POV-Ray : Newsgroups : povray.advanced-users : Problem wih POV-Syntax Server Time
12 Jan 2025 22:03:07 EST (-0500)
  Problem wih POV-Syntax (Message 1 to 3 of 3)
Subject: Problem wih POV-Syntax
Date: 8 Oct 2001 07:56:16
Message: <3bc19460$1@news.povray.org>
Hi NG,
i am working on a macro for creating Blobcomponents. I've already
successfully implemented this with a blob-object. But now i want to use an
isosurface, because of the freedom of adding additional functions. when i
try my new macro i get a parser-error stating a vectoridentifier where an
operand should be, but i used the .x (.y / .z) operator to extract a
float-value but povray doesn't seem to care... has anyone tips what i made
wrong? Thanks in advance
    Thies Heidecke
the macro :
#macro Icosaeder(C,S,CR,R,L)   // Recursive Macro
    #if(L=0)
        S*(1 - ( ( (x-C.x)^2 + (y-C.y)^2 + (z-C.z)^2 ) / (CR*R)^2 )^2 +   //
<---here's the error
    #else
        #local New_L = L-1;
        #local New_R = R*nsr;
        Icosaeder(C+ P1*R*ir,S,CR,New_R,New_L)
        Icosaeder(C+ P2*R*ir,S,CR,New_R,New_L)
        Icosaeder(C+ P3*R*ir,S,CR,New_R,New_L)
        Icosaeder(C+ P4*R*ir,S,CR,New_R,New_L)
        Icosaeder(C+ P5*R*ir,S,CR,New_R,New_L)
        Icosaeder(C+ P6*R*ir,S,CR,New_R,New_L)
        Icosaeder(C+ P7*R*ir,S,CR,New_R,New_L)
        Icosaeder(C+ P8*R*ir,S,CR,New_R,New_L)
        Icosaeder(C+ P9*R*ir,S,CR,New_R,New_L)
        Icosaeder(C+P10*R*ir,S,CR,New_R,New_L)
        Icosaeder(C+P11*R*ir,S,CR,New_R,New_L)
        Icosaeder(C+P12*R*ir,S,CR,New_R,New_L)
Subject: Re: Problem wih POV-Syntax
Date: 8 Oct 2001 08:34:28
Message: <3BC19E3F.C374CD59@gmx.de>
Thies Heidecke wrote:
> Hi NG,
Try declaring locals like:
  #local Cx = C.x;
at the beginning of the macro.
Date: 8 Oct 2001 21:56:44
Message: <i8bDCHArvew7EwTi@econym.demon.co.uk>
>> Hi NG,
>  #local Cx = C.x;
Also, note that the line
        S*(1 - ( ( (x-Cx)^2 + (y-Cy)^2 + (z-Cz)^2 ) / (CR*R)^2 )^2 +  //
has seven "("s and only six ")"s. You either need to slip in a seventh
")" on that line somewhere or write a heck of a lot of them when you
return from your macro.
And remember that the expression returned by the macro has a spurious
"+" on the end, so you're going to have to call it something like
isosurface {
   function{
      Icosaeder(...)
      0
Where the extra "0" is simply there to prevent the trailing "+" being
syntactically incorrect.
Mike Williams
Gentleman of Leisure
