,pp2.z)*pp2+c;
    #local pp3=pp3+Fn(pp3.x,pp3.y,pp3.z)*pp3+c;
So it was neither the bozo, nor an accuracy-problem ...
What makes me wonder is, WHY this makes a difference ?
Shouldn't the first approach treat the congruent(?) points of the adjacent(?)
triangles all in the same way, so they still should be all in the same point
Obviously they are not, but why? Furthermore, Why did the second way solve
this ?(Indeed, it is no longer the identical function to the first way, but
it
fits to my needs)
Now, Okay .. The resulting image is in p.b.i ... I did the spheres as meshes,
to
be able to play a bit with LevelOfDetail Algorithms ...
