POV-Ray : Newsgroups : povray.advanced-users : Projection types of the camera Server Time
12 Jan 2025 21:47:42 EST (-0500)
  Projection types of the camera (Message 1 to 9 of 9)
Subject: Projection types of the camera
Date: 1 Nov 2001 14:16:06
Message: <3be19f76$1@news.povray.org>
Hi!
I am currently developing a povray modeler for KDE (see
http://www.azweb.de/kpovmodeler) and need some help with the projection
types of the camera.
Currently I am only able to visualize the perspective and orthographic
projections. I need some more detailed information on how the other
projection types work. Can you point me to a web site or a book or... ? The
user povray documentation says not much about these projections.
Greetings, Andreas
 Andreas Zehender, Dipl. Ing. (BA)
 Student, 9th semester computer science
 http://www.azweb.de
 az### [at] azwebde | zeh### [at] kdeorg
Subject: Re: Projection types of the camera
Date: 1 Nov 2001 14:29:28
Message: <3be1a297@news.povray.org>
Have you checked the povray source? I think it's quite straightforward there.
Date: 1 Nov 2001 14:59:20
Message: <3be1a998$1@news.povray.org>
>   there.
Yes. I am looking at the render.c file at the moment. But a nice paper with
some images would be nicer :-)
 Student, 8th semester computer science
 http://www.azweb.de
Date: 1 Nov 2001 15:37:55
Message: <3be1b2a3$1@news.povray.org>
Hmm, images could help explain the documentation a bit, also. I never really
understood how fisheye or omni cameras work.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
"Andreas Zehender" <zeh### [at] kdeorg> wrote in message
news:3be1a998$1@news.povray.org...
> >   there.
with
>  http://www.azweb.de
Date: 2 Nov 2001 15:05:59
Message: <8fg4ut4235q4ks9lotpqcbm8mudbn4rhug@4ax.com>
On Thu, 1 Nov 2001 20:16:44 +0100, Andreas Zehender <zeh### [at] kdeorg>
You might have some trouble with the rest of the camera types in terms
of visualization, as I doubt Mesa supports real-time nonlinear
transformations :)
Peter Popov ICQ : 15002700
Date: 3 Nov 2001 13:34:58
Message: <3be438d2@news.povray.org>
> transformations :)
I know that.
Since I render only a wireframe, I will subdivide the rendered lines and do
some vertex based non linear transformations (with some trigonometrical
lookup tables for speedup) to approximate complex camera types.
I need no real time solution because the rendering is nonblocking and can
take some time.
 http://www.azweb.de
Date: 5 Nov 2001 12:16:51
Message: <3be6c983@news.povray.org>
> I know that.
Are lookuptables still needed today for these usages ?
AFAIK first-person-shooters and thelike are using the FPU of the current
processors, so there shouldn't be the need to "accelerate" the program this
way....
(of course, these games are using mostly a perspective camera)
I think the times of precalculated Trig-tables are gone ...
BTW: What shall I do with my SupaDupa-Athlon with VeryFastKillThemAll-CPU ???
(I don't own an Alpha yet... ;)
Date: 5 Nov 2001 16:10:06
Message: <3be7002e@news.povray.org>
> this way....
I think so. You have much more vertexes than first person shooters in a
modeler. Rendering the wireframe of the chess2.pov example takes half a
second on my TNT 2 and a 433 celeron with a perspective camera.
And the perspective camera uses only simple transformations.
I think calling trigonometrical functions for each vertex would be far too
slow (didn't tested it yet)
 http://www.azweb.de
Date: 6 Nov 2001 07:32:24
Message: <3be7d858@news.povray.org>
"Andreas Zehender" <zeh### [at] kdeorg> schrieb im Newsbeitrag
news:3be7002e@news.povray.org...
> > this way....
I think there are other optimizations to go before using tables ...
I can't really believe that the FPUs are still SOOOOO much slower ...
Consider, that for a modeller, you'll need a very high accuracy, and so you
need very big tables ...
Also I'm sure, you won't use Integer(or Fixpoint)-Maths ...
So you'll have to transfer your numbers from FPU to memory, and back often
enough ...
This won't speed up your program very much ...
I for myself, would leave this option open, as one of the last ways to speed
up, if it's still to slow ... (or make it optional)
You surely have already thought about backface culling and thelike, haven't
you ?
Jan Walzer <jan### [at] lzernet>
